قديم 12-05-2012, 09:20 AM   #1
مشاركات الشكر: 23
شكر 339 مرات في 198 مشاركات
i9100 آيس كريم سانديتش 4.0.4 نسخه (الجوال+التابلت) في روم واحده
اليوم حبيت أقدم لكم تجربتي لروم PARANOIDANDROID v0.4
This is an ongoing developer project to make way for a modification that will entirely transform your device, but retain the aesthetics and the experience of your phone. I know you've seen tablet mode roms before, they change two lines in your build.prop file which you could easily edit yourself in seconds and maybe throw a keyboard in there to make it work better. It's a start, but this ain't enough. This thing has potential, but it is wasted the moment you try to stuff a full blown tablet into your poor phone. Yet we all know our high res phones can very well handle more than silly 1-column layouts. So the magic must be in between somewhere, a place that Google must have overlooked and left blank. Yes, this rom strives to drop your device into tablet mode, but it won't stop there, it will reshape and redefine ICS to make it all a usefull addition and not just a cute novelty. we're calling it: Hybrid Mode, best of both worlds.
You're asking yourself how exactly does this rom differ from "tablet mode roms" then, here's a quick status report:
  • Tablet mode shrinks your apps into a tiny mush, this rom features a setting called Per-App-Density. You can define an apps native DPI with it, make it look stock, smaller or bigger than that, your decision. All apps are depicted at DPI 182 per standard. No other rom has that feature right now
It comes with a working launcher. That might sound strange to you, but launchers do not work in tablet mode, at least not as you'd expect them to work. They often show no docks, have shrunk icons, look cluttered, their appdrawers are cut-off, etc. This rom uses a Trebuchet fork which was optimized in source and layout to run in hybrid mode.
It has a working Market. Google Play does not allow density changes and will stop working if you mess around with that. This rom fixes that problem for you 100%.
Its comes with a working stock Keyboard. Tablet mode destroys the original Android keyboard normally, it has been recompiled from source with new layout applied.
More stuff: Recents window closer to stock, fixes for overlapping elements, framework fixes, no crashes, working Phone (looks 100% like stock aswell), etc.
طبعا بالمختصر الروم فيله ميزه تحوله لنسخه تابلت زي ما شفتوا في الصور فوق
وتســــتــــطيع بضغطه زر ترجــعه لنسخه الجوال بكل ســــــهـــــوله طبعا
يفضل اخذ بيك اب من الريكفري للروم الحــالي في حال رغبتك للــــــــــــــــعوده له ..
هذه بعض الصور من جهازي :
لكن لا يوجد شيء كامل
وحلها بإرجاع الجهاز إلى نسخه الجوال مثل الصوره التاليه ( شيل الصح عن تابلت مود )
وحيرجع للنسخه المعروفه ( نسخه الجوال )
طريقة التثبيت
مثل المعتاد عن طريق الريكفري
Install HYBRID Gapps:
هذه برامج جوجل الإضافيهhttp://BillionUploads.com/1vbis6ltsq4l
Wipe caches, factory reset is a must if you're coming from another rom than CM9
بعد ما تثبت الروم حتلاقيه نسخه الجوال لازم نسوي كم شي قبل ما نحولها لنسخه التابلت
Go to Settings, System, Font size, set it to NORMAL
Check "Auto Hide" in Settings, System, Statusbar, to finally get Fullscreen
هذا الخيار ما لقيته وراسلت المطور في موضوعه وما رد للآن على العموم اشتغل وضع التابلت عادي
Trebuchet Settings: margins:SMALL, show permanent searchbar:YES, Grid: 5x4, resize all widgets:YES, Wallpaper scrolling: OFF تلاقيها في خيارات اللانشر
وبعدها نفعل وضع التابلت بوضع صح كما في الصوره
ومبروك خلاص انتهينا يالله لا تبخلوا علينا بالردود وتجاربكم وأي إستفسارات انا حاضر
memomo غير متصل   رد مع اقتباس
عدد 17 من الاعضاء يشكرون memomo على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
اخر 5 مواضيع للعضو memomo
الروم العربي الرسمي 4.0.4 للـ Acro S من صنعي +... قسم ترقيات الأجهزة الأخرى بنظام Google Android zaiddd 9 3621 14-09-2012 07:57 PM
[طلب]ملف FTF بالتحديث الاخير بالـ FlashTool للـ... قسم ترقيات الأجهزة الأخرى بنظام Google Android memomo 39 2555 06-09-2012 07:57 PM
اشتغل igo على جهازي Xperia s لكن ليس بكامل الشاشة... قسم الملاحة وتحديد الموقع لاجهزة Google Android المقيطع 3 806 04-09-2012 08:57 AM
[Acro s ] فتح البوتلدر+ CWM + Root ريكفري + مودات... قسم ترقيات الأجهزة الأخرى بنظام Google Android kasim_k21 44 5194 30-08-2012 06:42 PM
اول روم على البناء الاوروبي الجديد [2.17] Android... قسم ترقيات أجهزة HTC بنظام Google Android التنـبل 18 2001 11-08-2012 05:08 PM
قديم 12-05-2012, 09:47 AM   #2
لينين
الصورة الرمزية لينين
مشاركات الشكر: 92,732
شكر 4,075 مرات في 2,486 مشاركات
مشكور اخي وترتيب جميل شكرا لك
لينين غير متصل   رد مع اقتباس
قديم 12-05-2012, 10:10 AM   #3
fromq8
الصورة الرمزية fromq8
مشاركات الشكر: 2,436
شكر 3,028 مرات في 1,077 مشاركات
لطالما تمنيت نسخة تابلت على هاتفي جالاكسي اس 2
بأذن الله سأحمله الان .
