قديم 09-06-2010, 10:11 PM   #51
بو زقم
شكر 7 مرات في 6 مشاركات
للاسف ما طلعت
بو زقم غير متصل   رد مع اقتباس
قديم 09-06-2010, 10:16 PM   #52
محمد2012
الصورة الرمزية محمد2012
مشاركات الشكر: 2,884
شكر 3,399 مرات في 1,074 مشاركات
طيب هل طلع massStorageDetector.exe في التاسك منجر بعد ما طفيت وشغلت جهازك؟
المشاركة الأصلية كتبت بواسطة بو زقم مشاهدة المشاركة
للاسف ما طلعت
اللي يبيي يجرب هالطريقه لقيتها بموداكو
I own a B7610, and it has a internal 2gb (My Storage). I was curiously browsing the \Windows, and I accidentally tap a file (Don't remember what it is) and suddenly....
My Storage is gone!!!.... Nothing in the file explorer.... مناقشة حول اختفاء My Storage لجهاز أومنيا 2
Checked memory settings and it just indicated that My Storage is 0.Mb and can't be reset/format...
Tried hard reset, flashed the phone, crossed my fingers etc. but all failed, My Storage was gone...
So I took a deep breath and refreshed my mind on all things WinMo, got some ideas and tried it,
And it worked!
So I'm sharing this with i8000 users for I read some were having problems with i8000 disappearing "My Storage"...hoping my method will work for them too...
So here it goes, but with this method, you will not able to retrieve the files in My Storage, 'cause it will be formatted....
1. Check if Samsung Settings Still recognize My Storage even if it tells 0mb and cannot be formatted.
2. Download NueStorage Storage Manager 1.1 http://www.samsung-omnia.org/third-party-s...tach;attach=794
3. Install to your device. You will find it inside Windows default Settings. Run NueStorage.
4. In the drop down option, find your "missing" My Storage (look for the size either 2gb for B7610, 8-16gb for i8000) usually it is named DSK3:MMC Card. If you found your "My Storage" in the list, the problem is not hardware related. Choose it.
5. Now under Partitions, tap Properties
6. Partition Properties will open. Try to choose "Mount". If it is successful, soft reset and check if you got your My Storage back. If not, continue reading...
7. Close Partition Properties. Then under Filesystem, choose DSK3:MMC Card( or whatever name your 8gb-16gb gives) and tap Format.
8. It must successfully format the storage. If not, try again.
9. Do a hard reset or Flash a ROM....
10. Turn on device,finish device Set up and don't skip anything. Wait for a pop message telling if you want to format your storage card (which is actually My Storage) to make it usable or something like that. Click yes and wait for format to finish.
(If you waited long enough and there is no such message, continue with the guide)
11. Go to USB connection and set connection to Mass Storage, choosing My Storage as the mass storage device. Click ok.
12. Connect your device to your PC (via usb). If all goes well, the PC will recognize My Storage (as mass storage), but it will ask you to format it, Click Yes and Format.
13. After successfully formatting My storage via PC, safely disconnect it from the computer. Check your device if My Storage is back....and celebrate مناقشة حول اختفاء My Storage لجهاز أومنيا 2
As far as I can remember, these are the steps I have done to get back "My Storage"... Hope that the above will work on those who have the problem too..
Fell free to ask questions or comments upon my guide... GOODLUCK مناقشة حول اختفاء My Storage لجهاز أومنيا 2
IMPORTANT NOTE
If nue storage doesn't show your missing "my storage", then there is a high possibility that the problem is hardware related. If that's the case the only solution is bring the phone to a service center for repairs.
