هذا الطباخ احسه مستعجل مرى مايخلي شي في الجهاز الا ويطيرة
حتى رومه الجديد اليوم اصدر اتوقع مع سرعته ماوضع اي صور عن الروم
ادعكم مع معلومات الروم
! 15MB PagePool size (patch available for 4MB/8MB/12MB/20MB).
! LZX compress.
- Remove most mp3 ring (only keep 'Cloudy Tone .mp3', because tclock use this one)
! No any default Today, just empty.
- Remove most theme (only keep Classic Blue) (provide cab files)
- Remove some non-used icons
- Remove .rgu files
- Remove sample music
- Remove sample picture
! Enable IME setting in Settings
! Change MinimumTapTime to 0
! Enable automatic backlight mode by default
! Disable touch vibration and sound by default
! Enable vibration for all notification by default
! Disable hardware buttons tone by default
! Wake up button set to Lock or Power by default
! Enable etiquette mode by default
! Enable front camera support by default
! Set HKCU\ControlPanel\PhoneNetSelMode\timeou t to 0 by default
! set HKLM\Software\Microsoft\SimContacts\Radi oEnableDelay to 0 by default
! Disbale SMS/MMS sent alert by default
! Enable unicode support for SMS by default
! Disable security warnning by default
! Disable error report function
! Enable screen rotate function
! Enable Microsoft Settings
! Set HKLM\Software\Microsoft\Shell\LowMem\Pro gramMem to 96
! XTRA enabled by default (ActiveSync and GPRS)
! GPS Baud set to 115200 by default
! Enable sound alarms even when the device is set to silent or vibrate
! change start menu to 4 rows grid (provide cab for restore to 3 rows grid)
! Assign Button 1 to Start Menu
! Assign Hold Button 1 to Task Manager
! Assign Button 2 to OK/Cancel
! Assign Hold Button 2 to Screen Rotate
- Remove all games (provide cab files, you can select the storage to install)
- Remove Auto rotation support (provide cab files, you can select the storage to install)
- Remove Adobe Reader LE (provide cab file, you can select the storage to install)
- Remove Audio Notes (Recorder) (provide cab file, you can select the storage to install)
- Remove CHome (provide cab file, install to \windows only)
- Remove Digital Frame (provide cab file, you can select the storage to install)
- Remove DMC (Connected Home) (provide cab file, you can select the storage to install)
- Remove Facebook (provide cab file, you can select the storage to install)
- Remove File Manager (My Files) (provide cab file, you can select the storage to install)
- Remove FM Radio (provide cab file, you can select the storage to install)
- Remove fwupdate
- Remove Google Map (You can get the new version from Google)
- Remove GPRSCounter (provide cab file, you can select the storage to install)
- Remove Help
- Remove i8000 book
- Remove JAVA (provide cab file, install to \windows\ only)
- Remove LockScreen (provide cab file, install to \windows\ only)
- Remove Midomi (provide cab file, you can select the storage to install)
- Remove MVE (Video Editor) (provide cab file, you can select the storage to install)
- Remove My Phone (Install Marketplace first, then install from Marketplace)
- Remove Opera (provide cab file, you can select the storage to install, or get new version from Opera website)
- Remove Office (provide cab file, you can select the storage to install)
- Remove OneNote (provide cab file, you can select the storage to install)
- Remove Photo Album (Photo) (provide cab file, you can select the storage to install)
- Remove PlayerAutoUpdate.exe (provide cab files, you can select the storage to install)
- Remove Podcast (provide cab file, you can select the storage to install)
- Remove PowerCalc (Calculator) (provide cab file, you can select the storage to install)
- Remove power on/off animated picture (provide cab file, install to \windows\ only)
- Remove power on/off sound (provide cab file, install to \windows\ only)
- Remove QiK (provide cab file, you can select the storage to install)
- Remove Remote Desktop Mobile (provide cab file, you can select the storage to install)
- Remove Rich Internet (provide cab file, install to \windows\ only)
- Remove RSS Reader (provide cab file, you can select the storage to install)
- Remove Samsung Apps (provide cab file, you can select the storage to install)
- Remove Samsung Today (provide cab file, install to \windows\ only)
- Remove Samsung WidgetPlus (provide cab file, install to \windows\ only)
- Remove SharePix (Communities) (provide cab file, you can select the storage to install)
- Remove Smart Converter (Unit Converter) (provide cab file, you can select the storage to install)
- Remove Smart Memo (Memo) (provide cab file, you can select the storage to install)
- Remove Smart Reader (provide cab file, you can select the storage to install)
- Remove Smart Search (provide cab file, you can select the storage to install)
- Remove Smart Sync (provide cab file, you can select the storage to install)
- Remove Streaming Player (ASPlayer) (provide cab file, you can select the storage to install)
- Remove SQM
- Remove Task Manager (Task Switcher) (provide cab file, install to \windows\ only)
- Remove Test Programs (provide cab file, install to \windows\ only)
- Remove Touch Calendar (Schedule) (provide cab file, you can select the storage to install)
- Remove Touch Clock (Clock) (provide cab file, you can select the storage to install)
- Remove Welcome Center
- Remove Windows Live (Install Marketplace first, then install from Marketplace)
- Remove Marketplace (get the new version from http://mp.windowsphone.com/ website)
- Remove Youtube (provide cab file, you can select the storage to install)
ملاحظات الطباخ:
1. Please use OCTANS Downloader 2.14 or later version
2. Photo Album (Photo), File Manager (My Files), SharePix (Communities) may be used by Camera, so install them if you need Camera.
3. You need to reboot the device after install FM Radio.
4. Execute 'Restore Connections' in 'Samsung Settings' if you can't use data link for 3.5G or via ActiveSync
5. You need to flash the official rom before flash lite rom if you want to use PowerDic (the files in my storage hidden partition).
لتحميل الروم
http://www.multiupload.com/WMUX3T6RSZ
http://www.multiupload.com/MFZKT70RW6
http://www.multiupload.com/EWTW2J4M3A
المصدر ولتحميل بقية البرامج
http://www.modaco.com/content/i8000-...lite-20100420/
ياليت احد الاخوان يرجع لصفحة الطبخة ممكن ا كون ناسي شي للاني ضعيف في للغة الانجلزية ولكن احاول ان ازودكم بكل جديد خاصة بعد غياب اخونا الهندسية
ااحترامي لكم
