قديم 29-03-2013, 06:30 PM   #1
الصورة الرمزية deyaaa
مشاركات الشكر: 33
شكر 447 مرات في 148 مشاركات
للجالكسي س2 روم[AllianceROM][V7.02][15.03]
للجالكسي س2 (i9100) فقط الروم الرائع
مميزات الروم
6 اقفال للشاشة
jb
xperia z
galaxy s3
acer
lg
black berry
+القفل المائي
+القفل الحبري
+تسجيل المكالمات
+تغيير الوان البطارية وقوة الاشارة والششاعة وشكل البطارية ومتوى الشفافية للبار العلوي
+امكانية اضافة toggle وتغيير مكانها كيف ما تحب
+تغيير لونها
+تسجيل المكالمات
+alliance ota
+والكثر
+الملتي ويندوز
v7.02
Get it from ota updates after flashing 7.01
Fix for ota settings access
Fix for custom settings rotation fc
Choose any color/transparency for toggle bg
Choose any color/transparency brightness slider bg
Option to use toggle bg image or color
Phone theme color (for powermenu and more stuff as I add it)
Xperia z lockscreen - thanks to Arsaw
Choose any color settings/clear button (aosp theme only)
v7.01
Moved to XWLSD Base
Fixed Birthday FC in contacts
Fixed Pattern/Pin lockscreen getting landscape layour in portrait making it impossible to unlock
Darkened shade on bb lockscreen
Added color option for text (clock, date etc) for bb, optimus, acer, pattern, pin, jb lockscreens
Fixed scrollable home wallpaper
Added button to restart launcher after toggling
Fixed Edge zoom toggle (big thanks to Hawkerpaul and trevfee for sorting it out without me having to do anything)
Added button to restart browser after toggling
Changed brightness slider to white to fit with any color theme
Changed dropdown pressed handle to white to fit with any color theme
Added AOSP transparent theme in OTA
Added stock transparent theme in OTA
Added Hawkerpauls colored AOSP data icons to OTA visuals (flash after rom while on TWRP kernel)
v6.1
Official JB LS8
Deodexed, rooted, zipaligned
Ficetos TWRP kernel (you can change to what you like after install)
Crussaders awesome JB Reloaded theme
Alliance ROM Customizer with root browser from ficeto
AllianceOTA
Alliance Control
6 Lockscreens - Ripple, Circle, Jellybean, Blackberry 10, Acer, LG Optimus
Set color of Blackberry Dropdown, Optimus Background and Acer Background
21 optional and orderable dropdown toggles including multiwindow, smart stay etc
Choose 3, 4, 5 or 6 toggles on screen at once
4 Lockscreen Shortcuts on Ripple
5 battery options from aokp (stock, text only, text centered, text offset, none)
Choose ANY color for battery
Choose ANY color battery text
Choose ANY color charging text (Text only battery)
Choose ANY color low battery text (Text only battery)
Choose ANY color signal icons
Choose ANY color wifi icons
Information Ticker on Ripple
Ripple Toggle
Ink toggle
Choose ANY INK COLOR!!!!