محمد2012 غير متصل   رد مع اقتباس
عدد 3 من الاعضاء يشكرون محمد2012 على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 10-06-2010, 01:06 AM   #53
aceir
الصورة الرمزية aceir
مشاركات الشكر: 4,617
شكر 2,354 مرات في 989 مشاركات
المشاركة الأصلية كتبت بواسطة motabe3 مشاهدة المشاركة
الله يعطيك العافية
أكون شاكر لك لو عندك طريقة ممكن تحل الاشكالية
قبل كل شي تحتاج تزور الرابطين الاثنين وتقراه صح
http://www.ce4arab.com/vb7/showthread.php?t=220292
http://www.ce4arab.com/vb7/showthread.php?t=214649
واذا المشكله مستمره
بعدها نبدا بالشرح الاصعب
بالنسبه الي طلبه اخوي محمد2012
MassStorageDetector
تجده هنا
http://www.4shared.com/file/42zY5OZj...eDetector.html
بانتظار الملف
نجربه ونشوف
يمكن تنحل المشكلة
مع اني حتى مع الهارد رست ماظهر لي الستورج
وأتمنى ممن لديهم الامنيا 2
نسخ هذا الملف ورفعه للتجربه
فقد يحل المشكلة للجميع
اخوي انا معي امنيه2
وهو ليس ملف تنفيذي بل dll
100%
Mouse over this area to load the wiki
aceir غير متصل   رد مع اقتباس
عدد 2 من الاعضاء يشكرون aceir على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 10-06-2010, 11:02 AM   #54
مشاركات الشكر: 83,775
شكرا لكم جميعا
أسأل الله أن يجزي خيرا كل من يحاول أن يجد حلا لمشاكل إخوانه.
جهازي ليس فيه مشكلة ولكن للمتابعة.
قديم 10-06-2010, 02:44 PM   #55
بو زقم
كلا الطرق لم تفلح معي
قديم 10-06-2010, 03:09 PM   #56
aceir
أخي (محمد2012) هل جهازك الأومينا أو الأومنيا2...
أنا جهازي الأومنيا2 والجهاز ليس في أي مشكلة والحمد لله وMy Storage 16g شغال وظاهر... ومع ذلك لم أجد الملف الذي أشرت إليه أنت (massStorage) لم أجده لا في مجلد الوندوز ولا في (StartUp) ولا ضمن المهام task manager ضمن Process ...
والذي أريد قوله هو أن الملف الذي ذكرته حسب علمي لا إشكالية من عدم وجوده في الأومنيا2. والله أعلم.
اخوي
تجده عن طريق ريسكو اكس بلور
وليس معنه انحلت المشكله
اما في task manager
ميطلع الى مع التشغيل
100%
قديم 10-06-2010, 04:32 PM   #57
ingvay
الصورة الرمزية ingvay
مشاركات الشكر: 1,684
شكر 1,733 مرات في 465 مشاركات
قمت بمراسلة موقع شركة سامسونج وطلبت منهم شرح المشكلة بالتفصيل حيث انها باتت مشكلة معروفة لجهاز الاومنيا 2 لكن للاسف جاء الرد دبلوماسي ولم يذكرو اي ادنا توضيح للمشكلة..هنا نص الرسالة المرسلة والرسالة المستلمة.
my storage despair Issue
Hello there,
I've problem with my storage ..its gone suddenly..and this issue is Familiar
with this phone..so i need an Explanation to this issue and what could coz this problem..thx
وهنا الرد
Dear Sir,
Sorry for the inconvenience.
Please go to settings->system->memory.check whether you can see My
Storage.If found you can either reset/format the same.
If you dont find My Storage under memory then please contact the service
center in your region.
Thank You.
وهو بأختصار مفيد يخبرك ان تقوم بالتحقق من الذاكرة موجوده او لا تحت بند الميموري..فأذا لم تجدها فأنه عليك ارسال الجهاز الي اقرب مركز صيانة
ويتواصل الغموض مع هذه المشكلة ..في الامان
ingvay غير متصل   رد مع اقتباس
عدد 4 من الاعضاء يشكرون ingvay على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 10-06-2010, 05:44 PM   #58
aceir
المشاركة الأصلية كتبت بواسطة ingvay مشاهدة المشاركة
Hello there,
وهنا الرد
Dear Sir,
Thank You.
