قديم 26-07-2014, 12:32 PM   #1
الصورة الرمزية george_shudi
مشاركات الشكر: 59
شكر 365 مرات في 217 مشاركات
NeatROM v1 for S5 G900F
Welcome to NeatROM for S5 G900F
Simple, clean and reliable
[FONT=Tahoma][SIZE=3]
  • NeatROM for Samsung Galaxy S5 G900F
  • July 26, 2014
  • Firmware: G900FXXU1ANG2 NeatROM v1 Aroma (4.4.2)
  • Build date: Thu Jul 3 14:08:46 KST 2014
  • Modem: XXU1ANG2
  • CSC: SLK1ANG1-Multi
  • Change List: 2089850
  • Available languages in Rom: Azerbaycanca, Bahasa, Catala, Cestina, Dansk, Deutsch, Eesti, English, Espanol, Euskara, Filipino, Francais, Gaeilge, Galego, Hrvatski, Islenska, Italiano, Latviesu, Lietuviu, Makedonski, Magyar, Nederlands, Norsk bokmal, Ozbekcha, Polski, Portugues, Romana, Shqip, Slovencina, Slovenscina, Srpski, Suomi, Svenska, Tieng Viet, Turkce, Udru, Uzbek, Greek, Bulgarian, Russian, Ukrainian, Korean, Chinese...
  • Default Language - English
  • Aroma installer
  • Option to Full Wipe from Aroma
  • Fully Deodexed
  • Zipaligned
  • Rooted
  • BusyBox
  • SuperSU v2.01
  • NO WIPE
  • Disabled Boot Sounds
  • Enabled All Languages for Samsung Keyboard
  • Enabled Secondary Symbols on Stock Keyboard
  • No Auto Converting messages to MMS
  • Modded Mms (Sent Time instead of Received Time)
  • Enabled Sending/Receiving MMS without Data
  • Enabled Signature in Messaging
  • Enabled Scheduled Messaging
  • Increased SMS Hour Limit to 1000
  • Unlimited Recipient SMS/MMS Limit
  • Unlimited Contacts to SMS,MMS
  • No SMS,MMS in Call Log
  • Enabled Call Button in Logs
  • Enabled More Contacts (999)
  • Call Recording
  • Enabled Call & MSG Blocking
  • Enabled Camera Sound Menu
  • Enabled Camera During Call
  • Enabled Screen Capture Sound in Camera
  • Modded Camera (Removed Camera Battery Warnings)
  • Added Exit Browser Option
  • 4 Way Reboot Menu
  • Disabled scrolling cache
  • Enabled Hidden Torch Settings
  • NeatROM WallPapers
  • Allowed Installation Of Apps From Unknown Sources By Default
  • Disabled Verify Apps By Default
  • Disabled Safe Volume Warning
  • Disabled Battery Cover & Charging Cover Toasts
  • Enabled Menu Alarm Alert During Silent Mode
  • Default Screen Animation speed 0.5
  • Cooked through JustArchi's awesome kitchen Thanks to @JustArchi
  • www.NeatROM.com as default home page for Browser
  • Removed Knox
  • Read/Write to External SD Card
  • Deodexed using latest smali/baksmali
  • Zipaligned using latest SDK
  • Rebuilded all permissions
  • Init.d Support
  • Init.d Tweaks
  • Build.prop Tweaks
  • Tweaks
  • Other minor changes and fixes
  • Option to Install:
    - Stock Bootanimation
    - NeatROM Bootanimation Thanks to @momo.martinovic
    - Google Bootanimation
    - Android L Bootanimation
  • Apps:
    - FlashPlayer
    - DropBox
  • Choose the Apps you want to Install:
    - Google Books
    - Google Chrome
    - Google Play Movies
    - Google Drive
    - Google Magazines
    - Google Maps
    - Google Music
    - Google Play Games
    - Google+
    - YouTube
    - ChatON
    - Email/Exchange
    - Flipboard
    - Help Hub
    - Live Wallpapers
    - Memo
    - Mobile Print
    - Polaris Viewer
    - Samsung Update
    - Sansung Fonts
    - Calculator
    - Music Player
    - Video Player
    - Widget Active Application
    - TalkBack
    and many more...
