قديم 29-06-2013, 06:14 PM   #1
الصورة الرمزية mh7
مشاركات الشكر: 4,198
شكر 17,108 مرات في 2,998 مشاركات
لجهاز HTC one روم Android Revolution HD 71.1 _ 4.4.2. Sen6
[ROM] Android Revolution HD 12.0 | 4.2.2 | High Quality & Performance | 2.19.401.1
Proudly presenting you the most popular ROM for HTC One...
رابط صورة كبيرة الحجم (2387 kB)
الروم للطباخ المخضرم "mike1986." وروماته تمتاز بالمحافظة علي نكهة الروم الخام مع التعديلات التي ترفع من كفائة الأداء وتوفير استهلاك البطارية
قبل تحميل الروم يجب أن يكون جهاز مفكوك الحماية
يرجي قرأءة هذا الموضوع لفك الحماية
http://www.ce4arab.com/vb7/showthrea...03#post4237203
محتويات الروم
كود:
Removed software (CPU) rendering - full Snapdragon 600 (GPU) rendering
Fully optimized and tweaked
Root access
Unsecured boot.img
Newest BusyBox
RAM optimizations
System signatures check enabled for system security and safety
Improved virtual memory management
Speed optimizations
Enabled GPU UI rendering
Data, cache and system partitions mounting tweaks
Bloatware applications removed
All /system applications updated to latest available
All /data applications updated to latest available
Improved CPU governors performance
Most optimal system scheduler
Disabled kernel debugging for better performance
Zipaligned (Improved RAM management)
Zipalign on boot (for user applications on data partition)
Fully de-odexed
init.d scripts (BusyBox run-parts) support
Auto init.d permissions set on boot
sysro/sysrw commands support
Excellent battery life!
Improved EXT4 performance
OpenVPN support
Most up-to-date system files permissions
Adobe Flash Player support
Support almost 24h a day
...and many more!
جديد الإصدار Android Revolution HD 11.0
كود:
There is no need to flash latest hboot!
Better not to flash any custom kernel
Based on latest HTC One 2.19.401.1 (WWE) firmware that includes:
- Android 4.2.2
- Improved BlinkFeed
- Stock HTC %battery
- Stock HTC EQS
- Long press home button works as menu
- Possibility to remove all icons from the dock
- Icons doesn't disappear from the app drawer even if added to the dock
- Audio improvements
- Camera improvement
- Thermal configuration improvements
- Much more!
Improved AROMA installer
Other minor changes and fixes
Included and updated components:
لتحميل الروم
http://www.androidrevolution.nl/down...0.zip"]Android
لتحميل 2.24.401.1 -Android Revolution HD 12.0 _ 4.2.2
Android Revolution HD - Mirror Site
Android Revolution HD 12.1 | 4.2.2 | High Quality & Perform
Android Revolution HD 12.2 | 4.2.2
الكمبيوتر الكفي - عرض مشاركة واحدة - لجهاز HTC one روم Android Revolution HD 12.1 _ 4.2.2 البناء
Android Revolution HD 12.3 | 4.2.2 | High Quality & Performance |
الكمبيوتر الكفي - عرض مشاركة واحدة - لجهاز HTC one روم Android Revolution HD 12.2 _ 4.2.2 البناء
Revolution HD 13.3 | High Quality & Performance | Android 4.2.2 Jelly Bean | 2.24.401.8 | One ToolBox
الكمبيوتر الكفي - عرض مشاركة واحدة - لجهاز HTC one روم Android Revolution HD 12.3 _ 4.2.2 البناء
سلسة رومات 4.3
[ROM] Android Revolution HD 20.0 | High Quality & Performance | Android 4.3 Jelly Bean | 3.09.401.1 | Sense 5 Toolbox
الكمبيوتر الكفي - عرض مشاركة واحدة - لجهاز HTC one روم Android Revolution HD 13.3 _ 4.2.2
Android Revolution HD 40.2 رومات الكت كات 4.4
HD 40.2 ONLINE | High Quality & Performance | Android 4.4 KitKat | HTC Sense 5.5 | 4.06.1540.2 | Sense 5 Toolbox 2.5 | Sprint Support | T-Mobile
الكمبيوتر الكفي - عرض مشاركة واحدة - لجهاز HTC one روم Android Revolution HD 20 _ 4.3.
