قديم 08-11-2010, 05:49 AM   #76
قرقشني
الصورة الرمزية قرقشني
مشاركات الشكر: 134
شكر 140 مرات في 51 مشاركات
export PATH=/data/local/bin:$PATH
sh-3.2$ export PATH=/data/local/bin:$PATH
sh-3.2$ a2sd
cp: cannot create '/data/dta2sd.lg1': Permission denied
rm: cannot remove '/data/dta2sd.log': Permission denied
[ ] Apps2SD is launching...
/system/bin/a2sd: line 22: /data/dta2sd.log: Permission denied
/system/bin/a2sd: line 23: /data/dta2sd.log: Permission denied
/system/bin/a2sd: line 24: /data/dta2sd.log: Permission denied
/system/bin/a2sd: line 27: /data/dta2sd.log: Permission denied
/system/bin/a2sd: line 28: /data/dta2sd.log: Permission denied
/system/bin/a2sd: line 35: /data/dta2sd.log: Permission denied
/system/bin/a2sd: line 36: /data/dta2sd.log: Permission denied
/system/bin/a2sd: line 37: /data/dta2sd.log: Permission denied
/system/bin/a2sd: line 38: /data/dta2sd.log: Permission denied
/system/bin/a2sd: line 39: /data/dta2sd.log: Permission denied
grep: /init.rc: Permission denied
tee: /data/dta2sd.log;: Permission denied
__ _____
|__/ | Darktremor Apps2SD 2.7.5.1 (2010-09-22)
/system/bin/launcha2sd: line 117: /data/dta2sd.log: Permission denied
[ ] GetProp Command = /system/bin/toolbox getprop
[ ] SetProp Command = /system/bin/toolbox setprop
[ ] Mount Point = /system/sd
[ ] Creating /cache/dc
mkdir: can't create directory '/cache/dc': Permission denied
chmod: /cache/dc: Permission denied
[ ] Symlinking /cache/dalvik-cache to /data/dalvik-cache
rm: can't stat '/cache/dalvik-cache': Permission denied
ln: /cache/dalvik-cache: Permission denied
/system/bin/launcha2sd: line 282: /data/dta2sd.log: Permission denied
[ ] Starting Darktremor Apps2SD Version 2.7.5.1
/system/bin/launcha2sd: line 627: /data/dta2sd.log: Permission denied
[X] No command specified.
You must specify a command if you are launching
from the command line.
Syntax: /system/bin/a2sd command
All commands create a logfile: /data/dta2sd.log
Command is one of the following
Standard Apps2SD Commands:
reinstall
Moves free and paid apps to the ext2/ext3/ext4
partition on your secure digital card. Removes
the No A2SD flag file.
This is used if you have already executed an
a2sd remove command. Otherwise, this part is
automatically performed when Apps2SD is
started.
File removed: /data/.noa2sd
remove
Moves free and paid apps to the internal phone
--More-- (7% of 8017 bytes)
قرقشني غير متصل   رد مع اقتباس
قديم 08-11-2010, 06:03 AM   #77
einstien
الصورة الرمزية einstien
مشاركات الشكر: 840
شكر 1,042 مرات في 595 مشاركات
المشاركة الأصلية كتبت بواسطة قرقشني مشاهدة المشاركة
sh-3.2$ a2sd
__ _____
reinstall
started.
remove
اولا اكتب su بعدين انتر
بعدها اكتب a2sd check
einstien غير متصل   رد مع اقتباس
قديم 08-11-2010, 06:22 AM   #78
nmo
شكر 30 مرات في 25 مشاركات
dear all
can i update my motorola milestone xt720 with thise rom
nmo غير متصل   رد مع اقتباس
قديم 08-11-2010, 06:30 AM   #79
einstien
مشاركات الشكر: 840
المشاركة الأصلية كتبت بواسطة nmo مشاهدة المشاركة
dear all
I don't think so my dear because it's basically a Nexus One Rom Based
قديم 08-11-2010, 06:59 AM   #80
قرقشني
مشاركات الشكر: 134
طيب هذا طلع معي
sh-3.2$ su
sh-3.2# a2sd check
__ _____
[ ] Starting Apps2SD Check Program.
[ ] Checking for ext partition
Darktremor 2.7.5.1 Apps2SD Status Report
Legend:[*]=Setting is correct
[!]=Setting is correct, but not optimal.
[X]=Setting is incorrect and needs to be fixed or option is not available.
Block Device -[*] Found
-[*] /dev/block/mmcblk0p2
EXT Partition -[*] Mounted
Mount Point - [ ] /system/sd
Partition Type -[*] EXT2
Support EXT2? -[*] Yes
Support EXT3? -[*] Yes
Support EXT4? - [X] No
Apps - [ ] Linked to SD Card.
