قديم 16-11-2008, 03:02 PM   #1
الصورة الرمزية mozilla
مشاركات الشكر: 561
شكر 3,308 مرات في 348 مشاركات
Thumbs down صفحة جهاز HD الترقيات .التلميحات
[CENTER]
الموضوع كتبه الاعزاء mozilla وابوالبراء وhabibjamil واقوم بتحريره كل فترة للاضافات والتعديلات taiseer999
صور الجهاز
HTC Blackstone
صفحة جهاز HD الترقيات .التلميحاتصفحة جهاز HD الترقيات .التلميحات
مسميات الجهاز
HTC T828X / HTC Touch HD- Blackstone
المواصفات
كود PHP:
ecifications
ModelHTC Touch HD™ T8282
      Processor
Qualcomm® MSM 7201A™ 528 MHz
      Operating System
Windows Mobile® 6.1 Professional
      Memory
ROM512 MB RAM288 MB
      Dimensions
115 mm x 62.8 mm x 12 mm (4.35 in x 2.5 in x 0.47 in)
Weight146.4 grams (5.164 ounceswith battery
      Display
3.8-inch TFT-LCD flat touch-sensitive screen with 480 x 800 WVGA resolution
      Network
HSDPA/WCDMA
          Europe
/Asia 900/2100 MHz Up to 2 Mbps up-link and 7.2 Mbps down-link speeds Quad-band GSM/GPRS/EDGE Europe/Asia850/900/1800/1900 MHz (Band frequencyHSUPA availability, and data speed are operator dependent.)
GPS GPS and A-GPS ready
      Connectivity
Bluetooth® 2.0 with Enhanced Data Rate and A2DP for wireless stereo headsets
          Wi
-Fi®IEEE 802.11 b/g HTC ExtUSB™ (11-pin mini-USB 2.0)
CameraMain camera5 megapixel color camera with auto focus
          Second camera
VGA CMOS color camera
      Audio Built
-in 3.5 mm audio jackmicrophonespeaker, and FM radio
          Ring tone formats
AACAAC+, eAAC+, AMR-NBAMR-WBQCPMP3WMAWAV 40 polyphonic and standard MIDI format 0 and (SMF)/SP MIDI
      Battery Rechargeable Lithium
-ion or Lithium-ion polymer battery
          Capacity
1350 mAh
      Talk time
Up to 390 minutes for WCDMA
          Up to 310 minutes
for GSM
      Standby time
Up to 450 hours for WCDMA
          Up to 390 hours
for GSM
      Video call time
Up to 120 minutes
(The above are subject to network and phone usage.)
Expansion SlotmicroSD™ memory card (SD 2.0 compatibleup to 32 GB
      AC Adapter
Voltage range/frequency100 240V AC50/60 Hz
          DC output
5V and 1A
      Special Features
FM RadioG-SensorHTC TouchFLO™ 3DTouch-sensitive front panel buttons
طريقة عمل hard reset ( فورمات )
لجهاز HD
عن طريق أزرار الجهاز
في حالة توقف الجهاز عن العمل نهائياً لأي سبب من الاسباب
قم بفك البطارية لبضع ثواني ثم قم بتركيب البطارية ولا تضغط على زر التشغيل
ثم اضغط على زر رفع الصوت ورز خفض الصوت معاً ثم أضغط على زر التشغيل
سوف تظهر لك بعدها شاشة بيضاء لاتمام عملية الفورمات وهي :
This operation will delete all your personal data, and reset all settings to the manufacturer default settings. Press VolUp to restore manufacturer defaults, or press other keys to cancel.
لاتمام عملية الفورمات اضغط على زر رفع الصوت
وانتظر حتى تتم عملية الفورمات
لالغاء عملية الفورمات اضغط أي زر أخر
To perform a hard reset
1. With the device turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then briefly press the POWER button.
2. Continue pressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen:
3. Release the VOLUME UP and VOLUME DOWN buttons.
4. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
طريقة الدخول الى الـBootloader
وذلك بإغلاق الجهاز من زر البور
ثم يتم الضغط على زر البور مع زر خفض الصوت وزر الهوم معاً
فتظهر لنا الشاشة الملونة ..