Android Revolution HD 51.0 4.4
Android Revolution HD 51.0 | High Quality & Performance | Android 4.4.2 KitKat | HTC Sense 5.5 | 4.19.401.8 | Sense 5 Toolbox 2.7.1 | Sprint Support | T-Mobile Wi-Fi Calling
الكمبيوتر الكفي - عرض مشاركة واحدة - لجهاز HTC one روم Android Revolution HD 40 _ 4.4.
[ROM] Android Revolution HD 71.1 | High Quality & Performance | Android 4.4.2 KitKat | Official HTC Sense 6.0 | 5.11.401.10 | Tweaks app - Sense 6 Toolbox 1.2 | Sprint Support | T-Mobile Wi-Fi Calling
http://www.ce4arab.com/vb7/showpost....2&postcount=67
لتعديل مؤشر البطارية ليحوي النسبة المئوية
Battery"]- بطاريه بالون العادي الأخضر مع المؤشر
Battery1Blue_422.zip"]- بطارية باللون الزرق مع المؤشر
يوجد أيضا شكل المؤشر الدائري
Circle: http://d-h.st/6pe
Sense: http://d-h.st/Rxn
أيضا
Transparent:
Sense w/ Blue Signal Bars, new WiFi & Alarm: http://d-h.st/siW
Sense w/ Red Signal Bars, new WiFi & Alarm: http://d-h.st/02X
Circle w/ Blue Signal Bars, new WiFi & Alarm: http://d-h.st/32b
Black Bar:
Sense w/ Blue Signal Bars, new WiFi & Alarm: http://d-h.st/d5j
Sense w/ Red Signal Bars, new WiFi & Alarm: http://d-h.st/419
Circle w/ Blue Signal Bars, new WiFi & Alarm: http://d-h.st/hm3
Back to Stock: http://d-h.st/DWo
من أراد تحميل الريديو الأخير
4A.16.3250.24_10.38.1150.03L
RadioUpdate10.38.1150.03.zip | by he_stheone64 for One
إضافة خيارات لزر الإغلاق
Dropbox - HTC_One_APM_For_4.2.2_v4.zip
لمن أراد تحميل كيرنيل لتفعيل شعار HTC وخاصية Sweep2Wake
ElementalX 2.2
Goo.im Downloads - Downloading ElementalX-m7-2.2.zip
مميزاته
كود:
•Aroma installer
•optimized for extended battery life
•overclocking/underclocking options
•select independent frequencies for each core
•user voltage control
•optional GPU overclocking
•choose undervolting levels
•kernel based thermal control
•thermal options
•sweep2wake
•doubletap2wake
•logo2wake
•pocket detection
•logo2menu
•button light notification
•/system writable
•init.d support
•force fastcharge
•NTFS r/w support
•CIFS support
•OTG support
•support more game controllers (including PS3)
•maintains compatibility with all paid apps
•increased refresh rate for HDMI output via MHL adapter
•optimized -O3 linaro 4.7.3
كيرنيل أخر teaMSeven-2.1.2
http://d-h.st/Q3W
مميزاته
كود:
Features
- No accidental touch events when in-call on ear-piece screen off by proximity (on stock 4.2.2 kernel this happens, you can touch the buttons accidentally with your ear while screen is off)
- Different Wake options (Home2Wake, Logo2Wake, Sweep2Wake)
 - Pocket Wake Protection (prevents phone from waking accidentally in your pocket, when it contacts skin through textile)
 - Logo2Menu, Logo2Sleep options
 - CIFS, NTFS-RW
 - Button light notification (only with screen off, if not on charging light, or screen on)
 - all OTG devices (except ps3 controllers, sisaxis, as the stack of htc is not compatible with that, afaik)
