قديم 17-08-2012, 05:28 PM   #1
مشاركات الشكر: 65
شكر 91 مرات في 44 مشاركات
رووووووم i9003 [ALPHA][ROM][4.0.4] CyanogenMod 9
السلام عليكم وحمة الله وبركاته
الروم يا اخواني صار شغال 100%
Changelog
Alpha 11 - 08042012
Fixed Video Recording.
Fixed Audio Latency which was causing Audio sync issues.
Bluetooth MAC and Device Name fixes.
Fixed issues with Bluetooth doesn't turn on at times until reboot.
Temporary fix for WiFi Scan issue.
Alpha 10 - 07242012
Fixed Media Playback on 720P videos.
Added MP3 and AAC Codecs.
Youtube now runs on hardware codecs.
Faster camera preview.
Included Samsung STK
Preliminary support for Video Recording (Needs some rework on Camera HAL).
Mainstream updates.
Alpha 9 - 07092012
Adjusted Back Button App kill Timeout
Updates and Fixes from the Mainstream.
Alpha 8 - 06202012
Fixed Camera color issues in apps (Cartoon Camera, Videocam Illusion)
Faster Camera Preview.
Restored Front Camera preview as that of A6.
Root access in recovery
Added Reboot to Download Mode.
Fixed few vibration patterns.
Faster boot animation.
Fixed issues with repeating keys in Recovery.
Tweaked autobrightness.
Fixed battery capacity to 1650mah.
Updated proprietary libraries from XXLE4
Fixed dmesg spam.
Few kernel CPU Fixes.
Alpha 7 - 06112012
Button lights are now controlled by the kernel
Added Device Setting to control Button Lights Timeout
Fixed few issues with Notification LED Indication.
Few more Bluetooth Fixes.
Tweaked GPU performance
Sync Bug Fix (Thanks XDA_BAM!)
Long press Menu button opens Google Search.
Updated sources (New Boot Animation!)
Camera Changelog:
Fixed issues with Third Party Apps (Hopefully)
Fixed Face Unlock (Barely works due to VGA Camera)
EXIF orientation for Front Camera (Partially)
Added Focus Modes (Auto, Macro and Face Detection)
Fixed issues with Landscape Scene Mode
Front Camera Stretch issues Fixed (Not perfect)
Support for 720p Preview (For Future use)
Fixed Autofocus issues with Timer Mode.
Alpha 6 - 05282012
Fixed USB Mass Storage Support
Fixed Minor Audio distortion issues when ringtone is played with HeadPhones
Fixed LED Button Lighting
Fixed Pulse Light Notification (BLN)
Fixed Haptic Feedback on Touchkeys
Backlight Fix - Thanks to arindammanidas!
Fixed GPS broken in Alpha 5
Fixed Bluetooth Crash and Disconnection issues thanks XDA_BAM
Updated to latest CM9 Nightly. (Lockscreen Weather Widget and New Apollo Player)
Camera Changelog:
Fixed issues with capture on Alpha 5
Really fast capture speed (Shutter).
Optimized image sizes for loss-less compression.
Fixed force close upon capture (Hopefully).
Fixed mirroring issues with Front facing camera after capturing.
Alpha 5 - 05232012
Fixed Microphone in Applications.
Updated Audio and Samsung Kernel Drivers.
Added Device Specific Settings.
Added HSPA/UMTS mode toggle.
Fixed Vibration Intensity. It could be adjusted from the Advanced Settings.
Included few dalvik tweaks for performance.
Added Samsung Service Mode.
Alpha 4 - 05102012
Fixed Camera preview and capture.
Switchable Internal and External Memory.
Use Opensource Audio HAL with FM Radio Support.
Fixed Audio Shutter during playback.
Fixed screen flickering when display is turned off.
Fixed multiple press issues with Home Button (Thanks XDA_BAM!)
Removed testing H/W Codecs. Youtube should now work on Software Rendering.
Alpha 3 - 04052012
Based on 4.0.4 CM9 Release.
Lots of bugfixes from upstream.
Upgraded GPU drivers. Fixed Hardware Acceleration.
Microphone Fixed in Applications.
Experimental Support for HD Video Playback (Not yet Complete).
Added Data Usage Limit / Statistics.
Revert to Samsung Mounts (Internal and External SD) to fix proper removal of External SD Card.
Few performance tweaks.
Update v2 - 04062012
Fixed issues with Updater Script (Black Screen)
Fixed GPU issues. Chrome now works fine.
Alpha 2 - 01192012
Fixed Audio (Ringtones and Media)
Fixed Bluetooth Audio and added A2DP Profiles. (Phone and Media)
Fixed Outgoing calls - Unable to Hang Up.