اخوي انا محصلت ردعلى هذي المشاركه 31 واحتاج خبراء لتعليق عليها
وهذا نص الحوار
اخواني احتمال المشكله تكون بسيطه ولا نعلم الى الان فك لغزها واعتقد الشركه مطفتها مشكله اختفاء الذاكره
بمعنى انا لان افكر في اشياء كثيره
احس سؤالي داخل عرض ولا له اي منطق ومسوي مخترع
من ضمنها لو نضغط على ابدا اكيد له كود معيآ لاجل فتح القوائم
ولوالغينا الكود وحطينا كود اخر له لنفترض كود اتصال وضغطنا على ابدا راح تفتح لنا اوامر الاتصال وهذا يعد كسبيل مثل والي محيرني هل يوجد كود My Storage
لانو في حالت فقدانها نستعين بالكود لاجل استخراجها
طيب الان
ابي اعرف مهو الفرق بين
soft reset
factory reset
Hard reset
وهل جميعها موجوده في الجهاز
وسؤال خارجي عن المناقشه للموضوع هذا
هل بامكاني اغلاق جميع الاوامر بمعنى الجهاز معاد اقدر اتحكم فيه بال استثناء بامر كود معيآ دون استعانه باي برامج
واحتاج تفكرون فيها
وايضآ وجت والله مني عارف اسمه لاكن ان شاء الله احصله في نفس النظام يقوم بقتل جميع البرامج النشطه بستثناء القائمه الحاليه التي اكون فيها وصراحه تعبت منها واحتاج الغيها
ارجو عدم تجاهل الرساله
100%
100%
قديم 10-06-2010, 07:15 PM   #59
ingvay
المشاركة الأصلية كتبت بواسطة aceir مشاهدة المشاركة
وهذا نص الحوار
طيب الان
soft reset
factory reset
Hard reset
واحتاج تفكرون فيها
100%
100%
1-لا يوجد كود لأستعادة MyStorage لاننا تعلمنا في عالم الكمبيوتر انه يوجد كيان مادي و كيان برمجي ..الكيان المادي هو اي شي ملموس مثل الهارديسك و الذاكرة الداخلية والماثربورد وغيره..والكيان البرمجي هو برنامج او كود يقوم بمهمه معينة مثل امر فتح القوائم كما في مثالك.
2-Soft Rest إعادة تشغيل الجهاز .
3-Factory Rest إعادة ضبط الجهاز كما جاء من المصنع.
4-Hard Rest يقوم بعمل فورمات للجهاز .
Soft Rest و Hard Rest موجودات في الجهاز .
5- لم استوعب السؤال الاخير..
في الامان
عدد 2 من الاعضاء يشكرون ingvay على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 10-06-2010, 07:30 PM   #60
محمد2012
المشاركة الأصلية كتبت بواسطة Nooruddeen مناقشة حول اختفاء My Storage لجهاز أومنيا 2
اخي نور الدين
جهازي اومنيا 1
ومن الممكن ان طريقة الاومنيا 1 غير الاومنيا 2
وصادق من الممكن ان الطريقه تختلف
العضو التالي يشكر محمد2012 على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 10-06-2010, 07:39 PM   #61
aceir
طيب هل هي واضحه للكل بمعنى الدخول الى السيتنج او غيره
في الامان
الرد على السؤال 5
هل يوجد برنامج مدمج في الجهاز دون استعانه ببرامج خارجيه
مهمته منع التحكم في الجهاز دون استثاء
و برنامج يقوم بقتل جميع الاوامر النشطه عدا القائمه التي تكون فيها بمعنى لتقليل حجم الذاكره
غير التسك منجر
وللمعلوميه دون استعانه ببرامج
اذا بتقول لايوجد فانا حصلت الطريقه وهي مخفيه
واعتقد هي خطيره وتسبب خلل لا قدر الله في النظام وتبب تلف الذاكره او غيره
ووجت اشياء مخفيه كثيره
وحصلت النقاش عن خفايا الامنيه 2 وهو مثبت
عدا اشياء اكتشفتها
مثل لعبه
asphalt4
و الله حاسبه غريبه جدآ
مع العلم قمت بعمل بفورمات للجهاز اكثر من مره
ولا زالت موجوده