Choose ANY color Toggles
Choose ANY color Toggle Text
Toggle Text On/Off
Toggle Indicator On/Off
Choose ANY color statusbar (Thanks Legendk95 for help)
Choose ANY transparency level for statusbar
Choose ANY color for dropdown background
Choose ANY transparency for dropdown background
Choose ANY color statusbar clock
Choose ANY color dropdown clock
Choose ANY color date
Choose Centre/Right/No clock (Thanks AOKP)
Add small/large AM/PM to statusbar clock (Thanks AOKP)
Add small/large day of week to statusbar clock (Thanks AOKP)
Brightness slider On/Off
5 icon JB lockscreen (added phone and mms) (Thanks atl4ntis)
Toggle for CRT with fix for waking with power *thx sorg
Toggle to move contact pic to left side (default is right)
Toggle for Browser Edge Zoom
Optional Screenshot on power menu
Restart UI button in custom settings (No more hotboots to change statusbar or noti panel color!!) *thx ficeto
SMS to MMS Auto convert - 250
Recipient limit - 400
Hide options for:
Statusbar alarm
Statusbar Bluetooth
Statusbar Sound
Toggle options for:
Low Battery Popup
Full Charge Notification
USB Connect Sound
Lock Screen Torch
Long Press Skip Track
Popup Browser
Long Press back to kill
Disabled Scrolling Cache
Smartstay
Unplug wont wake
Scrolling wall toggle
4 way reboot
Modded Camera from jobnik
Build prop tweaks for touch and smoothness
Multiwindow with edit apps
4 way rotation
Lockscreen set to 2 way rotation only
Call recording
Non increasing ring toggle *thx mythrandyr
Call end delay setting *thx mythrandyr
No home button lag with double tap intact and no longer goes to default home screen *thx mirko
V5.2
Big thanks to ficeto and Legendk95 for their help
Dorimanx 7.38 (Thanks dorimanx)
Rooted, deodexed and zipaligned
AllianceOTA
Alliance Control
20 optional and orderable dropdown toggles including multiwindow, smart stay etc
Ripple Toggle
Toggle Text On/Off
Toggle for CRT
Toggle for scrollable TW Home wallpaper
Media Scanner fix (Thanks Shoman)
Fixed Reboot options in Toggles
Added rest of JB reloaded theme (Thanks Crussader - will msg you the Toggles fix)
Hide options for:
Statusbar alarm
Statusbar Bluetooth
Statusbar Sound
Toggle options for:
Low Battery Popup
USB Connect Sound
Lock Screen Torch
Popup Browser
Smartstay
Unplug wont wake
4 way reboot
4 way rotation
Call recording
Themed Framework
Themed Dialer
Themed Contacts
Themed Settings
Themed multiwindow bar
Themed Dropdown
And im sure more....errr....cant remember
V5.1
Fixes for disappearing data icons, locksceen settings fc, lockscreen freeze and more
2 new ink....Ectoplasm and Tango!! :P
Themeable battery switch in aliance control. Once activated can be themed via ota visual mods. There are more than 30 styles to choose.
NOTE - I FORGOT TO CHANGE BUILD PROP SO WILL STILL SHOW V5!! DOH!
V5
Based on samsung JB Leak XXLSJ
Modem XXLS6
Kernel - Philz safe kernel. THERE IS NO SIYAH OR DORI FOR SAMMY JB. DONT ASK FOR IT!!!
AllianceOTA
Alliance Control
13 ink effect choices on Ripple lock - None, Pink,Orange,Green,Blue,Navy,Purple,Brown ,Light
Blue,Black,Bright Red,Yellow,Dark Red
Ripple Toggle
Hide options for:
Statusbar Clock
Statusbar alarm
Statusbar Bluetooth
Statusbar Sound
Toggle options for:
Low Battery Popup
