قديم 29-04-2012, 09:11 AM   #1
شكر 9 مرات في 7 مشاركات
[ Guide] htc Sensation install Custom /Stock Recovery ( Downloads
Complete Guide for installing Both Custom / Stock Recovery ( Downloads and Methods ) - htc Sensation
Credit
السلام عليكم و رحمه الله و بركاته , ارجو من احد الاخوه الافاضل ان يقوم بترجمه هذا النص للعربيه لكي تعم الفائده
لعرض الموضوع بطريقه سليمه , يتم تعديل اللغه الي الانجليزيه في لوحه المستخدم ( لغة المنتدى )
or go to here [ Guide ] for installing Both Custom / Stock Recovery ( Downloads and Methods )
here is a complete Guide for installing Custom Recovery or Stock Recovery for htc Sensation
1) Custom Recovery
Downloads
  • i gathered some of those links for all over the forum , thanks for the members who posted them
  • to manually install Custom Recovery , here is recovery-clockwork-5.x ( from bootloader ) :
  • to manually install Custom Recovery , here is recovery-clockwork-5.x.images ( from PC and device in fastboot , usb debugging enabled , fast boot UN-ticked in power menu ) :
    • File format is { recovery name }.img , and you should use Method 1 for this file format
    • CWM v5.0.0.8 is always Proved working
    • CWM 5.0.2.0 ( use Method 1 )
    • CWM v 5.0.2.0 ( use Method 1 should work )
    • CWM 5.8.0.9 ( use Method 1 )
4EXT Recovery
  • tip : 4EXT touch Recovery has more options , i recommend after S-Off to install CWM safer ( because Revolutionary install it after S-OFF , and i 'd rather go by the book for S-OFF procedure , much safer ) , then after install SU and Rom all finished and your Rom settles , then move to 4EXT later on
Installation Problems
  • in case fastboot commands is not working :
    • uninstall htc sync then uninstall new htc drivers that comes with it , and install Old htc driver download link for HTCDriver3.0.0.007.exe
    • uncheck fast boot under setting \ power or simply remove battery and put it back and boot to boot loader
    • start cmd as admin , disable firewall if needed , remove conflicting software or APK's
  • there is a new version of CWM 5.8 touch version , it has bugs now , so don't use it until those Bugs are fixed ( it also may prevent installing of ARHD ICS Rom or usb connection )
  • for PG58IMG.zip that give error , edit android-info.txt without extracting the zip file to include your cid and mid ( using Notepad++ or maybe notepad ) , and use ( Method 2 )
  • to edit android-info.txt , read this title " How to edit the android-info.txt File via Windows " in hereUser Friendly Firmware Upgrade
Manual Installation
  • ( in case of reinstalling or updating ) , install Rom Manager ROM Manager APK from the Market ( free or Pro ) or 4EXT Recovery Updater or 4EXT Recovery Control and let it install latest Custom Recovery automatically
  • if you install CWM recovery through revolutionary while S-off ( or connected to it later on ) , it will install an old version i think CWM 4.x . this old version will not charge device if it is powered off, So better immediately install CWM 5.x , ( Note that 30 min to 45 min with me to install )
  • Method 1 :
    • if you are using Recovery.img ( i.e ???.img ) then from your PC using ADB tools download for WINDOWS or download for LINUX and the device should be in fastboot usb .
    • Put recovery.img from zip file inside ADB Folder ,
    • start cmd as administrator and navigate to ADB folder which includes fastboot.exe
    • execute fastboot flash recovery recovery.img , then after installation is finished execute fastboot reboot-bootloader
  • Method 2 :
    • the file name should be PG58IMG.zip , make sure of that ( not PG58IMG.zip.zip
    • if your are using a downloaded PG58IMG.zip ( i.e .zip ) ( it is not a file that you rename and compress by yourself !!!!! ) , then place it into SD card and install it from bootloader as usual update
    • if it gave you cid or mid error , then you can either super cid and use it
    • or if you don't want to do that you can modify the PG58IMG.zip , it has android-info.txt file inside it ( which determines on which mid and cid's devices it is allowed to be installed )
    • you can modify the android-info.txt to include your cid and mid , and it should work
    • don't extract the PG58IMG.zip , just open it in winrar and modify the android-info.txt file only ( add cid and mid ) using notepad++ ( drag it to desktop , modify then drag it inside winrar window again to replace the existing file and press ok )
  • Method 3 : you can extract ????.img from the zip ( PG58IMG.zip ) and flash it as in Method 1
  • Method 4 : you can also try Android Flasher if you like ( do it at your own risk , i didn't try it personally )
How to Boot into Custom Recovery From PC without installation
  • Download ADB tools download for WINDOWS
  • Put recovery img { recovery name }.img inside ADB folder in same place your fastboot.exe
    • { recovery name }.img is the exact name for the downloaded recovery img that you put inside the ADB Folder
    • it is NOT PG58IMG.zip recovery
  • Start cmd as administrator and navigate to ADB Folder which includes fastboot.exe and type the command fastboot boot { recovery name }.img and press enter
  • your phone should now go to recovery screen ( loaded through fastboot )
2) Stock Recovery
3) My Other Posts
  • [Tutorial/Mod] Replace “ god mode“ with “Ownership Mode" / and Editing Any APK's implemented on MikRuny 1.03 Tweak here ( htc Incredible 2 )
  • Solve WiFi Errors , Radio Flashing Problem , Caused by htc Dev Unlock Method here
  • [ guide ] Successful S-OFF using htc dev Unlock for GB or ICS after non proper Wrong S-ON with Security Warning here
  • [ Solved ] Working 100% - Enable WiFi ad-Hoc Network for both ICS / GB -htc Sensation here
Press thanks Button for this Post , and vote for it
trkaaa غير متصل   رد مع اقتباس
اخر 5 مواضيع للعضو trkaaa
Modified Bootanimation - Removed the Snake ViperS... قسم ترقيات الأجهزة الأخرى بنظام Google Android trkaaa 0 2070 12-11-2012 04:18 AM
Modified Bootanimation-Wallpaper ViperS 1.3.5 -... قسم ترقيات الأجهزة الأخرى بنظام Google Android trkaaa 3 1767 06-10-2012 10:49 PM
Install any ICS Rom for (S-ON hboot 1.27.000) and... قسم ترقيات الأجهزة الأخرى بنظام Google Android trkaaa 1 10633 29-04-2012 09:35 AM
Sensation[Solved] Enable WiFi ad-Hoc Network for... قسم ترقيات أجهزة HTC بنظام Google Android trkaaa 0 20911 29-04-2012 09:17 AM
[ Guide] htc Sensation install Custom /Stock... قسم ترقيات أجهزة HTC بنظام Google Android trkaaa 0 18496 29-04-2012 09:11 AM
android, book, dropbox, fastboot, firmware, htc, htc incredible, htc sensation, power menu, ruu, s-off, s-on, sensation, super cid, usb
جميع الأوقات بتوقيت GMT +3. الساعة الآن 02:13 PM.