ولكن هل من مشاكل في الواليس او بلوتوث وغيره ؟
fromq8 غير متصل   رد مع اقتباس
قديم 12-05-2012, 12:08 PM   #4
memomo
مشاركات الشكر: 23
المشاركة الأصلية كتبت بواسطة fromq8 مشاهدة المشاركة
لا مشاكل نهائيا كل شي شغال 100% حتي الفيس انلوك
قديم 12-05-2012, 12:28 PM   #5
almutairi
الصورة الرمزية almutairi
شكر 73 مرات في 58 مشاركات
شي جميل
الله يعطيك العافيه
almutairi غير متصل   رد مع اقتباس
قديم 12-05-2012, 12:53 PM   #6
abuzar.786
الصورة الرمزية abuzar.786
مشاركات الشكر: 674
شكر 350 مرات في 150 مشاركات
يا الله !!!! وش هالإبدااااع
يا أخي أنت تجنني...
جاري التحمبل والتركيب
abuzar.786 غير متصل   رد مع اقتباس
قديم 12-05-2012, 01:22 PM   #7
hindawy
الصورة الرمزية hindawy
مشاركات الشكر: 515
شكر 1,148 مرات في 764 مشاركات
مشكوور اخوي مجهود رائع ويعطيك العافية
hindawy غير متصل   رد مع اقتباس
قديم 12-05-2012, 01:42 PM   #8
dream_576
شكر 60 مرات في 25 مشاركات
رابط برامج جوجل الإضافيه لايعمل
ارجو تعديل الرابط
dream_576 غير متصل   رد مع اقتباس
قديم 12-05-2012, 02:46 PM   #9
ZJT
الصورة الرمزية ZJT
مشاركات الشكر: 1,371
شكر 691 مرات في 219 مشاركات
المشاركة الأصلية كتبت بواسطة dream_576 مشاهدة المشاركة
ارجو تعديل الرابط
الرابط شغال 100 % ,,
ZJT غير متصل   رد مع اقتباس
قديم 12-05-2012, 03:10 PM   #10
memomo
مشاركات الشكر: 23
اخوي اليوم الصباح محمل برامج قوقل والرابط شغال
قديم 12-05-2012, 04:39 PM   #11
ZJT
الصورة الرمزية ZJT
عجزت ألقاها .. وينهي بالضبط موجودة ؟
قديم 12-05-2012, 05:01 PM   #12
fromq8
روم رائع على الرغم انه بيتا
وانتظر نسخة جديده على فارغ الصبر
ولكن نسخة التابلت تحتاج الى تحسين في اللمس
قديم 12-05-2012, 05:01 PM   #13
meeeeas
مشاركات الشكر: 616
شكر 1,497 مرات في 737 مشاركات
الله عجبني الروم جاري التحميل والتجربه اخي ودي اسالك على لعبه ريسدينت ايفل فور موجوده في الاندرويد ياويل قلبي تصد ق كنت العب كل اللعب هذه في البلاستيشن ولين اخذت الجوال دخلت في بحر الرومات الله ياخذها وعشت بحر بعدم الاستقرار ياليت طمني اذا كانت معك ياليت تعلمني ودي احملها الله يسعد قلبك وحياتك جاري التحميل والتجربه لروم وترك الانطباع ان شا ءء الله عن قريب
meeeeas غير متصل   رد مع اقتباس
قديم 12-05-2012, 05:21 PM   #14
memomo
مشاركات الشكر: 23
المشاركة الأصلية كتبت بواسطة ZJT مشاهدة المشاركة
اخوي لما تدخل الاعدادات تلاقي في ثلاث خيارات اللانشر والثيم والسستم
ابحث عن ما ينقصك بتمعن وستجدها اضنها في خيارات الانشر
المشاركة الأصلية كتبت بواسطة meeeeas مشاهدة المشاركة
ايوه اخوي الصور من جهازي واللعبه عندي بس المشكله لغتها كوري وبحثت عن نسخه انجليزيه ولم اجدها ياريت لو لقيتها ترسلي الرابط بالنسبه للكوريه خذلك لفه بقوقل تلاقيها بسهوله
قديم 12-05-2012, 06:05 PM   #15
badboy619
الصورة الرمزية badboy619
شكر 27 مرات في 18 مشاركات
اخى مشكور مقدما
ولكن ممكن رابط الموضوع الرسمى لمتابعه اخر الاخبار واراء الاعضاء والمطورين
badboy619 غير متصل   رد مع اقتباس
قديم 12-05-2012, 06:36 PM   #16
memomo
مشاركات الشكر: 23
تفضل هنا
العضو التالي يشكر memomo على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 12-05-2012, 07:23 PM   #17
ميرندا تفاح
مشاركات الشكر: 41
شكر 300 مرات في 133 مشاركات
أخوي بعض الرومات ما تشغل بعض الالعاب مثل فيفا 2012 وغيرها
هل هذي الروم مضبوطة من هالناحية؟؟
والبطارية كيفها؟؟
وهل الروم عربية القوائم؟؟
الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 07:23 PM ----------- المشاركة السابقة اضيفت في 07:16 PM ---------
وياليت ترفع برامج قوقل على رابط آخر لانه ما يفتح
ميرندا تفاح غير متصل   رد مع اقتباس
قديم 12-05-2012, 07:24 PM   #18
ZJT
الصورة الرمزية ZJT
أحد اشتغل عنده Google chrom ؟
لانه يرفض يشتغل !!