Fixed Incoming Calls - Doesn't Appear.
Fixed WIFI DHCP Issues.
Auto Brightness Fixed.
Pulse Light Notification (Somewhat works).
Fixed Proximity Sensor (Phone Calls).
Removed default search Apps. Google Apps package has newer versions.
Performance Tweaks.
Alpha 1 - 01172012
Initial Release
Quote:
Installation Instructions
Stock ROM
1. Flash CWM Compatible Kernel (CF ROOT)
2. Reboot to Recovery.
3. Select the ROM zip from your SD Card and flash.
4. Go to Advanced -> Reboot Recovery.
5. After the Recovery restarts, Wipe Data / Factory Reset.
6. Mounts and Storage -> Format dbdata
7. Flash Google Apps.
8. Reboot
Any other AOSP ROM (CM7/MIUI)
1. Reboot to Recovery.
2. Select the ROM zip from your SD Card and flash.
3. Go to Advanced -> Reboot Recovery.
4. After the Recovery restarts, Wipe Data / Factory Reset.
8. Reboot
Upgrading from previous versions of CM9
3. Flash Google Apps.
4. Reboot
لتنزيل الروم:dhiru1602 / Downloads اول واحد alpha 11
تنزيل برامج ICS :Goo.im Downloads - Browsing gapps
الرجاء الضغط على تقييم الموضوع الرجاء الرجاء
مع تحيات زيد جابر (والتجربة شخصية) والسلام عليكم
zaid jaber غير متصل   رد مع اقتباس
عدد 6 من الاعضاء يشكرون zaid jaber على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
اخر 5 مواضيع للعضو zaid jaber
الرجاء المساعدة الرجاء الرجاء قسم الملاحة للاجهزة الشخصية والمركبات nezarnuaimat 3 595 05-12-2015 03:57 PM
عمل سوفت وير لجهاز one x at&t قسم ترقيات أجهزة HTC بنظام Google Android zaid jaber 0 2048 12-12-2013 12:08 AM
الجالكسي اس4 I9505) 4G) نسخة CM 10.2 4.3 nightly قسم ترقيات أجهزة Samsung بنظام Google Android zaid jaber 4 1944 30-08-2013 05:06 AM
استفسار بسيط عن I9500 و i9505 الرجاء الدخول قسم ترقيات أجهزة Samsung بنظام Google Android sam hasoon 5 861 04-08-2013 12:11 AM
قديم 20-08-2012, 05:31 AM   #2
أسير االصمت
الصورة الرمزية أسير االصمت
مشاركات الشكر: 58
شكر 131 مرات في 73 مشاركات
مشكور على الروم الرائع واتشرف اكون اول من يرد على موضوعك
انا اريد تحميل وتجرة هذا الروم
بس هل يدعم اللغة العربية
ويا ليت تفيدني بطريقة تركيب الروم
أسير االصمت غير متصل   رد مع اقتباس
العضو التالي يشكر أسير االصمت على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 20-08-2012, 03:51 PM   #3
zaid jaber
مشاركات الشكر: 65
نعم يدعم وطريقة تنزيل الروم
نزل الروم ايس على اي روم تريده ونفس الطريقة اللي تنزل فيها الروم المطبوخ
قديم 20-08-2012, 04:36 PM   #4
Generl-hell
الصورة الرمزية Generl-hell
مشاركات الشكر: 30
شكر 41 مرات في 16 مشاركات
الله يوفقك اخوي الموصفات لو انها بالعربي
Generl-hell غير متصل   رد مع اقتباس
قديم 20-08-2012, 05:10 PM   #5
zaid jaber
مشاركات الشكر: 65
مواصفات ايش؟؟؟
الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 05:10 PM ----------- المشاركة السابقة اضيفت في 05:09 PM ---------
اخواني كل اشي في الروم صحيح انو الفا بس شغال كل اشي حتى الكاميرا شغاله وعلى 720p
قديم 25-08-2012, 09:08 PM   #6
vampire111
مشاركات الشكر: 21
اخي هاي ثاني مرة انزل روم سيانوجين و لا اجد file manager من اجل التحكم بالمجلدات
الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 09:08 PM ----------- المشاركة السابقة اضيفت في 07:27 PM ---------
كيف انزل اي برنامج دون ما ادخل مجلدات كرت الذاكرة
vampire111 غير متصل   رد مع اقتباس
العضو التالي يشكر vampire111 على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 27-08-2012, 02:45 AM   #7