USB Connect Sound
Lock Screen Torch
Popup Browser
Smartstay
Unplug wont wake
4 way reboot
4 way rotation
Call recording
Themed Framework
Themed Dialer
Themed Contacts
Themed Settings
Themed Dropdown
فيديو للروم :
صورة متحركة ط
http://makeagif.com/media/2-12-2013/PTiAXV.gifالتصيب :
قم بالدخول للريكفري مود
1_wibe cach/data factory reset
2_wibe partition
3_install zip
4_اختار الروم
5_قم بمسح برنامج rom customize
6_نزله من هنا ROM Customizer - Android Apps on Google Play
7_قم بالدخول للبرنامج واختار اول خيار ota
8_قم بالدخول للupdate
9_اختار 7.02_aosp_theme_only مساحته 90 او اكثر بقليل
10 :قم بالتحميل وفلشه بالبرنامج بدون wibe cach\data factory reset
للتحميل :http://d-h.st/KYC (v7.01
deyaaa غير متصل   رد مع اقتباس
عدد 8 من الاعضاء يشكرون deyaaa على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
اخر 5 مواضيع للعضو deyaaa
اخر اصدار للواتس اب منتدى Google Android للبرامج deyaaa 0 498 05-10-2014 11:44 PM
نسخة الاندرويد 4.3] الخام للجالكسي س4 I9505 قسم ترقيات أجهزة Samsung بنظام Google Android مهند الكاتب 23 4834 28-06-2013 02:12 PM
ظهور اول جهاز سامسونج بنظام TIZEN منتدى الأخبار الشيخ عمر 18 3891 23-05-2013 09:46 PM
اشاعة:جالكسي نوت 3 بشاشة 5.99 انش,ثماني... منتدى الأخبار abc111 32 3804 28-04-2013 05:02 PM
[شرح][للمبتدئين]صنع ثيم خاص بك/لرومك/لطرحه منتدى Google Android للبرامج deyaaa 14 3195 27-04-2013 12:31 AM
قديم 29-03-2013, 09:18 PM   #2
بــــرق
الصورة الرمزية بــــرق
مشاركات الشكر: 46
شكر 156 مرات في 108 مشاركات
ااخي كيف الاستقرار واداء الروم وكيف البطاريه
و افيني بالتفاصيل يالغالي
بــــرق غير متصل   رد مع اقتباس
العضو التالي يشكر بــــرق على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 29-03-2013, 09:51 PM   #3
Wolf_07
كيف اداء البطارية وهل يدعم اللغه العربية
Wolf_07 غير متصل   رد مع اقتباس
قديم 29-03-2013, 10:02 PM   #4
deyaaa
مشاركات الشكر: 33
طبعا يحتوي العربية مبني على xwlsd
البطارية جيدة جدا
وخاصة مع كرنل صياح من alliance ota
الروم رائع بمعنى الكلمة
ويمكنكم الرجوع للثيم الاصلي عن طريق alliance ota
Sent from my GT-I9100 using Tapatalk 2
الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 11:02 PM ----------- المشاركة السابقة اضيفت في 11:00 PM ---------
نعم مستقر لكن اتبعوا طريقة التنصيب
قديم 29-03-2013, 10:04 PM   #5
Wolf_07
شكرا deyaaa على الموضوع الأكثر من رائع
قديم 29-03-2013, 11:52 PM   #6
Andrgelx
الصورة الرمزية Andrgelx
مشاركات الشكر: 7,491
شكر 7,589 مرات في 1,841 مشاركات
اخي الكريم اريد ان اسالك هل قمت بتجربه روم PAC ادا نعم فياليت تخبرني الافضل بينهم ؟
Andrgelx غير متصل   رد مع اقتباس
العضو التالي يشكر Andrgelx على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 30-03-2013, 12:43 AM   #7
deyaaa
مشاركات الشكر: 33
المشاركة الأصلية كتبت بواسطة Andrgelx مشاهدة المشاركة
لم اجربه
بس ميزة هذا الروم لاداعي لتفليش المودات
مع احترامي لمطورين المنتدى
لكن روماتهم لتغيير لون الtoggle تحتاج للتفليش عن طريق الريكفري
اما هذا الروم لاداعي التغيير فوري
قديم 30-03-2013, 12:48 AM   #8
بــــرق
مشاركات الشكر: 46
ياخي الكريم وين رابط التحميل V7.02
اللي انت وضعته رابط V7.01
قديم 30-03-2013, 02:30 AM   #9
Ahmad-6
مشاركات الشكر: 132
شكر 109 مرات في 63 مشاركات
المشاركة الأصلية كتبت بواسطة بــــرق مشاهدة المشاركة
7.2 عباره عن تحديث تحدثه من برنامج rom coustmize
يعني اول شيء تفلش النسخة 7.1 بعدين تسوي ابديت للنسخة 7.2 من نفس الروم