[ ] No Apps2SD Flag File not found.[*] Programs run from SD card
To run from internal storage, type a2sd remove
Private Apps - [ ] Linked to SD Card.
[ ] No Apps2SD Flag File not found.[*] Private Programs run from SD card
Dalvik Cache - [ ] Regular directory.
[ ] Dalvik to /cache flag file not found.
[ ] Dalvik to SD flag file not found.[*] Dalvik runs from Int. Storage.
To run from SD card, type a2sd cachesd.
To run from /cache partition, type a2sd cachepart.
Swap - [ ] Partition present.
[ ] No Swap flag file not found.[*] Swap starts.
To deactivate swap, type a2sd noswap
[ ] Note: Not all ROMS activate swap.
ZipAlign -[*] Not running at boot.
To activate it, type a2sd zipalign
Dalvik Heap(MB) -[*] 32m
Low Memory
Killer Settings -[*] 1536,2048,4096,4096,5120,15360
Note: Values are in pages.
1 page = 4KB memory.
Values represent the following:
1st number = Foreground App
2nd number = Visible App
3rd number = Secondary Server
4th number = Hidden App
5th number = Content Provider
6th number = Empty App
[] For a list of commands that you can use with Apps2SD
Type: a2sd help
sh-3.2#
قديم 08-11-2010, 10:42 AM   #81
nicegypt
الصورة الرمزية nicegypt
مشاركات الشكر: 512
شكر 1,786 مرات في 677 مشاركات
شغال عندك زي الفل
Sent From My Naxuuuuuus Using Tapatalk Pro
nicegypt غير متصل   رد مع اقتباس
قديم 08-11-2010, 11:56 AM   #82
alsahran79
الصورة الرمزية alsahran79
مشاركات الشكر: 343
شكر 271 مرات في 127 مشاركات
جزاك الله خير ومشكور علي العمل الجبار
alsahran79 غير متصل   رد مع اقتباس
قديم 08-11-2010, 05:52 PM   #83
dotshie
مشاركات الشكر: 72
شكر 55 مرات في 41 مشاركات
خاصية الهز مو شغالة عند الرد على المتصل او الاتصال
وبرنامج Trackball مو شغال فقط اللون الابيض
dotshie غير متصل   رد مع اقتباس
قديم 08-11-2010, 06:34 PM   #84
nicegypt
مشاركات الشكر: 512
لا كله شغال مية في المية خاصية الهز عند الاتصال والرد تعمل جيدا والتراك بول لازم تنزل البرنامج من الماركت
قديم 08-11-2010, 07:11 PM   #85
قرقشني
مشاركات الشكر: 134
لا اخي العزيز مااقدر انقل البرامج للذاكره
لاني حاولت في الفيس بوك ولاقدرت انقله
واما خاصية الاهتزاز عند الرد فهي غير مفعله الا اذا كنت وضعت لها ااعدادت لتفعيله
شكرا جزيلا اخي الكريم
قديم 08-11-2010, 07:12 PM   #86
dotshie
مشاركات الشكر: 72
والله امصدقك بس عندي ما تشتغل شنو يمكن يكون السبب؟
انشالله راح انزل البرنامج واجرب
شكرا جزيلا
قديم 08-11-2010, 11:18 PM   #87
nicegypt
مشاركات الشكر: 512
انت فين فى امريكا وانا اجيلك واوريلك تليفونى وهى شغالة
العضو التالي يشكر nicegypt على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 08-11-2010, 11:56 PM   #88
einstien
مشاركات الشكر: 840
المشاركة الأصلية كتبت بواسطة nicegypt مشاهدة المشاركة
فعلا حتى انا مو شغالة معي
الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 04:56 PM ----------- المشاركة السابقة اضيفت في 04:54 PM ---------
للي ما اشتغلت معه خاصية الهز عن الرد على الاتصال :
برنامج Extra Phone Setting موجود في الماركت مجاني و عن طريقه تقدرون تفعلون الهز عن الرد على الاتصال
قديم 09-11-2010, 11:53 AM   #89
dotshie
مشاركات الشكر: 72
صراحه هذا افضل روم انا جربتة وتقريبا انا امجربهم كلهم بس لولا وجود العيبين الي ذكرتهم
1- خاصية الاهتزاز عند الرد والاتصال مع انه صاحب الروم يقول موجودة بس عندي ما تشتغل
