قديم 29-04-2012, 09:17 AM   #1
شكر 9 مرات في 7 مشاركات
Sensation[Solved] Enable WiFi ad-Hoc Network for both ICS/GB
[ Solved ] Working 100% - Enable WiFi ad-Hoc Networking for Both ICS and GB for htc Sensation
السلام عليكم و رحمه الله و بركاته , ارجو من احد الاخوه الافاضل ان يقوم بترجمه هذا النص للعربيه لكي تعم الفائده
لعرض الموضوع بطريقه سليمه , يتم تعديل اللغه الي الانجليزيه في لوحه المستخدم ( لغة المنتدى )
or go to here [ Solved ] Working 100% - Enable WiFi ad-Hoc Network for both ICS / GB -htc Sensation
  • For GB , this Patch will enable ad-hoc 100% steady connection for both ( WEP and open Networks ) , Also Hotspot WPA2-PSK is still able to connect
  • For ICS , the APK will enable ad-hoc 100% steady connection with Full WiFi Signal for both ( WEP and open Networks )
General
  • Android does not show this Ad-hoc networks ( it Finds them in the search , but filters them out of the shown results ) , this patch prevent that filtering and shows those ad-hoc networks
  • There are two types of WiFi Networks :
    • Infrastructure ( Hotspot ) WPA,WPA2-PSK which is the most secured connection , usually routers broadcast this
    • Ad-hoc it is either WEP or open network which is less security , usually issued through a laptop connected to a DSL line to broadcast a temporary WiFi connection
DISCLAIMER
I am not responsible if flashing this Mod results in bricking your phone
for Rooted devices
ad-Hoc Networking for GB
Download Link
  • See attached Patch Ad-hoc Sensation-Ad-hoc.zip ( Full Credit and thanks to leeDroid )
  • ZT-180 Adhoc Switcher APK can also work with GB , But i prefer the permanent solution of the above Patch for GB
Apply the Patch
  • it is always good to do a Backup for your data , Or Just Backup the original file " wpa_supplicant " located in System\bin .
  • to restore the original file " wpa_supplicant " any time :
    • just open the Patch in a winrar window and navigate to System\bin and over-right the one in the Patch with the original ( you can get the original from your Rom zip ) . apply the modified Patch from recovery and you are back to the original
    • if you use Root Explorer to restore the original file ,make sure to set the correct permissions and ownership values
  • Clear Dalvik cache , and install the Patch from recovery as usual
ad-Hoc Networking for ICS
  • it is always good to do a NAND Backup for your Rom and data
  • there is an APK named " ZT-180 Adhoc Switcher " which i geuss is not intended for Sensation , this APK has two modes
  • it connects fast , very steady connection with full Wifi Signal and a fast WiFi Data transfer , Ad-hoc it is working for both WEP or open network , Please note that some firewalls could prevent you from connecting even after adjusting its settings
  • Ad-hoc( open Network ) :
    • for open network connection , to let the device find and connect automatically to any open ad-hoc you establish from your laptop ( with any name of your choice ) , go to setting while you are in infrastructure mode and clear the name in SSID then just switch to Just to try mode and enable WiFi and it will connect automatically ,
    • if you leave the default name in SSID "Android tether " as it is , it will only look for a connection with the name "Android tether " that is issued from your laptop and it will not detect any ad-hoc connection with any other name
    • if there is more than one open network that can be seen by the APK then
      • tip 1 : name the connction in your laptop same as in device SSID ( i.e android tether )
      • tip 2 : use Ad-hoc ( WEP Network )
      • this is because if there is more than one open ad-hoc network and you left the SSID name empty , you can not control which connection the APK will choose to connect to
  • Ad-hoc ( WEP Network ) :
    • if you want to use WEP connection , then enter SSID and Password before switching to to Just to try WEP Password.jpg , ( same name of the connection that you started on your laptop for example )
    • to enter SSID and WEP password you should switch to infrastructure mode and enter name and password , and after that switch back to Just to try mode
    • there is a complete help for the APK when you press the thin line under setting
  • Superuser.APK
    • if you are using the normal Super user APK opens normal , But if you are using the New SuperSU APK there will be a delay of maybe 5 sec for starting or executing Commands
  • please read this first #70 , Please note that this APK is not fully compatible with sensation although it worked fine with me
  • there is another APK ( try it if you like to ) named " WiFi AD HOC enabler " which doesn't really work good ( very weak signal and disconnects frequently ) , or at least this is what i experienced
Connectify Pro
  • there is a small yet powerful PC Software Called Connectify Pro ( i can't do without it ) that does three things :
    • it is for windows users
    • Acts like an actual hardware Router ( Not software networking )
    • toggle wifi with a single click for either ad-hoc or hotspot ( can start the same ad-hoc connection after reboot )
    • automatically does all complicated configurations for all types of network to fit with your firewall and windows , also share and transfer files among other options
Press the thanks Button for this Post
trkaaa غير متصل   رد مع اقتباس
العضو التالي يشكر trkaaa على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
اخر 5 مواضيع للعضو trkaaa
Modified Bootanimation - Removed the Snake ViperS... قسم ترقيات أجهزة HTC بنظام Google Android trkaaa 0 217 12-11-2012 04:18 AM
Modified Bootanimation-Wallpaper ViperS 1.3.5 -... قسم ترقيات أجهزة HTC بنظام Google Android trkaaa 3 358 06-10-2012 10:49 PM
Install any ICS Rom for (S-ON hboot 1.27.000) and... قسم ترقيات أجهزة HTC بنظام Google Android trkaaa 1 4492 29-04-2012 09:35 AM
Sensation[Solved] Enable WiFi ad-Hoc Network for... قسم ترقيات أجهزة HTC بنظام Google Android trkaaa 0 7110 29-04-2012 09:17 AM
[ Guide] htc Sensation install Custom /Stock... قسم ترقيات أجهزة HTC بنظام Google Android trkaaa 0 6507 29-04-2012 09:11 AM
android, google, htc, htc sensation, restore, sensation
جميع الأوقات بتوقيت GMT +3. الساعة الآن 02:03 AM.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