100%
قديم 11-06-2010, 01:47 PM   #62
motabe3
مشاركات الشكر: 276
شكر 200 مرات في 75 مشاركات
الحقيقة شر البلية مايضحك
أمس أخذت جهازي للمستقبل التابع للمتبولي وكيل سامسونج قسم الصيانة (الوكيل الرسمي)
نادولي المسئول الباكستاني واسمه منير وقلت له جهازي فيه مشكلة
وشرحت له المشكلة
الرجال بدا يحاول يصرفني
قال يمكن يحتاج قطعة غيار ومهيب موجودة عندنا
يمكن تتأخر اسبوعين أو أكثر
لكن وده لمشاعل الخليج أو اكسيوم لأنهم وكلاء للصيانة
طبعا ماقتنعت بكلامه وقلت له أنا جهازي عليه ضمان المستقبل وبعدين ماعندي مشكلة للمدة ممكن أنتظر
لأن ماعندي استعداد أتردد من وكيل لآخر وأنا أعرف أساليبهم في تطفيش الزباين
مالكم بالطويلة الرجال حاول يصرفني لكني رفضت
طبعا فكيت الغطاء قدامه وخذت شريحة الجوال وكرت الذاكرة الخارجية وبدا يحاول يبحث عن مبررات جديدة
يقول يمكن شريحتك فيها فايروس وهو اللي خرب الجهاز طبعا ضحكت عليه
وتحديته في فحص الذاكرة
والمحاولة الثالثة له للتصريف لما بدأت في عمل الهارد رست بدا يسوي لي فهمان وان المفروض الهارد رست الوكالة اللي تسويه وانه هو اللي يضر الجهاز ضحكت مرة ثالثة وقلت له أصلا الطريقة رسمية وبالمانيوال موجودة وبعدين كيف تبيني أعطيك الجهاز وفيه بيانات خاصة
المهم الجهاز خليته عندهم بس كان واضح انهم يصرفون من يجيهم ولا يوجد لديهم استعداد لخدمة العميل
ننتظر ونشوف آخرتها معهم
إضافة : أعتقد من حقي مطالبتهم بجهاز بديل حتى انتهاء اصلاح جهازي أو أنا غلطان ؟ لأن فاتني مطالبتهم بالبديل
motabe3 غير متصل   رد مع اقتباس
قديم 11-06-2010, 03:27 PM   #63
ASAMI ARCH
شكر 7 مرات في 4 مشاركات
نفس المشكلة حصلت لي اليوم
الجهاز سقط على الأرض من ارتفاع متر واحد تقريباً وكان ذلك أمس
بعدها كان يشتغل بشكل طبيعي
حدث أنه أثناء نقلي لبعض الملفات من مجلد لآخر داخل my storage
علق وكان قبلها بطئ جداً .. قمت بعمل ريست وإذا بالذاكرة اختفت
لم يظهر في usb
ولم يظهر في activecync
قمت بعمل فورمات ونفس المشكلة
المشكلة إن الجهاز من السعودية وأنا في مصر
إنا لله وإنا إليه راجعون
اللهم أئجرنا في مصيبتنا واخلف لنا خيراً منها
المشاركة الأصلية كتبت بواسطة محمد2012 مشاهدة المشاركة
My Storage is gone!!!.... Nothing in the file explorer.... http://www.ce4arab.com/vb7/images/sub/1006_1/165595.jpg
And it worked!
13. After successfully formatting My storage via PC, safely disconnect it from the computer. Check your device if My Storage is back....and celebrate http://www.ce4arab.com/vb7/images/sub/1006_1/165596.jpg
Fell free to ask questions or comments upon my guide... GOODLUCK http://www.ce4arab.com/vb7/images/sub/1006_1/165597.jpg
IMPORTANT NOTE
إخواني .. هذه الطريقة تبدو مجدية ..
خلاصتها أنه برنامج تقوم بتنصيبه وتجده في مجلد الويندوز تشغله من هناك .. وهو مثل
partition magic
يشبهه
والحقيقة وجدت my storage باسم part02
ولكني لم أستطع عمل لا فورمات ولا حتى مسح وعمل بارتشن جديد
كلما أردت فعل واحدة منها تظهر رسالة تفيد بأنه لا يمكن عمل ذلك
مع أن هذه الخواص تعمل مع الكارت الخارجي ..