2- برنامج Trackball للمكالمات لم يرد عليها اجباري اللون الابيض
اما غير ذلك فهو جدا سريع وما يعلق ابدا
الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 12:53 PM ----------- المشاركة السابقة اضيفت في 12:51 PM ---------
المشاركة الأصلية كتبت بواسطة einstien مشاهدة المشاركة
شكرا تم تجربة البرنامج بس مو مضبوط مرة اوكي و 10 لا
قديم 09-11-2010, 07:58 PM   #90
einstien
مشاركات الشكر: 840
طيب جرب اعمل فلاش للملف هذا من الريكفري بس لا تنسى تعمل NAND BACKUP قبل لا تسوي الفلاش و جرب
http://www.4shared.com/file/hj4njjrm...t_signed2.html
قديم 10-11-2010, 11:57 AM   #91
dotshie
مشاركات الشكر: 72
اشكرك جدا اخي الكريم مضبوط 100% ما قصرت باقي مشكلة وحده لون
الـ Trackball صار ازرق بالـ Missed call وما اقدر اغيره كمل احسانك وحلي هالموضوع
العضو التالي يشكر dotshie على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 10-11-2010, 03:52 PM   #92
nicegypt
مشاركات الشكر: 512
نزل برنامج trackball alert من الماركت
عدد 2 من الاعضاء يشكرون nicegypt على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 10-11-2010, 07:30 PM   #93
einstien
مشاركات الشكر: 840
المشاركة الأصلية كتبت بواسطة dotshie مشاهدة المشاركة
لا يفتى و مالك في المدينة جرب تسوي زي ما قال الاخ نايس ايجبت انا ضابطه معي و بعد ما تنزل البرنامج تقدر تغير الالوان حسب ما يعجبك سواء للرسائل او المكاالمات او الايميلات
العضو التالي يشكر einstien على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 10-11-2010, 10:42 PM   #94
العلي عز
الصورة الرمزية العلي عز
مشاركات الشكر: 185
شكر 433 مرات في 186 مشاركات
اخي الكريم الروم اكثر من رائعة و لكن عندك مشكلة في الوايرلس
اذا كان نوع الاتصال computer hotspot يعني من كمبيوتر لأخر الروم ما بتشوف شبكة الوايرلس بينما روم سيناجن بتشوف الشبكة و بتشتغل عليها ياريت تعدلها لاني حابب استخدم روماتك
العلي عز غير متصل   رد مع اقتباس
قديم 11-11-2010, 03:23 AM   #95
nicegypt
مشاركات الشكر: 512
لا شغالة جرب اعملها سكيور وبعدين جرب تانى لانها شغالة عندى وانا كمان للاسف مش هعرف اشوفها دلوقت لانى على الرسمى مستنى الجنجربريد علشان نعمل منه روم
قديم 11-11-2010, 12:17 PM   #96
dotshie
مشاركات الشكر: 72
كل شي شغال 100% شكرا لكم جميعا
قديم 12-11-2010, 01:23 AM   #97
العلي عز
مشاركات الشكر: 185
مع كل اسف مش شغاله مع اني عامل للشبكة سكيور و جربت الروم على جهاز ثاني كمان ما اشتغلت
حتى كمان اعدادات ال 3g او 2g مو شغالة
و الباقي الررروم اكثر من رائعة بس للاسف
يا ريت تحاول تحل المشكلة
قديم 12-11-2010, 01:56 AM   #98
nicegypt
مشاركات الشكر: 512
ارجو من احد الاعضاء المستعملين للروم محاولة الاتصال بالشبكة هل توجد مشكلة كما قال الاخ العلى عز
قديم 12-11-2010, 04:31 PM   #99
العلي عز
مشاركات الشكر: 185
اخي nicegypt اليوم جربت الروم على جهاز ثالث و غيرت مزود الخدمة و للاسف النتيجة هي نفسها مافي اتصال بالشبكة
و موضوع الوايرلس كمان ما اشتغل
بصراحة حابب اعتمد هي الروم لدعمك كونك عربي اولا
و عندي اكثررمن 30 شب من اصحابي من مستخدمين نكسس و كلنا عم نجرب روماتك بس هي المشاكل الي ذكرتها عم تمنعنا من التغير و بعدنا على رومات سيناجن
كل الدعاء بالتوفيق لك
قديم 12-11-2010, 05:43 PM   #100
nicegypt
مشاركات الشكر: 512
هنزل تحديث الليلة ان شاء الله فى حل للمشكلة دى دعواتكوا
الماركت, البطارية, ثيم, روم, شرح, rom
جميع الأوقات بتوقيت GMT +3. الساعة الآن 04:10 AM.