 - system write protection disabled in kernel
 - cpu freq stats enabled
 - Undervolting control enabled (as an exception for tweaks in the Stable Edition, because it's not risky if you don't actively undervolt in a tweak app)
 - sound control (thanks @faux123)
 - additional TCP congestion variants (use Trickster Mod or other app to set it)
Performance Edition additional features:
 - Hotplug control (MPDecision removed from ramdisk) - use tweak app to control it. Advice: http://forum.xda-developers.com/show...&postcount=925
 - undervolting control
 - force usb fastcharge possibility
 - overclockable (CPU)
 - underclockable
 - additional Governors (interacitve, smartmax) - tbalden's recommendation: with stable edition: OnDemand / perf edition: msm-dcvs
 - additional io schedulers (fiops, row, bfq)
 - GPU overclocked 450mhz
لم أجرب أي منهما حتي الأن
إذا أردت العودة لكيرنيل الروم الأصلي
Dropbox - StockKernel-signed.zip
الحجم كبير نسبيا
إذا اردت معرفت طريقة التعديل علي أيكونات الإعدادات السريعة
تابع هذا الموضوع
~~~ لجهاز HTC one طريقة التعديل علي أيكونات الإعدادات السريعة ~~~
لتحسين أداء بطارية جهازك راجع هذا الموضوع
طريقة معايرة بطارية HTC one لمن يشتكي من أداء بطاريته
mh7 غير متصل   رد مع اقتباس
عدد 11 من الاعضاء يشكرون mh7 على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
اخر 5 مواضيع للعضو mh7
أخبار عن نية Google شراء شركة HTC منتدى الأخبار mh7 25 2895 08-09-2017 10:34 PM
جوجل تضيق الخناق على الأجهزة التي تحمل صلاحيات... منتدى الأخبار hassanajdahim 37 4245 21-05-2017 11:39 AM
جوجل تحصل على براءة اختراع Drag & drop لنقل... منتدى الأخبار العتيد الشمري 3 1742 28-04-2017 12:01 PM
تسريب لصورة جهاز OnePlus 5 وبعض مواصفاته منتدى الأخبار kkhmasri 26 3534 26-04-2017 08:42 AM
بدأ التحديث الهوائي لـ Android wear 2 لساعات LG منتدى الأخبار ffffff 8 2306 07-04-2017 12:37 PM
قديم 29-06-2013, 09:00 PM   #2
zoalla
مشاركات الشكر: 27
شكر 31 مرات في 20 مشاركات
شكرا للاضافة الروم رائع جدااا وانا اعمل علية حاليا
سؤال هل جربت البطارية بالمؤشر على هذا الروم ؟؟
zoalla غير متصل   رد مع اقتباس
العضو التالي يشكر zoalla على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 29-06-2013, 09:46 PM   #3
Mohamad Serwan
الصورة الرمزية Mohamad Serwan
مشاركات الشكر: 1,892
شكر 1,258 مرات في 619 مشاركات
شكرأ لك
Mohamad Serwan غير متصل   رد مع اقتباس
العضو التالي يشكر Mohamad Serwan على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 29-06-2013, 10:45 PM   #4
mh7
الصورة الرمزية mh7
نعم اخي جربتها بالطبع. والملف صالح لهذه النسخه بعد تجربات فاشله كثير
مرفق صوره من جهازي
5ameneta
Sent from my HTC One using Tapatalk 2
عدد 2 من الاعضاء يشكرون mh7 على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 29-06-2013, 11:43 PM   #5
sayyas
الصورة الرمزية sayyas
مشاركات الشكر: 354
شكر 304 مرات في 146 مشاركات
انا من محبيين رومات Revolution ... فغلا رائعة .. شكرا ع مجهوداتك ...
