العودة   الكمبيوتر الكفي > المنتديات العامة > المواضيع ذات العناوين الغامضة والغير معبرة عن محتوى الموضوع
قديم 03-10-2016, 12:37 AM   #1
مشاركات الشكر: 102
شكر 10 مرات في 8 مشاركات
ROM][6.0.1_r61][Stable]ResurrectionRemix v5.7.3 [01-10-2016][SM-G7102 & SM-G7105]
[ROM][6.0.1_r61][Stable]ResurrectionRemix v5.7.3 [01-10-2016][SM-G7102 & SM-G7105]
02053731pm 1170595 684901 0 0.com%2Fu%2F4931972%3Fv%3D3%26s%3D200
02053731pm 1170596 684901 0 0
روم مارشميللواا لهذا الجهاز سامسونج غلاغكسي غراند 2
About Resurrection Remix ROM
Changelog
Installation
Downloads and useful links
Resurrection Remix the ROM has been based on CM,slim.omni and original Remix ROM builds, this creates an awesome combination of performance, customization, power and the most new features, brought directly to your Device
Many things that in previous versions were tweaked with mods, are now included by default in the ROM so, please enjoy!
Special thanks to, the CM team,OMNI team ,SLIMROMS and of course to all the supporters
Included Main Features
- 6.0.1_R52
- optimised kernel
-compiled with latest tool chains
-Navigation Bar
-Enable/Disable Navbar
-Navbar Ring Switch
-Navbar Ring Targets
-Navbar Button Customization
-Navbar Dimensions(Potrait & Landscape)
-Statusbar
-Brightness Slider
-Enable/Disable Show Notification Count
-SuperUser Indicator Switch
-Carrier Label
-Carrier Label Switch
-Carrier label Colour
-Quick PullDown Switch
-Smart Pulldown Switch
-Clock Customizations
-Time & date
-Clock Colour
-Day & date Toogle
-Center Clock/Right Clock Choice
-Battery
-Battery Bar customization
-Battery Icon Customization(circle/landscape/Potrait and more)
-Battery % Text
-Network Traffic Indicator
-Theme Chooser
-RR exclusive PITCH BLACK THEME
-Animations
-Toast Animations
-ListView Animations
-System Animations
-Gestures
-Gestures Anywhere Feature
-App Circle Bar
-Choose apps in App circle
-Trigger Width
-Trigger Hieght
-Trigger Position
-Recents Panel
-Clear All button Switch
-Clear All Tasks Switch
-Clear All Button Location(Top right,Top Left,Top Center,Bottom Left,Bottom Right,Bottom Center)
-cLock Widget
-CLock And Alarm Customizations
-Weather Panel Customizations
-Calender Events
-LockScreen
-Lockscreen Shortcuts
-Choose upto 5 Shortcuts
-100 Icons for Shortcuts
-Quick Slider Shortcuts
-Notification Drawer
-Weather Display Switch
-Quick Settings
-Choice to Add 20 Tiles
-Enable 2/3/4 Tiles per Row
-Enable Disable Birghtness Slider in Notification Panel
-Advanced Location Settings Switch(Choose Battery saving/Device Only/High Accuracy Directly in Notification Panel)
-LongPress Toogles to Enter Settings
-Buttons
-Backlight Timer
-Backlight Strength
-Navigation Bar left/Right handed mode Switch
-Power Menu
-Power Menu End Calls Switch
-Volume Buttons
-Wake Up Device
-Playback Control
-Keyboard Cursor Control
-Swap Buttons on Landscape mode
-Perfomance Profiles
-LCD Density
-Expanded Desktop Mode
-All New CM Audio FX App
-Heads Up Customizations
-Overall Smoothness Improvements
-Quick Unlock
-Optimizations to Improve Battery
-ALL cm13 Features
-AND MUCH MUCH MORE
Installation Instructions
- Download the latest build
- Download Gapps
- Take a nandroid backup
- Recommended - Full wipe and factory reset
- Flash ROM using latest ClockworkMod or TWRP recovery
- Flash Gapps
- Reboot.
- Enjoy!
Update Instructions
- Download the latest build of Resurrection ROM
- Flash ROM using recovery
- Flash Gapps
- Wipe cache
- Wipe dalvik cache
- Reboot
- Enjoy!