Ahmad-6 غير متصل   رد مع اقتباس
قديم 30-03-2013, 05:43 AM   #10
بــــرق
مشاركات الشكر: 46
المشاركة الأصلية كتبت بواسطة Ahmad-6 مشاهدة المشاركة
شكرآ لك اخي العزيز تم التحديث
قديم 31-03-2013, 04:52 AM   #11
abse99
الصورة الرمزية abse99
مشاركات الشكر: 71
شكر 219 مرات في 77 مشاركات
اللَّـَـَـَـْـْہ يَـــ ؏ـ'ــــطْيّگ آأإلعّ'ــــافُيــہ .. ‏​
ع المجهود الرائع
جاري التجربه
abse99 غير متصل   رد مع اقتباس
قديم 31-03-2013, 03:05 PM   #12
7AMADA2211
الصورة الرمزية 7AMADA2211
مشاركات الشكر: 157
شكر 192 مرات في 93 مشاركات
انا احب هذا المطور والروم رائع مع كيرنل صياح
وايضا انا منصب روم لنفس المطور على النوت2 وهي ايضا رائعة
7AMADA2211 غير متصل   رد مع اقتباس
قديم 31-03-2013, 04:34 PM   #13
deyaaa
مشاركات الشكر: 33
المشاركة الأصلية كتبت بواسطة abse99 مشاهدة المشاركة
ع المجهود الرائع
جاري التجربه
الله يعافيك
وأي سؤال انا موجود
الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 05:34 PM ----------- المشاركة السابقة اضيفت في 05:33 PM ---------
المشاركة الأصلية كتبت بواسطة 7AMADA2211 مشاهدة المشاركة
فعﻻ انا مركب معه كرنل صياح
قديم 31-03-2013, 07:06 PM   #14
9iii9iii
الصورة الرمزية 9iii9iii
مشاركات الشكر: 173
شكر 185 مرات في 106 مشاركات
وين كيرنل صياح اللي نسمع عنه
9iii9iii غير متصل   رد مع اقتباس
قديم 31-03-2013, 08:57 PM   #15
deyaaa
مشاركات الشكر: 33
المشاركة الأصلية كتبت بواسطة 9iii9iii مشاهدة المشاركة
ota/kernls/syah
aya hada be3rf bl linux y7kiny
قديم 03-04-2013, 05:18 PM   #16
علاوي مهدي
الصورة الرمزية علاوي مهدي
مشاركات الشكر: 1,937
شكر 755 مرات في 624 مشاركات
هل البار العلوي معرب في هذا الروم
علاوي مهدي غير متصل   رد مع اقتباس
قديم 14-04-2013, 05:56 PM   #17
amirsat
الصورة الرمزية amirsat
مشاركات الشكر: 2,017
شكر 1,887 مرات في 1,057 مشاركات
نزلت النسخة 7.3
http://d-h.st/HbO
قديم 14-04-2013, 10:57 PM   #18
deyaaa
مشاركات الشكر: 33
المشاركة الأصلية كتبت بواسطة rianyx مشاهدة المشاركة
هل جربتها هل البار العلوي عربي مثل البلوتوث والوايفاي
تم الإرسال من جهازي GT-I9100 بواسطة تاباتوك 2
لا لم اجربها التهيت برومي للgt-i9100 تحديث|| OUstahrom||بطعم الاكسبيريا v3
شوفه انشاء الله يعجبك
قديم 15-04-2013, 12:03 AM   #19
amirsat
لم اجربها....
Envoyé depuis mon GT-I9100 avec Tapatalk
قديم 15-04-2013, 10:43 PM   #20
dilaboni
شكر 45 مرات في 27 مشاركات
من أروع الرومات مع الكرنل صياح
dilaboni غير متصل   رد مع اقتباس
قديم 16-04-2013, 12:48 AM   #21
B ! L A L
B ! L A L غير متصل   رد مع اقتباس
قديم 30-04-2013, 05:13 AM   #22
علاوي مهدي
هل تم تعريب البار العلوي في هذا التحديث 7.3
قديم 20-05-2013, 12:33 AM   #23
بشير2
الصورة الرمزية بشير2
مشاركات الشكر: 967
شكر 157 مرات في 112 مشاركات
تسلم اخوي علي الروم الرايع وبارك الله فيك
بشير2 غير متصل   رد مع اقتباس
قديم 20-05-2013, 12:59 AM   #24
mraissi10
شكر 47 مرات في 34 مشاركات
الروم قوي جدا انا الآن على الاصدار الثامن الجديد صراحة روم لا يعيبه شيء
mraissi10 غير متصل   رد مع اقتباس
قديم 08-06-2013, 02:28 AM   #25
moradinho10
الصورة الرمزية moradinho10
شكر 228 مرات في 197 مشاركات
المشاركة الأصلية كتبت بواسطة mraissi10 مشاهدة المشاركة
ممكن اخي رابط الاصدار الثامن مع كيفية التثبيت انا الان على روم اخونا ونام الاصدار الاخير 14.4
وجزاك الله خيرا الجزاء
moradinho10 غير متصل   رد مع اقتباس
android, المكالمات, البطارية, google, launcher, mms, ريكفري, روم, روت, optimus, samsung, youtube, ويندوز, كيرنل
جميع الأوقات بتوقيت GMT +3. الساعة الآن 06:04 PM.