zaid jaber
مشاركات الشكر: 65
المشاركة الأصلية كتبت بواسطة vampire111 مشاهدة المشاركة
اشبك الجهاز بالنت ونزل ICS file manager
قديم 27-08-2012, 10:36 PM   #8
moh821966
مشاركات الشكر: 135
شكر 53 مرات في 45 مشاركات
الاخ العزيز
جهازي gt i9003 النظام 2.3.4
لم يركب الروم في الجهاز ويعطيني رسالة خطا في بداية التركيب
moh821966 غير متصل   رد مع اقتباس
قديم 29-08-2012, 04:44 PM   #9
megapharaoh
انا نزلته وكل شئ تمام ولكل لا اجد File manager وكمان الجوجل بلاي دايما يعطيني Connection Error
الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 04:44 PM ----------- المشاركة السابقة اضيفت في 04:03 PM ---------
الان الروم اشتغل تمام والجوجل بلاي اوك الخطأ كان من عندي لأني حملت CyanogenMod 10 بدلا من 9 علشان كدة كان يعطيني connection Error ولكن لما دخلت على ملفاتي من برنامج ICS file manager وجدت ال External SD car خالي تماما من الملفات مع العلم اني حاطط عليه اغاني وموجودة على برنامج ابولو عادي جدا
megapharaoh غير متصل   رد مع اقتباس
قديم 30-08-2012, 10:37 AM   #10
zaid jaber
مشاركات الشكر: 65
المشاركة الأصلية كتبت بواسطة moh821966 مشاهدة المشاركة
الاخ العزيز
اعطيني شو بعطيك ؟؟؟؟؟
الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 10:37 AM ----------- المشاركة السابقة اضيفت في 10:33 AM ---------
المشاركة الأصلية كتبت بواسطة megapharaoh مشاهدة المشاركة
نزله من النت البرنامج وابعثه على بلوتوث الله بعينك لانو ممكن تكون منزل برامج CM10 وما بتكون متوافقة مع الجهاز لانو عندي شغال 100%
وكمان اذا بدك تدخل على الميموري الخارجية بتكون باسم emmc بتكون موجودة مع ملفات system
العضو التالي يشكر zaid jaber على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 30-08-2012, 06:45 PM   #11
megapharaoh
المشاركة الأصلية كتبت بواسطة zaid jaber مشاهدة المشاركة
الله ينور انا فعلا كنت منزل CM10 علشان كدة كان بيعطيني Error حذفت الرروم ونزلته مرة ثانية وشغال 100% وبصراحة الجهاز اتغير تماما وكأنه جهاز ثاني وبالنسبة للميموي الخارجي وجدته فعلا زي مانت قلت الف شكر
العضو التالي يشكر megapharaoh على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 30-08-2012, 11:41 PM   #12
zaid jaber
مشاركات الشكر: 65
المهم اخوي تعمل تقييم للموضوع عشان يضل الجهاز حي وانا الوحيد الموجود في المنتدى المهتم بالجهاز
قديم 31-08-2012, 08:10 PM   #13
moh821966
مشاركات الشكر: 135
الاخ الكريم زيد
ركب الروم بشكل ممتاز مع برامج جوجل
وطبعا كل الشكر والامتنان لك
الى الان لم اجد اي مشكلة لانني جديد على الايسكريم
مع خالص شكري وتحياتي
العضو التالي يشكر moh821966 على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 01-09-2012, 06:05 AM   #14
zaid jaber
مشاركات الشكر: 65
الاخ الكريم زيد
واذا بتلاقي مشاكل قلي ان شاء الله اقدر بحلها
قديم 01-09-2012, 08:45 PM   #15
cloud s
شكر 6 مرات في 6 مشاركات
اريد طريقة تثبيت CyanogenMod 9 على جهاز SCL GT i9003
بالتفصيل الممل و لك مني جزيل الشكر
هل يعمل الجهاز بدون ادنى مشاكل ؟؟؟
cloud s غير متصل   رد مع اقتباس
قديم 01-09-2012, 11:20 PM   #16
Jordanyme
شكر 39 مرات في 19 مشاركات
يا اخوان اريد اي روم لهذا الجهاز فقط يشغل برنامج الفايبر !
هل من المستحيل تشغيل المكالمات بالفايبر على هذا الجهاز أم ماذا ؟!
الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 11:20 PM ----------- المشاركة السابقة اضيفت في 11:05 PM ---------
يا جماعة الخير هل هذا المنتدى مهجور أم ما الحكاية ؟!