1
2
صفحة جهاز HD الترقيات .التلميحات +
صفحة جهاز HD الترقيات .التلميحات [SIZE="7"]
او باستخدانم برنامج http://www.ce4arab.com/vb7/showthrea...84#post1049084
فك الحماية
اعادة الحماية
http://www.ce4arab.com/vb7/showpost....&postcount=884
التعريب
نزل الروم الاصلي للجهاز وصلته بالاسفل
خيار ثاني رابط تعريب تحديث 3 يناير: تعريب موبيديف على جميع الاجهزة الكفية WM6.1 الآن... هنا فقط...
http://www.ce4arab.com/vb7/showthread.php?t=137802
ملحقات التعريب:
ولتعريب الاوبرا
او
او http://www.ce4arab.com/vb7/showthread.php?t=139929
نسخ من الرومات الاصلية المتاحة للان
الروم العربي الرسمي للـ HD
http://www.ce4arab.com/vb7/showthread.php?t=141653
مواضيع متفرقة
تحميل الروم العربي الاصلي للجهاز بروابط من المنتدى ودون عناء البحث مع الشكر لصاحب الموضوع الاخ hazim5
mozilla غير متصل   رد مع اقتباس
عدد 282 من الاعضاء يشكرون mozilla على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
اخر 5 مواضيع للعضو mozilla
بعض تويكات Windows Mobile 6.5 قسم ترقيات اجهزة (HTC) nadia_h 79 29679 24-03-2009 01:50 PM
Davideuck_V-2_HP,21028 - للـ HD قسم ترقيات اجهزة (HTC) mozilla 51 5104 10-03-2009 04:16 PM
قديم 16-11-2008, 05:23 PM   #2
al-mesbah
الصورة الرمزية al-mesbah
مشاركات الشكر: 269
شكر 361 مرات في 113 مشاركات
جزاك الله كل خير وبارك فيك
السؤال هنا.... هل توقف جهازك عن العمل واضطررت ان تعمل له هارد ريست؟.. إذا كان كذلك فما هو السبب؟
وإن كان لمجرد الاستفاده فشكرا جزيلا لك
al-mesbah غير متصل   رد مع اقتباس
عدد 7 من الاعضاء يشكرون al-mesbah على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 17-11-2008, 07:50 AM   #3
إسلام بن منصور
شكر 6 مرات في 2 مشاركات
المشاركة الأصلية كتبت بواسطة al-mesbah مشاهدة المشاركة
ما هي مصير المعلومات التي على الجهاز بعد إجراء هذه العلمية ؟
إسلام بن منصور غير متصل   رد مع اقتباس
عدد 5 من الاعضاء يشكرون إسلام بن منصور على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 17-11-2008, 07:51 AM   #4
taiseer999
كبير الخبراء
الصورة الرمزية taiseer999
مشاركات الشكر: 12,017
شكر 111,068 مرات في 14,195 مشاركات
المعلومات تمسح بالكامل
وmozilla اكمل مواضيعك هنا وسننسقها سويا ان شاء الله
taiseer999 غير متصل   رد مع اقتباس
عدد 28 من الاعضاء يشكرون taiseer999 على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 17-11-2008, 01:04 PM   #5
mozilla
مشاركات الشكر: 561
نعم أثناء تجارب إصدارات التعريب المختلفة حدث ذلك مع مرة واحدة
بارك الله فيك أخي الحبيب .....