فيبدو أننا نحتاج لبرنامج يدخلنا على ما يشبه safemode
حتى نستطيع عمل فورمات لهذا البارتشن ال16 جيجا تقريباً والمسمى ب part02
أتمنى أن أكون وضعتكم على طرف خيط الوصول للحل بإذن الله
أعزكم الله
جربت الطريقة مع safemode
لا فائدة
وجربت هذه الطريقة أيضاً وهي مجدية إن لم تكن المشكلة في الهاردوير
ولكن للأسف صار لابد من الوكيل
أو شراء ميموري أخرى خارجية بسعة 16 أو أكثر
والله يعوض علينا
ASAMI ARCH غير متصل   رد مع اقتباس
عدد 3 من الاعضاء يشكرون ASAMI ARCH على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 14-06-2010, 01:47 AM   #64
Smile4ever
مشاركات الشكر: 75
شكر 21 مرات في 16 مشاركات
السلام عليكم جميعاً
لاحظت أن الجميع لديهم تقريباً نفس المشكلة ولم يصل أحد لحل حتى الآن .. إلا بالذهاب إلى الوكيل و توديع الجهاز لمدة 20 يوم .. :rolleyes:
وهذا ما لا أستطيع عمله لأن الجهاز يحتوي على صوري الشخصية وبياناتي
من قراءاتي يتضح أن السبب تحرك قطعة داخلية في الجهاز وهي السبب في اختفاء الذاكرة
أنا سقط الجوال مني قبلها بيومين أو ثلاثة من على ارتفاع متر تقريباً .. لكن التعليق واختفاء السيدة ميموري لم يظهر إلا اليوم فقط
خطر على بالي حل .. لكن أحتاج إلى تشجيع وتأييد
ما رأيكم أن أرميه مرة أخرى من على ارتفاع متر ونصف هذه المرة .. فربما تعود القطعة مكانها ؟
Smile4ever غير متصل   رد مع اقتباس
قديم 14-06-2010, 10:20 AM   #65
ingvay
المشاركة الأصلية كتبت بواسطة Smile4ever مشاهدة المشاركة
السلام عليكم جميعاً
مشكلة اختفاء الذاكرة الداخلية لا تزال مجهولة السبب لكن المتداول انه عند اختفاء الذاكرة يتم تغيير الماثربورد ..بمعني انه ليس من المنطقي عند رمي الجهاز سوف ينتج عنه رجوع الذاكرة.؟؟ انا لا انصحك برمي الجهاز حتي لا تنكسر الشاشة لا سمح الله...في الامان
العضو التالي يشكر ingvay على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 14-06-2010, 01:12 PM   #66
Smile4ever
مشاركات الشكر: 75
صدقني يا سيدي أنها لن تنكسر
لأنه ببساطة هذا الجهاز يعمل عكس كل القوانين الكونية
نفسي أقول اني تندمت على شرائه .. بس مو قادرة
قديم 14-06-2010, 05:06 PM   #67
ASAMI ARCH
أنا أهون على نفسي ما حدث
وهو أنني أحمد الله أن الميموري الداخلية لم يكن فيها معلومات مهمة وأنني أنصح من تعمل معه الميموري أن لا يعتمد عليها لأنه معرض أن يفقدها في أي وقت
ولذلك فالحل الذي سأقوم به هو شراء ميموري 32 جيجا
وقدر الله وما شاء فعل
لعل هذا خير من أن أفقد بيانات أهم فيما بعد
والذاكرة الخارجية حتى لو حدث شيء للجهاز فالمعلومات فيها لن تفقدها بإذن الله
بارك الله فيكم
عدد 2 من الاعضاء يشكرون ASAMI ARCH على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 14-06-2010, 06:29 PM   #68
المشاركة الأصلية كتبت بواسطة ASAMI ARCH مشاهدة المشاركة
بارك الله فيكم
هذا الذي عملته أنا أيضا من أول شرائي للأومنيا2 منذ 6 أشهر ... ومع ذلك حتى الكروت الخارجية قد تتلف أو ينسرق الجهاز -الله يحفظ لنا جميعا أجهزتنا- وهذا الذي ينبغي أن نفعله مع الأجهزة دائما... وهذا الأمر لم أقله قبل هذه المشاركة مراعيا مشاعر الشباب
والذي ينبغي للجميع أن لا يحفظ أمورا خاصة جدا في الجهاز أو ملفات ليس لها نسخة أخرى في مكان آخر ...