يا عم زياد رد علينا يرحم والديك
أنا رايح اسمع اغنية "لا تندهي ..مافي حدا" لفيروز
Jordanyme غير متصل   رد مع اقتباس
قديم 01-09-2012, 11:23 PM   #17
جلاكسي9
الصورة الرمزية جلاكسي9
مشاركات الشكر: 3,097
شكر 5,387 مرات في 3,033 مشاركات
ركب روم رسمي
جلاكسي9 غير متصل   رد مع اقتباس
العضو التالي يشكر جلاكسي9 على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 01-09-2012, 11:58 PM   #18
Jordanyme
المشاركة الأصلية كتبت بواسطة جلاكسي9 مشاهدة المشاركة
ركب روم رسمي
الف شكر على ردك... والله اعتقدت انه ما في غيري بالمنتدى لأنه حضرتك أول واحد يرد علي
ركبت الروم الرسمي وحدثته من ال Kies لكن جميع برامج ال VOIP لا يعمل المايكرفون فيها ... اليوم عملت روت للنسخة 2.3.6 وطبعا تعطلت الوايرلس لذلك حاليا ليس هناك اي خيار غير تنزيل روم جديدة ولذلك اسأل عن اي روم تعمل عليها برامج ال VOIP فاذا لا تعمل فلا داعي للجهاز الذي شريته علشانها
الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 11:58 PM ----------- المشاركة السابقة اضيفت في 11:28 PM ---------
طيب الجهاز للبيع الي يحب يشتري مع قابلية التبديل بكروزات دخان (مالبورو أحمر) علما ان الجهاز نظيف واستعمال فتاة
قديم 02-09-2012, 12:03 AM   #19
جلاكسي9
ركب روم 2.3.4
و ان اشاء الله تضبط معك
قديم 02-09-2012, 12:05 AM   #20
Jordanyme
ركب روم 2.3.4
عزيزي روم 2.3.4 فيها من المشاكل ما لا يمكن حصره... من عدم استقرارة الى المزامنة الى الغلق بقوة الى الرستارت ...الخ
ابحث عن روم مضمون تعمل عليه البرامج لأنه فعلا تعبت
قديم 02-09-2012, 12:27 AM   #21
zaid jaber
مشاركات الشكر: 65
المشاركة الأصلية كتبت بواسطة cloud s مشاهدة المشاركة
اخوي الروم مكتوب alpha يعني يوجد مشاكل لكن كاستخدام يومي انا بنصح به لانو البطارية رائعة كانت تقعد معي 3 ايام
اخوي بالتفصيل المهم اوك حاضرين:
1- الروم يركب على اي روم رسمي اي واحد
2- لازم تكون عامل للروم روت(عشان تقدر تنزل الروم من الريكفري )
3- ادخل الروم للميموري الخارجية مع البرامج (اللينك البرامج موجود تحت لينك الروم اختار برامج CM9)
4- ادخل على الريكفري اعمل الاتي:
. Reboot
وكذلك اصبح الروم جاهز
الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 12:27 AM ----------- المشاركة السابقة اضيفت في 12:23 AM ---------
المشاركة الأصلية كتبت بواسطة Jordanyme مشاهدة المشاركة
اخوي مثل ما حكالك اخونا جالكسي 9 واذا ما نفع احكيلي
قديم 02-09-2012, 12:31 AM   #22
Jordanyme
قصدك روم 2.3.4 ؟؟؟ ومشكلة التعليق والرستارت والمصيبة الاكبر مشكلة حذف الملفات وعمل فورمات لوحده ؟!
لو جربت هذي الروم ما رح تنفع ؟؟؟
قديم 02-09-2012, 12:37 AM   #23
zaid jaber
مشاركات الشكر: 65
يااااااااااااااااااا ااا اخوان نزل رووووووووووووووووووو ووووووم alpha 12 نزلو اول وااااااااااااااااااا احد
Alpha 12 - 09022012
Updated kernel to latest release by Samsung.
Sync Bug fix reworked (New Sources)
Front Camera Flip, Green Flickers (New Sources)
Bluetooth performance tweaks (New Sources)
Few patches from TI for bionic / gralloc to increase performance (untested).
Upstream Changes.
الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 12:37 AM ----------- المشاركة السابقة اضيفت في 12:34 AM ---------
اعطيني شو رومك شو نوعه من اي قارة ؟؟؟
قديم 02-09-2012, 12:42 AM   #24
Jordanyme
[/COLOR]
رديت عليكو وهيو بعمل بالروم 2.3.4 وقرب يخلص ... مع انه عارف هالروم رح تجنني
الروم الي قبل كانت اخر روم اصلي الي هو 2.3.6 kp3 او اشي زي هيك
قديم 02-09-2012, 01:08 AM   #25
zaid jaber
مشاركات الشكر: 65
طيب اعطيني اسمك على الفيس
او ايميل
للبيع, المكالمات, البطارية, الريكفري, الوايرلس, برامج, google, gps, جالكسي, kies, mac, رسمي, روم, روت, سامسونج, rom, samsung, unlock, usb
جميع الأوقات بتوقيت GMT +3. الساعة الآن 02:41 AM.