تثبيت خلفية tf3d ( المانيلا ) في كل الصفحات
عدد 38 من الاعضاء يشكرون mozilla على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 17-11-2008, 02:00 PM   #6
ابوالبراء
الصورة الرمزية ابوالبراء
مشاركات الشكر: 5,124
شكر 3,662 مرات في 1,029 مشاركات
جميل جداً وألف شكر للغالي mozilla وكذلك الخبير تيسير
وأنا أضيف طريقة الدخول الى الـBootloader
ابوالبراء غير متصل   رد مع اقتباس
عدد 20 من الاعضاء يشكرون ابوالبراء على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 18-11-2008, 09:10 AM   #7
taiseer999
كبير الخبراء
تم القيام ببعض التعديلات
عدد 15 من الاعضاء يشكرون taiseer999 على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 18-11-2008, 10:54 AM   #8
DIXON
الصورة الرمزية DIXON
مشاركات الشكر: 662
شكر 619 مرات في 319 مشاركات
بارك الله فيكم جميعا ... لست املك الجهاز لكني احب التعاون
DIXON غير متصل   رد مع اقتباس
عدد 6 من الاعضاء يشكرون DIXON على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 18-11-2008, 11:19 AM   #9
الملك808
مشاركات الشكر: 31
شكر 17 مرات في 6 مشاركات
مشكوووورين وما قصرتوا
الملك808 غير متصل   رد مع اقتباس
عدد 3 من الاعضاء يشكرون الملك808 على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 18-11-2008, 11:43 AM   #10
ALSAADCOM
الصورة الرمزية ALSAADCOM
شكر 108 مرات في 30 مشاركات
مبروك القسم الجديد وفعلا نحن نحتاج الى صفحة خاصة بروعة ال htc العملاق HD واود ان اشكر كبير الخبراء السيد تيسير على اهتمامه ومجهوده وطبعا لا انسى السيد Mozilla على جهوده الجبارة وبالنسبة لي
انا امتلكت الجهاز من يوم امس وجاهز لاي استفسار
عربته بالتعريب اللي وضعوه الشباب تحت عنوان 3 اكتوبر
واستعملت الباتش للاوبرا وكان ناجح معي وركبت عليه بعض البرامج وكانت ناجحة
الجهاز في قمة الاستقرار وصوته حلو افضل بكثير من الدايموند وخصوصا عندما تضع السماعات تشعر انك في قلب الحدث
الشاشة عملاقة رائعة بكل معنى للكلمة
ALSAADCOM غير متصل   رد مع اقتباس
عدد 26 من الاعضاء يشكرون ALSAADCOM على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 18-11-2008, 12:16 PM   #11
gedo
الصورة الرمزية gedo
مشاركات الشكر: 1,828
شكر 1,405 مرات في 645 مشاركات
شكرا جزيلا على التعاون الرائع والى الامام دائما
وهذا ليس بغريب او جديد عليكم كاعضاء روعة لمنتدى أروع
gedo غير متصل   رد مع اقتباس
عدد 5 من الاعضاء يشكرون gedo على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 18-11-2008, 12:20 PM   #12
mozilla
مشاركات الشكر: 561
طريقة وضع صورة خاص خلفية للمانيلا
سوف تحتاج برنامج
1
Manila Editor
2
والصورة المراد استخدامها بمقاس
256 * 256
يمكن تعديل المقاس بأي برنامج لمعالجة الصور مثل الفوتوشوب
3
ملف
4a087e41_manila
الموجود في مشاركة شرح تثبيت خلفية المانيلا
قم بتحميل البرنامج من المرفقات
ثم بتشغيل البرنامج
ثم قم بالضغط على
وقم باختيار المكان الموج به ملف 4a087e41_manila
سوف تظهر لك صورة الخلفية المستخدمه
قم بالضغط على
واختار الصورة الجديدة بالضغط على
سوف تكون النتيجة هكذا
قم بإغلاق البرنامج
ملاحظة البرنامج يقوم بعمل نسخة إحتياطية من الملف قبل التعديل في حالة أنك تريد الرجوع إليها مرة أخرى
ثم قم بتعطيل tf3d وقم بعمل إعادة تشغيل الجهاز
ثم انسخ الملف المعدل إلى مجلد windows ووافق على الاستبدال
ثم قم بتشغيل التتش فلو سوف تجد كل الصفحات لها نفس الخلفية الجديدة إلا شاشة البداية
إذهب إلى settings tab
Wallpaper