والحل أن نحفظ من ملفاتنا المهمة نسخة أخرى في الجهاز المكتبي في منزلنا أو في الهارديسكات الخاريجة، وأن نحفظ دائما من الأسماء والملاحظات في الأوتلوك مع المزامنة الدائمة...
عدد 5 من الاعضاء يشكرون Nooruddeen على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 17-06-2010, 12:44 AM   #69
sea-166
الصورة الرمزية sea-166
مشاركات الشكر: 960
شكر 1,579 مرات في 648 مشاركات
للاسف واضح ان المشكلة كل مالها تزيد
جهازي خرج من الصيانة اليوم
ولكن للاسف بعته باقل من نصف قيمة الشراء
اتمنى من ساسمونج ان تعطيني حل جذري للمشكلة او سبب مقنع
اتمنى لكم التوفيق واحترامي لكل خبراء الاومنيا جميعا
محبكم عبد الله
sea-166 غير متصل   رد مع اقتباس
عدد 2 من الاعضاء يشكرون sea-166 على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 17-06-2010, 12:55 AM   #70
ingvay
المشاركة الأصلية كتبت بواسطة sea-166 مشاهدة المشاركة
محبكم عبد الله
الله يعوضك خير اخونا العزيز..وبالفعل هذه المشكلة بدأت تقلل من قيمة الجهاز والغريب ان الشركة لم تضع حد للمشكلة فهذا اذا دل عن شي فيدل علي ان المشكلة مصنعية بحته ..في الامان
قديم 20-06-2010, 06:41 PM   #71
ASAMI ARCH
أخي هل تم حل المشكلة بعد خروجه من الصيانة ؟
مشكور
قديم 21-06-2010, 03:08 PM   #72
همـس السحاب
انا من لحظة ماشتريت الجهاز مختفيه الذاكرة الداخليه..
لاسويت ترقيه ولا طاح مني ..من جد مشكلة ..
همـس السحاب غير متصل   رد مع اقتباس
قديم 02-07-2010, 06:05 PM   #73
bashaqa
شكر 6 مرات في 2 مشاركات
ضحية جديدة من ضحايا إختفاء الذاكرة الداخلية
ما لاحظته قبل ان تحدث هذه المشكلة بأنني عندما اقوم بإعادة تشغيل الجهاز وهو موصول بالشاحن تكون قراءة البطارية خاطـئة
وآخر مرة وهي اليوم عند قيام إعادة التشغيل وهو موصول بالشاحن أختفت الذاكرة الداخلية
فأعتقد بأن المشكلة تتمحور عند الشحن
فأرجو تأكيد هذه المعلومة من قبل من فقد الذاكرة الداخلية
bashaqa غير متصل   رد مع اقتباس
قديم 15-07-2010, 12:22 AM   #74
بومنصور
اصبت بالعدوى هنق الجهاز واعدت تشغيلة واختفت الذاكرة 16 جيجا
بشرونا يا اخوان مالقيتوا حل للمشكلة هذي ..
وانا انصح كل من ناوي يشتري الجهاز انه يبعد عنه الجهاز قوي بس مشكلتة تمشي وانت حاط يدك على قلبك لا تطلع لك مشكلة والمشكلة الاكبر ان مشاكلة ما لها حل الا بالوكيل ..
شكرا لكم
بومنصور غير متصل   رد مع اقتباس
قديم 15-07-2010, 03:34 AM   #75
aceir
المشاركة الأصلية كتبت بواسطة بومنصور مشاهدة المشاركة
شكرا لكم
الله يعوضك يخوي اخير منه
ولازالت المشكله قائمه حتى الان .
فيه ذاكره خارجيه 16 قيقا يابانيه ضمان سنه من الوكيل
سعرها 125ريال في البطحى تفي بالغرض
100%
ترقية
جميع الأوقات بتوقيت GMT +3. الساعة الآن 04:00 AM.