Installation Files
build 5.7.3 Latest For SM-G7102
Resurrection Remix M 6.0.1_r61 V5.7.3
Enjoy the Resurrection Remix OS // #GETRESURRECTED
Changelog:
Android 6.0.1_r52->6.0.1_r61
Frameworks: Halo Color
Frameworks: HALO
Halo: Add option to Enable/Disable Halo Button in Header
SysUI: Fix Layouts of Halo Button within Expanded Statusbar
StatusbarHeader: Fix Headsup and Halo Button Animations
Halo: Reverse message bubble bg and text colors
Blur: Minor fixes
Blur: Fix Arithmetic Exception when Radius and Scale are set to 0
Blur: Major update
SystemUI: BatteryBar: Gradient color
SystemUI: Display bluetooth battery status when available
Implement Blur Statusbar personalization options
Update halo and heads up qs button
Configurable Notifications transparency
Configurable Smartbar button transparency
Fix up header button icon, position and animation
Network Traffic and Custom Logos: Fix Inverted SB icon tint when color is white
Option to set custom scrolling values
Statusbar: Gracefully adapt 3Minit Battery hook for AOSP
Add 3Minit battery mod
Option to let ADB always notify
Custom Toast Color Options
Fix FC on Seekbar in VOlume dialog and power menu Stroke & opacity
SystemUI: Add vector support to SlimRecents
Update Slim Recent App Sidebar
mountservice: Don't nuke all volumes when decrypting (Speeds up bootime by 30 % for encrypted devices)
SysUI: Add theme manager permission
Themes: Add permission to themes protected broadcasts
Instant reboot action trigger
MobileNetworkSettings: Check CarrierConfig on isWorldMode
EditPhoneNumberPreference: Prevent empty text from being set
Dynamically tell the user which vendor image is needed
Show a more descriptive message when vendor.img is out of date
Update Kernel Adiutor apk
make overlay permission check configurable
fw: enforce android.permission.PREVENT_SYSTEM_KEYS in system server
SysUI: Add RecreateStatusbar to Quick Settings Blur
SysUI: Make sure new Blur Features dont Conflict with Transparency Items
bootanimation: add multithreaded decode
framework: don't allow assist activities while not provisioned
Services: Fix a small Derp from instant reboot action
sepolicy: Let the IO prefetcher look at sdcardfs
sepolicy: Put theme service in its own context
sepolicy: More IOP rules
sepolicy: Fix MTP for sdcardfs
Pulse Solid Bar Sanity Levels & Lavalamp Anim Speed
Pulse 2.0 Advanced Audio/Visual Rendering
Settings:Pulse-Update Legacy Dimens and Bar Spacing Resources
Settings:Pulse Use Sliders for Pulse Customizations
Add dependencies to pulse 'fading blocks' seekbars
Clock color master switch
Task Manager animations
Obey inverted statusbar ONLY when color is white
Color picker: Rework
ADB always notify
Disable gradient SB by default
Popup menu: Add support for item icons
Fix Null Checks to avoid NPE
Fix random crash in libhwui
lights: Make sure the lights are out
SysUI: Define config for showing screen on hints
AudioDucking : Check session playback state
SysUI: Add first time use lock screen hints
PackageManager: make protected-broadcasts permission aware
livedisplay: Add support for direct color balance control
Recents Styles - Add Android N Recents Style Button
SysUI: Show hints if showing keyguard and provisioned
SystemUI : Initialize state linked volume
Recents: Remove Dead Code
Factory reset: Wipe media by default
Improve the scan process
Fix notification panel can't hide in statusbar
Enable camera hal v3 interface
Revert "FWB: Volume Dialog: Force expanded mode 2/2"
mountservice: Shut down volumes before restarting framework
SeekBarPreferenceCham: Expand with buttons
Add SIM status string for localizing voice/data strings
Settings: Fix possible crash
Settings: Improve vibrator intensity dialog layout
settings: Add support for color balance in LiveDisplay
Automatic translations imports
All updates from CM
Bugfixes and improvements
For more info Track Github Activities
Bugs:
-front cam fc
Download:
Here
patch.zip
Note there is no ota for this build and Dont forget to flash patch.zip or else u will get bootloop
Build V5.7.4 For SM-G7105
Hey SM-G7105 Users
Here is Resurrection Remix for ms01lte
Here ROM ZIP
Patch ZIP
Instructions
Download rom.zip
Download patch.zip
Flash both and reboot
Bugs
Front cam i think so
Credits
SoUnd001
Download GApps
alfredee غير متصل
العضو التالي يشكر alfredee على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
اخر 5 مواضيع للعضو alfredee
android, bluetooth, rom, update
جميع الأوقات بتوقيت GMT +3. الساعة الآن 03:29 AM.