وقم باختيار نفس الصورة المستخدمة كخلفية جديدة
الملفات المرفقة
نوع الملف: zip Manila Editor v.0.2.zip‏ (410.0 كيلوبايت, المشاهدات 2595)
عدد 50 من الاعضاء يشكرون mozilla على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 18-11-2008, 12:39 PM   #13
mozilla
مشاركات الشكر: 561
هذه النسخة التي تأتي مع الروم الأصلية للجهاز
للأسف العربي يظهر بها متقطع الحروف
لكن هذه النسخة التي قم بوضعها خبيرنا تيسير إصدار أقدم قليلاً
http://www.xda3.com/f/get.php?filename=1226846144.cab
لكن تعمل بشكل جيد جداً
عدد 55 من الاعضاء يشكرون mozilla على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 18-11-2008, 12:58 PM   #14
wm55wm
شكر 12 مرات في 5 مشاركات
htc hd
ممكن برنامج ملاحة متوافق مع الجهاز وبه خرائط السعودية والمناطق البرية
wm55wm غير متصل   رد مع اقتباس
عدد 3 من الاعضاء يشكرون wm55wm على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 18-11-2008, 02:04 PM   #15
yalasmary
الصورة الرمزية yalasmary
مشاركات الشكر: 1,209
شكر 228 مرات في 107 مشاركات
مجهود مبارك ان شاء الله
yalasmary غير متصل   رد مع اقتباس
عدد 5 من الاعضاء يشكرون yalasmary على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 18-11-2008, 02:35 PM   #16
ابوالبراء
بعض الخدع و الإضافات والخاصة بالكاميرا
علماً أنني قمت بتجربتها
Burst لعمل صور متتالية
Mobile
Device\HKEY_LOCAL_MACHINE\Software\HTC\C amera\P6set "Enable" on "1"
Sports للصور الرياضية
MobileDevice\HKEY_LOCAL_MACHINE\Software \HTC\Camera\P8set "Enable" on "1"
Video Share لعمل فيديو يتم مشاركته مع الآخرين والذي ظهر لي حتى الآن عن طريق موقع يو تيوب
MobileDevice\HKEY_LOCAL_MACHINE\Software \HTC\Camera\P9set "Enable" on "1"
GPS Photo كعاتدها الشركة لا تظهر هذه الخاصية في أجهزتها فنظطر لعمل ذلك يدوياً
وهي خاصية التصويربالإحداثيات للمكان الذي تم إلتقاط الصورة فيه .
MobileDevice\HKEY_LOCAL_MACHINE\Software \HTC\Camera\P10set "Enable" on "1"
صور توضيحية لقبل وبعد الإضافات ..
الصورة الأولى :
الصورة الثانية :
الصورة الثالثة :
ودمتم في رعاية الله
عدد 63 من الاعضاء يشكرون ابوالبراء على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 18-11-2008, 03:16 PM   #17
habibjamil
الصورة الرمزية habibjamil
مشاركات الشكر: 1,708
شكر 3,097 مرات في 1,036 مشاركات
أنتم دائما سباقون للخير... كنت ناوي اليوم أبدأ بالعمل على هذه الصفحة وأقترح فتح صفحة خاصة بالجهاز لكن انشغلت كثيرا بالعمل... حتى الآن ناوي أشتري الجهاز قريبا وأتمنى بتواضع أن أضيف إلى معلوماتكم القيمة
habibjamil غير متصل   رد مع اقتباس
عدد 4 من الاعضاء يشكرون habibjamil على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 18-11-2008, 03:18 PM   #18
AbuHumaid
الصورة الرمزية AbuHumaid
مشاركات الشكر: 4,039
شكر 6,816 مرات في 919 مشاركات
المشاركة الأصلية كتبت بواسطة ابوالبراء مشاهدة المشاركة
Mobile
DeviceHKEY_LOCAL_MACHINESoftwareHTCCamer aP6set "Enable" on "1"
MobileDeviceHKEY_LOCAL_MACHINESoftwareHT CCameraP8set "Enable" on "1"
MobileDeviceHKEY_LOCAL_MACHINESoftwareHT CCameraP9set "Enable" on "1"
MobileDeviceHKEY_LOCAL_MACHINESoftwareHT CCameraP10set "Enable" on "1"
الصورة الأولى :
الصورة الثانية :
الصورة الثالثة :
http://www.ce4arab.com/vb7/pub110800/56659.jpg
ودمتم في رعاية الله
شكراً اخي العزيز ابوالبراء ..
