العودة   الكمبيوتر الكفي > منتديات ايفون iPhone و الايباد iPad و الايبود iPod > منتدى الترقيات لأجهزة iPhone / iPod / iPad > ترقيات iPhone للاجهزة المغلقة
قديم 22-04-2012, 02:35 PM   #1
واخيرا فك تشفير اي ايفون على اي شبكة بدون جيفي او غيرها ومجاناااا
خطوات فك تشفير اي جهاز ايفون على اي شبكة مهما كان نوعه او بيس بانده
How to: Unlock your iPhone with SAM
I thought the IMSI unlock saga is done and dusted but apparently there are more to it. All credit goes to Loktar_Sun from weiphone.com who pursued an earlier lead that many, yours truly included, have gave up as a viable exploit.
What do you need: A jailbroken iPhone that can be activated in iTunes (that is, not officially blacklisted), a computer with the latest iTunes installed and working internet connection. You will also need to know the carrier that your iPhone is locked to.
1. Step one: Install Sam Bingner's SAM (Subscriber Artificial Module) package. I recommend that you get it from repo.bingner.com since older versions have a different interface and may not work for this purpose.
2. Enter SAM by either going through the settings menu or find the SAMPrefs icon on your springboard. You will need to have the SIM card you intend to use in your phone.
3. Go to utilities and select "De-Activate iPhone", your ActivationState under "More Information" should now be "Unactivated"
4. With SAM enabled, choose "By Country and Carrier" in "Method"; find your carrier, for some carriers operating more than one Carrier ID you may need to select "SIM ID"; easy to tell since iTunes will not activate if the wrong IMSI is selected.
5. Go to More Information", copy or write down the IMSI in "SAM Details", then tap "Spoof Real SIM to SAM".
6. Go back to the main SAM screen and change your "Method" to manual. Paste or enter the IMSI string we saved in Step 5.
7. Connect your iPhone to your computer and allow iTunes to do its job (namely re-activating your phone), double click "Phone Number" parameter at the main device screen and make sure that the ICCID matches that of your SIM card. If not you need to start over from Step 1.
8. Unplug your phone, close iTunes.
9. Disable SAM. The source article says to uninstall SAM and delete your lockdownd folders; it's unnecessary.
10. Connect your phone to iTunes again, you should get an error saying that your phone cannot be activated. This is normal. Just close iTunes and open it again.
11. You should see signal bars in a short time, congratulations.
12. Push notifications may stop working after this procedure but can be easily restored with "clear push" utility in SAM followed by connecting to iTunes.
Your phone will work normally with your SIM card and that SIM card ONLY since we have tricked iTunes to think that ICCID is one of the intended carrier's. The phone can be rebooted and connected to iTunes freely without losing the "unlock", at least for now.
Since it does not involve emergency numbers or IMSI spoofing it will not have any of the issues associated with SIM interposers. Tested working on iOS 5.01 but should work with tethered 5.1 too.
Posted by Laforet at 3:16 PM
Labels: Hardware, Net
husseinmhsh غير متصل   رد مع اقتباس
اخر 5 مواضيع للعضو husseinmhsh
مشكلة عويصة مع NOTE 2 S PEN هل من حل {vedio} قسم ترقيات أجهزة Samsung بنظام Google Android memoria 7 848 03-12-2012 11:56 PM
Note 2 لا يتعرف على ال s pen قسم ترقيات أجهزة Samsung بنظام Google Android husseinmhsh 6 564 28-11-2012 01:10 AM
واخيرا فك تشفير اي ايفون على اي شبكة بدون جيفي او... ترقيات iPhone للاجهزة المغلقة husseinmhsh 0 1906 22-04-2012 02:35 PM
الفزعة الففزعة البيس باند فارغ ما الحل ؟ ترقيات iPhone للاجهزة المغلقة Abyan_05 9 615 28-01-2012 10:42 PM
ايفون, iphone, itunes, unlock
جميع الأوقات بتوقيت GMT +3. الساعة الآن 08:51 AM.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
