النهاردة شفت اعلان التلفون الجديد من HTC
قمة في الروعة والجمال
Processor Qualcomm® ESM7206A™, 528 MHz Operating System Windows Mobile® 6.1 Professional Memory ROM: 256MB
RAM: RAM: 288MB
Flash: 8GB Dimensions 113.5 mm (L) X 63.1 mm (W) X 13.9 mm (T) Weight 151 g (with battery) Display 3.8-inch TFT-LCD flat touch-sensitive screen with WVGA (480 X 800) resolution Network Mobile WiMAX: IEEE 802.16e (2.5 ~ 2.7 GHz)
Tri-band GSM/GPRS/EDGE: 900/1800/1900 MHz
(Band frequency, data speed and WiMAX availability are operator dependent.) Device Control TouchFLO™ 3D GPS Internal GPS antenna Connectivity Wi-Fi®: IEEE 802.11 b/g
Bluetooth® 2.0 with Enhanced Data Rate and A2DP for stereo wireless headsets
HTC ExtUSB™ (11-pin mini-USB 2.0, audio jack, and TV Out* in one) Camera Main camera: 3.2 megapixel color camera with auto focus
Second camera: VGA CMOS color camera Ring tone
supported formats- AAC, AAC+, eAAC+, AMR-NB, AMR-WB, QCP, MP3, WMA, WAV
- 40 polyphonic and standard MIDI format 0 and 1 (SMF) / SP MIDI
Video Supported
formats WMV, ASF, MP4, 3GP, 3G2, M4V, AVI Battery Rechargeable Lithium-ion or Lithium-ion polymer battery
Capacity: 1500 mAh
Talk time:- Up to 420 minutes for GSM
- Up to 230 minutes for VoIP
Standby time:- Up to 350 hours for GSM
- Up to 50 hours for VoIP
(The above are subject to network and phone usage.) Expansion Slot microSD™ memory card (SD 2.0 compatible) AC Adapter Voltage range/frequency: 100 ~ 240V AC, 50/60Hz
DC output: 5V and 1A Special Features Voice and Video over IP