sayyas غير متصل   رد مع اقتباس
العضو التالي يشكر sayyas على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 30-06-2013, 02:02 AM   #6
zoalla
مشاركات الشكر: 27
مرفق صوره من جهازي
http://img.tapatalk.com/d/13/06/30/5ameneta.jpg
بسبب التجارب الفاشلة انا سالتك لانى جربت مرة وفشلت واضطريت انى اعيد تنزيل الروم مرة اخرى
شكرا لك مرة اخرى
الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 02:02 AM ----------- المشاركة السابقة اضيفت في 01:21 AM ---------
تم التجربة وتعمل بنجااااااااااااااااح مشكووووووووووووووووو وووووووووور للمرة الثالثة وجزاك الله خير
قديم 30-06-2013, 02:50 AM   #7
اليافعي المطري
الصورة الرمزية اليافعي المطري
شكر 71 مرات في 43 مشاركات
اخواني الاعزاء الرابط لايعمل
تم الإرسال من جهازي HTC One بواسطة تاباتوك 2
اليافعي المطري غير متصل   رد مع اقتباس
قديم 30-06-2013, 03:02 AM   #8
mh7
الصورة الرمزية mh7
لمن أراد تحميل الريديو الأخير
العضو التالي يشكر mh7 على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 30-06-2013, 03:47 AM   #9
Formance
شكر 29 مرات في 15 مشاركات
ماالفائدة من تحديث الراديو أخي؟؟
Formance غير متصل   رد مع اقتباس
قديم 30-06-2013, 02:00 PM   #10
mh7
الصورة الرمزية mh7
المشاركة الأصلية كتبت بواسطة Formance مشاهدة المشاركة
الريديو هو المسؤول عن الإتصال بجهازك
وكفاءة الريديو تزيد من كفاءة الإتصال والواي فاي والجبي اس ...الخ
وايضا لها أثر على استهلاك البطارية بالتالي
الريديو كفاءته نسبيه ... فهي تختلف من بلد لآخر ومن شركة إتصالات لأخرى
يمكنك تجربة إصدارات مختلفة لتحديد أيهم أنسب وافضل لك في الأداء
قديم 30-06-2013, 04:10 PM   #11
zoalla
مشاركات الشكر: 27
اخى انا اصدار الراديو عندى مختلف وهو : 4A.14.3250.13
هل له تحديث ؟؟؟ وهل ضورورى لانى لا زلت على S-ON وطبعا لازم اكون S-OFF حتى استطيع تحديث الراديو
قديم 30-06-2013, 06:53 PM   #12
doooode
مشاركات الشكر: 88
شكر 90 مرات في 42 مشاركات
اخي ممكن طريقة تركيب الراديو ؟ ومن اين استطيع الحصول على اصدارات الراديو ؟
doooode غير متصل   رد مع اقتباس
قديم 01-07-2013, 11:55 AM   #13
mh7
الصورة الرمزية mh7
الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 10:49 AM ----------- المشاركة السابقة اضيفت في 10:43 AM ---------
المشاركة الأصلية كتبت بواسطة doooode مشاهدة المشاركة
يمكنك متابعة إصدارات الريديو من هذا الموضوع
http://forum.xda-developers.com/show....php?t=2342544
الطريقة حمله مثل الروم تماما
الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 10:55 AM ----------- المشاركة السابقة اضيفت في 10:49 AM ---------
المشاركة الأصلية كتبت بواسطة zoalla مشاهدة المشاركة
أنصحك أن تكون على S-off
ويوجد طريقة لتحميل الريديو في s-on عن طريق أوامر cmd لـلـ fastboot
يجب أن يكون ملف الريديو على روت الذاكرة
الأوامر
adb shell
dd if=/dev/block/mmcblk0p31 of=/sdcard/radio_firmware.img
قديم 01-07-2013, 07:24 PM   #14
doooode
مشاركات الشكر: 88
اخ mh7 هل يوجد برنامج أوديين للHTC مثل السامسونق؟؟
قديم 02-07-2013, 12:47 AM   #15
mh7
الصورة الرمزية mh7
ElementalX 2.2
مميزاته
كود:
•Aroma installer
•thermal options
•sweep2wake
•doubletap2wake
•logo2wake
•pocket detection
•logo2menu
•/system writable
•init.d support
•force fastcharge
•NTFS r/w support
•CIFS support
•OTG support
http://d-h.st/Q3W
مميزاته
كود:
Features
 - CIFS, NTFS-RW
 - underclockable
الحجم كبير نسبيا
الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 11:47 PM ----------- المشاركة السابقة اضيفت في 11:43 PM ---------