قديم 12-05-2012, 08:59 PM   #19
ميرندا تفاح
مشاركات الشكر: 41
خلاص ضبط الرابط
الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 08:59 PM ----------- المشاركة السابقة اضيفت في 07:26 PM ---------
فيه مشكلة بعض البرامج والالعاب اثبتها لكن معاد اقدر ادخل قائمة البرامج يعطي اغلاق بالقوة
قديم 12-05-2012, 09:26 PM   #20
alkamali5551212
مشاركات الشكر: 176
شكر 1,523 مرات في 890 مشاركات
هل تعاني من اختفاء كرت الزاكرة الخارجية ع رومات ICS تفضل الحل هنا
قديم 12-05-2012, 11:31 PM   #21
ZJT
الصورة الرمزية ZJT
المشاركة الأصلية كتبت بواسطة ميرندا تفاح مشاهدة المشاركة
خلاص ضبط الرابط
والحل للأسف إنك تحذفها ,,
الروم جداً رائع ،، لكن هالمشكلة هي اللي مخربته ,,
قديم 12-05-2012, 11:46 PM   #22
memomo
مشاركات الشكر: 23
بالفعل المشكلة كل الرومات المبنيه على الكود المصدري بها هذه المشكله مع الذاكره الـ sd
فأي برنامج ثبته على الذاكره الداخليه للجهاز وهذا الحل وإن شاء الله المطورين يجدوا لنا حل
الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 11:40 PM ----------- المشاركة السابقة اضيفت في 11:39 PM ---------
طبعا الأخ إلى جاله الإغلاق بقوه ولا قدر يحذف البرنامج مالك غير فيكتوري ريست من الريكفري ولا تثبت هذا البرنامج إلى سبب لك المشكلة
الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 11:41 PM ----------- المشاركة السابقة اضيفت في 11:40 PM ---------
لانه يرفض يشتغل !!
إيوه أشتغل معاي بالنسخه ذه وكل نسخ الآيس كريم بس الحروف العربيه مقطعه
الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 11:46 PM ----------- المشاركة السابقة اضيفت في 11:41 PM ---------
والبطارية كيفها؟؟
الروم عربيه نعم
وبها بعض المشاكل مع بعض الألعاب التي تتطلب ممري كارد خارجي للداتا وما شابه
حالها كحال كل الرومات المبنيه على السورس كود ( الكود المصدري )
البطارية لسع ما يمداني احكم عليها لكن غالبا حتكون جيده لأن الكيرنال صياح
قديم 13-05-2012, 12:24 AM   #23
طفش023
شكر 33 مرات في 31 مشاركات
بما اني مليت وانا انتظر الايسكريم للشرق الاوسط
بتوكل على الله وبركب هالروم
لكن انا ماعمري ركبت روم ولا شي
انا جاهزي اس تو بدون جي 2.3.5 ومركب روت وكيرنل صياح بس مو اخر نسخه
ابي الطريقه الصحيحه علشان اركب هالروم
وهل احتاج لفرومات والروم يمسح كل شي والا مايحتاجج اسوي بآك اب
وعندي استسفار البطاريه كم مده شحنها وكم مده بقائها ..
طفش023 غير متصل   رد مع اقتباس
قديم 13-05-2012, 12:39 AM   #24
magawa
الصورة الرمزية magawa
مشاركات الشكر: 1,106
شكر 2,709 مرات في 915 مشاركات
جربتها روم رائعه لكم في مشكلة وهقتني ..
كل ما افتح برنامج جهات الاتصال يجي android core فورس كلوز ... وهذي موجودة برومات ايس كريم كثيرة و جعلتني ابتعد عن الايس كريم و اثبت على الروم التركي جنجر بريد 37" من اول ما نزلت حتى الان على جهازي " ... روم مذهلة لكن انا احب التغيير .... لا أحد يسألني عن رابطها بعد اذنكم ...
magawa غير متصل   رد مع اقتباس
قديم 13-05-2012, 01:22 AM   #25
طفش023
هل يستاهل اركبه والا .؟
الريكفري, برامج, google, launcher, روم, قوقل
جميع الأوقات بتوقيت GMT +3. الساعة الآن 08:28 AM.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
