قديم 18-03-2012, 08:10 PM   #1
مشاركات الشكر: 57
شكر 373 مرات في 134 مشاركات
برنامج Volume+ (Sound Boost) v1.9.0.0 Final لزيادة ارتفاع صوت السماعات الخارجية لمكال
Requirements: Android OS 2.3+
Overview: This is very similar to my Louder Volume Hack application but rendered in code rather than pushing different files across.
4P0QHr BtTNTUHe JJKaPPRi3aifc Khitu9ZBZDZ0jB9sP1jhmRDsAvjpF1SLknug=w705
zJS3HJZMmi0dJoPTm l2QkYsCoovTw 6tSR GqUEO4AGeJKa4v9Zc6cezgO3FAIj7A zSAHYoKcpP8ry 3ZIfzVS1CLEIAWcG9dXrbcC1vGfBb3SObVdbDdSZWH FCj0V1DXWk
A Cyanogen Mod 7 or MIUI ROM is HIGHLY recommended. Running this app on a Stock ROM/Kernel may result in it not working, being far too quiet, or getting even quieter. PLEASE don't comment or rate badly if you are on a Stock ROM as this is most likely the problem.
Thanks.
This Application is ONLY for phones running Gingerbread.
It will NOT work on any other version of Android but should work on ANY phone running Gingerbread (2.3).
ALL SETTINGS CAN BE ALTERED SEPARATELY!
FEATURES INCLUDE:
* On/Off toggle
* Volume Boost
* EQ pre-sets
* Bass Enhancer
* Stereo Widener (only for Headset/Bluetooth Headset)
* Virtual Room Effect (VRE - Echo)
ALL FEATURES AVAILABLE FOR:
* Phone Speaker
* Headset
* Bluetooth Headset
This application works in a similar way to DSP Manager but with this tool you can push the volume up much higher. It has options to boost the main Speaker Volume and add a Bass Enhancer.
Please use this tool wisely. It can SERIOUSLY damage your speakers if not used carefully. I cannot stress this enough.
What's in this version:
UI Overhaul
Settings completely changed
Sliders automatically adjust to show pre-sets
Volume/BassBoost/Echo now controlled exclusively by the sliders
Tick the 'Custom EQ Settings' to enable the sliders
the ability to Save/Load/Delete custom settings added
Method of altering volume modified
Check added so you can only open headset/bluetooth settings when headset is plugged in or bluetooth device is connected.
More Info:
Volume+ (Sound Boost) - Android Apps on Google Play
Download Instructions:
http://www.mediafire.com/?ecwangfcd0cexa1
samoto غير متصل   رد مع اقتباس
اخر 5 مواضيع للعضو samoto
ما هو لحد الان روم اس 4 مطبوخ كويس ومستقر قسم ترقيات أجهزة Samsung بنظام Google Android boob112200 3 941 23-05-2015 12:46 PM
كنت محتاج برنامج exposed installer يتوافق مع لولي... منتدى Google Android للبرامج yasserst 7 1977 14-05-2015 10:21 AM
طلب روم لهاتف اس3 ميني gt-18190 قسم ترقيات أجهزة Samsung بنظام Google Android samoto 0 684 15-03-2015 08:34 AM
طلب روم لهاتف اس3 ميني gt-18190 منتدى هواتف Google Android العام samoto 0 467 15-03-2015 08:33 AM
لكل من يعاني من استهلاك بطارية قسم ترقيات الأجهزة الأخرى بنظام Google Android firasusman 8 2815 28-03-2014 11:21 PM
قديم 10-04-2012, 06:09 AM   #2
azxcvg
ياليت تشرح البرنامج وشكراا
azxcvg غير متصل   رد مع اقتباس
قديم 23-07-2014, 04:16 PM   #3
ibm200
شكراا اخى الكريم ولكن رابط ميديا فير حذف الملف ارجو التجديد
ibm200 غير متصل   رد مع اقتباس
قديم 23-07-2014, 07:15 PM   #4
pcman2k
مشاركات الشكر: 2,029
شكر 178 مرات في 109 مشاركات
pcman2k غير متصل   رد مع اقتباس
قديم 27-07-2014, 05:17 AM   #5
m_6600
الصورة الرمزية m_6600
مشاركات الشكر: 159
شكر 1,012 مرات في 555 مشاركات
خرب لي سماعات الجهاز اقسم بالله
اصبح بها شوشرة
لا أحد يستخدمه
m_6600 غير متصل   رد مع اقتباس
android, bluetooth, gingerbread, google, rom, test
جميع الأوقات بتوقيت GMT +3. الساعة الآن 05:39 AM.