كأضافه على طريقتك .. يمكن تفعيل هذه الاضافات عبر برنامج Advanced Config ..
شكراً اخي الكريم mozilla على الموضوع ..
AbuHumaid غير متصل   رد مع اقتباس
عدد 15 من الاعضاء يشكرون AbuHumaid على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 18-11-2008, 04:00 PM   #19
أباقصي
الصورة الرمزية أباقصي
مشاركات الشكر: 28
شكر 266 مرات في 161 مشاركات
اذا في طريقة لازالة بعض البرامج اللي تيجي مع الجهاز والواحد مايحتاجها زي مثلا الماسنجر واليوندوز لايف وبرامج اخرى ممكن ترفع من اداء الاجهاز
أباقصي غير متصل   رد مع اقتباس
عدد 7 من الاعضاء يشكرون أباقصي على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 18-11-2008, 04:21 PM   #20
Abo Forat
الصورة الرمزية Abo Forat
مشاركات الشكر: 100
شكر 200 مرات في 110 مشاركات
مجهود جبار
شکرا یا اخوانی انه حقا موضوع جمیل.. آلاثنین القادم یباع الجهاز فی آلسویدلاول مرة
Abo Forat غير متصل   رد مع اقتباس
قديم 18-11-2008, 08:15 PM   #21
habibjamil
متشوق جدا للانضمام الى نادي الـ HD (وأكيد سأشتاق للقيصر) وأتمنى أن لا يتأخر في الشحن عن طريق Clove
العضو التالي يشكر habibjamil على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 18-11-2008, 10:34 PM   #22
avocatsy
مشاركات الشكر: 112
شكر 156 مرات في 61 مشاركات
المشاركة الأصلية كتبت بواسطة habibjamil مشاهدة المشاركة
هالدعاء مو من قلبي بس رح أقوله على سبيل الدعابة : انشاء الله يتأخر الشحن وانشاء الله يقوم القراصنة بالبحر الأحمر باختطاف السفينة اللي رح يشحنوا عليها لأنو ما بدنا نخسرك نحن جماعة القيصر .. هههههههههههه
avocatsy غير متصل   رد مع اقتباس
قديم 19-11-2008, 01:05 AM   #23
البراك
مشاركات الشكر: 1,039
شكر 476 مرات في 165 مشاركات
افاااا تركتنا يا ابو احمد :rolleyes:
تصدق عاد انا افكر باومنيا
البراك غير متصل   رد مع اقتباس
قديم 19-11-2008, 03:11 AM   #24
chakrah
شكر 7 مرات في 6 مشاركات
thanxxxxxxxx
chakrah غير متصل   رد مع اقتباس
قديم 19-11-2008, 06:33 AM   #25
khalid179
شكر 16 مرات في 14 مشاركات
ياشباب أبتلشت مع شاشة (( align screen )) اللي تجي بعد hard reset !!! مشيت مع علامة الزائد على جميع الزوايا لكن مو راضية تنتهي المشكلة ؟؟؟؟ أيش أعمل معها حتى أدخل على الويندوز ؟؟؟ نصف ساعه وأنا أطارد في السهم حتى ذبحني النوووووم
khalid179 غير متصل   رد مع اقتباس
للمبتدئين, الاسماء, الاندرويد, البطارية, الشرق الاوسط, اندرويد, تحميل, gprs, gps, hd2, htc, رسمي, روم, شرح, restore, rom, فك الحماية, ويندوز, كتب
جميع الأوقات بتوقيت GMT +3. الساعة الآن 03:03 PM.