أودين خاص بسامسونج ... رومات HTC هي RUU وتقوم بالتحميل التلقائي والتعرف على الجهاز
قديم 02-07-2013, 11:06 PM   #16
viaccess
مشاركات الشكر: 162
شكر 84 مرات في 56 مشاركات
للاسف فتحت البوتلودر وعملت روت للجهاز وحملت الروم السئ والمستهلك للبطارية viperone . تحديث 4.2.2
كيف ارجع الجهاز زى الاول على النسخة 4.1.2
هل من الممكن الرجوع من تحديث اعلى الى تحديث اقل؟؟
viaccess غير متصل   رد مع اقتباس
قديم 03-07-2013, 12:37 PM   #17
mh7
الصورة الرمزية mh7
المشاركة الأصلية كتبت بواسطة viaccess مشاهدة المشاركة
الموضوع خاص برومات Revolution
وهي روم جيدة جدا للتجربة
أما سؤال بخصوص كيفية العودة للروم الأصلي يرجي طرحه في موضوعات فك الحماية
قديم 03-07-2013, 03:06 PM   #18
mh7
الصورة الرمزية mh7
Android Revolution HD 11.5
Android Revolution HD 11.5 | 4.2.2 | High Quality & Performance | 2.24 official
الروم للبناء 2.24.401 ولكن المسحوب من تسريبات البناء 709 وتعديلها الى 401
وسيتم اصدار الروم Android Revolution HD 12 خلال أيام بعد اعداد الطبخ لها على البناء الرسمي الأخير
Based on latest HTC One 2.24.709.1 (WWE) firmware that includes:
- Android 4.2.2
- Stock HTC EQS
- Lock-screen widgets
- Much more!Re-based from 709 to 401 (Thanks baadnewz for the system dump)
رابط الروم
http://www.androidrevolution.nl/down...D-One_11.5.zip
قديم 03-07-2013, 08:05 PM   #19
BJM
الصورة الرمزية BJM
مشاركات الشكر: 901
شكر 1,963 مرات في 823 مشاركات
النسخه الاخيرة لايوجد فيها خيار lte النسخه السابقه افضل
بانتظار النسخه الاصليه تم تركيب سوبر سيد لاتمكن من تركيب اي نسخه لاي بلد انصح الجميع بعملها
BJM غير متصل   رد مع اقتباس
العضو التالي يشكر BJM على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 03-07-2013, 09:27 PM   #20
mh7
الصورة الرمزية mh7
بناء النسخه 11.5 مبني علي. GSM للاسف
لكن لا زال يمكنك استخدام الشبكة 4جي
عن طريق
4636
ومن ثم غير الشبكة
صورة من جهازي علي شبكة 4جي
gezenysy
قديم 06-07-2013, 04:01 AM   #21
mh7
الصورة الرمزية mh7
بتاريخ اليوم الًدار الجديد
Android Revolution HD 12.0 | 4.2.2 | 2.24.401.1
الإصدار للبناء الرسمي الأخير 2.24.401.1
ينصح بتحميل ال firmware 2.24.401.1 قبل أو بعد الروم للحصول علي أفضل أداء
لأن الروم لا تحوي الفيم ورك
رابط التحميل
لمعرفة طريقة تحميل الفيرمورك تجدها بهذا الموضوع
رابط تحميل الروم
http://www.androidrevolution.nl/down...D-One_12.0.zip
قديم 06-07-2013, 05:00 AM   #22
BJM
الصورة الرمزية BJM
مشاركات الشكر: 901
مليون شكر لك يا استاذنا مجهود تشكر عليه
لكن مانزل الروم الاخير بصيغة ruu ???
قديم 07-07-2013, 05:09 AM   #23
NeRe 4 EvEr
الصورة الرمزية NeRe 4 EvEr
مشاركات الشكر: 2,850
شكر 1,221 مرات في 561 مشاركات
تسلم يا سيدي
الله يعطيك العافية
NeRe 4 EvEr غير متصل   رد مع اقتباس
قديم 07-07-2013, 04:36 PM   #24
BJM
الصورة الرمزية BJM
مشاركات الشكر: 901
الاصدار الاخير من الروم ممتاز جدا جدا واداء البطاريه جبار جدا
مع اني ماحب الرومات المعدلة لكن اقتعنت بهذا الروم
قديم 07-07-2013, 08:00 PM   #25
Dark_man28
الصورة الرمزية Dark_man28
مشاركات الشكر: 194
شكر 56 مرات في 48 مشاركات
اخوي Mh7 لو امكن التواصل معك لانني لا اعرف شيئا عن HTC صراحه
Dark_man28 غير متصل   رد مع اقتباس
android, مفكوك الحماية, bluetooth, book, البطارية, dropbox, تحميل, تركيب, fastboot, firmware, google, htc, htc one, روم, روت, rom, ruu, s-off, s-on, usb, wi-fi, youtube
جميع الأوقات بتوقيت GMT +3. الساعة الآن 05:01 AM.
