برنامج ادارة التطبيقات والتحكم بها ...App Manager v3.23 Donated
بعض الوظايف مثل تعطيل التطبيقات وايفافها تحتاج الى روت
• Easiest uninstaller - single click on an app to uninstall it
• Batch operations of apps : uninstallation, share, disable/enable, Re-install, manage, open in Play-Store or Amazon-AppStore.
• APK files management
• Removed Apps history viewer
• Customizable Widgets, for uninstalling the recently installed app or clearing its internal/external data
• Normal/ROOT uninstallation of apps . Using ROOT, it's much easier and faster
• Shows all kinds of apps, and not just those that you can launch. For example: widgets, live wallpapers, keyboards, launchers, plugins,...
• Auto-handling of apps that have admin privileges, allowing you to revoke them and uninstall the apps
• Auto add shortcuts to newly installed apps, no matter how you've installed them. Also choose exactly which launcher will have the new shortcuts
• Various operations on selected app:
• Run
• Share app as link or APK file
• Manage
• Open link on play store.
• Kill background processes
• Stop app (needs ROOT+Honeycomb)
• Clear internal storage (ROOT)
• Create shortcut, including hidden ones
• Search the Internet for app's name/package
• Disable/Enable app (ROOT)
• Re-install
• Sort apps by size, name, package, date installed, date updated, launch time
• OS uninstallation integration
• Useful shortcuts to built in apps
• Filter apps by:
• System/user apps
• Enabled/disabled apps
• Installation path: SD card / internal storage
• Ability to uninstall system apps (Root , might not work on some cases)
• Shows app information: package name, date installed, build number, version name
• Auto-cleaning of external storage files of apps that the OS didn't remove them right for some reason
• Theme chooser, in case you don't like the cards UI
التحميل