    I probably forgot somethin
ٍScreenshots
Download
http://www.androidfilehost.com/?fid=23578570567718551
Installation Instructions via CWM recovery (KNOX 0x1)
1. PLEASE make a Nandroid backup of your current ROM!!!!
2. Backup your Internal SD to your PC
3. Download NeatROM onto your phone (either internal or external SD card) and reboot your phone into recovery mode (turn your phone off and then press & hold Volume Up & Home & Power buttons)
4. Reboot your phone into recovery mode (turn your phone off and then press & hold Volume Up & Home & Power buttons)
" IF YOU'RE COMING FROM ANOTHER CUSTOM ROM OR HAVING ISSUES WITH APPS FORCE CLOSING AFTER THE FIRST BOOT, IT IS HIGHLY RECOMMENDED TO WIPE DATA AND THEN INSTALL NeatROM"
5. Select "Install Zip" and then navigate to where the NeatROM zip is located on your SD card
6. Once the Aroma Installer starts, select the options that you would like to install
7. When the ROM has finished installing, and at the end of the installation process in Aroma, UN-TICK "Reboot Device"---pic1
8. Remove the battery for a few moments and then put it back in, boot into Download Mode (press Volume Down + Home + Power, then press volume up)
9. Download and open PC Odin
10. Download, extract and flash MODEM (load as CP) and BOOTLOADER (load as BL) in ONE STEP---pic1---pic2
11. If something goes wrong and your device will not boot after flashing, try to remove the battery for a few moments and then put it back in, press and hold VolumeUP + Home + Power to boot the device into recovery mode and do a "wipe Data"
12. Enjoy your NeatROM
<b>
Installation Instructions: If you're coming from a Samsung stock NON-Rooted ROM before NG1/NG2 (KNOX 0x0)
1. Backup your Internal SD to your PC
2. Go to Settings/Security/Security policy updates/ and UN-TICK "Automatic updates"
3. Go to Settings/Security/ and UN-TICK "Send security reports"
4. Go to Settings/About device/Software update/ and UN-TICK "Auto update"
5. Root your phone with Towelroot---pic1---pic2
6. Reboot and install SuperSu from the PlayStore
7. Run SuperSU and select "Continue", "Normal" and "Cancel". Reboot device.---pic1,---pic2,---pic3
8. Run SuperSU again and select "Try to disable KNOX"---pic1,---pic2
9. Reboot and download NeatROM onto your phone
10. Check the md5sum of the NeatROM.zip
11. Purchase and install Mobile Odin Pro
12. Run Mobile Odin Pro---pic1---pic2
13. Load the NeatROM.zip file with "OTA / Update ZIP"---pic1,---pic2
14. UN-TICK "Enable EverRoot" (NeatROM is already rooted)---pic1
15. UN-TICK "Wipe data and cache"---pic1
16. UN-TICK "Wipe Dalvik cache"---pic1
17. Select "After flash..." then select "Download mode"---pic1,---pic2
18. Select "Flash firmware"---pic1
19. Once the Aroma Installer starts, select the options that you would like to install
20. When the ROM has finished installing, and at the end of the installation process in Aroma, UN-TICK "Reboot Device"---pic1
21. When the phone goes into Download Mode, download and open PC Odin
22. Extract and flash MODEM (load as CP) and BOOTLOADER (load as BL) in ONE STEP---pic1---pic2
23. If something goes wrong and your device will not boot after flashing, try to remove the battery for a few moments and then put it back in, press and hold VolumeUP + Home + Power to boot the device into recovery mode and do a "wipe Data/factory reset" then "reboot system now"
24. Go to Settings/Security/Security policy updates/ and UN-TICK "Automatic updates"
25. Go to Settings/Security/ and UN-TICK "Send security reports"
26. Enjoy your NeatROM with KNOX 0x0
Installation Instructions: If you're coming from a Samsung stock NON-Rooted NG1/NG2 ROM (KNOX 0x0)
2. Download, extract, boot the phone into Download Mode and flash this ROM using PC Odin (use AP on Odin)---pic1,---pic2
3. Boot the phone normally. If something goes wrong and your device will not boot after flashing, try to remove the battery for a few moments and then put it back in, press and hold VolumeUP + Home + Power to boot the device into recovery mode and do a "wipe data/factory reset" then "reboot system now"
6. Go to Settings/About device/Software update/ and UN-TICK "Auto update"
7. Root your phone with Towelroot---pic1---pic2
8. Reboot and install SuperSu from the PlayStore
9. Run SuperSU and select "Continue", "Normal" and "Cancel". Reboot device.---pic1,---pic2,---pic3
10. Run SuperSU again and select "Try to disable KNOX"---pic1,---pic2
11. Reboot and download NeatROM onto your phone
12. Check the md5sum of the NeatROM.zip
13. Purchase and install Mobile Odin Pro
14. Run Mobile Odin Pro---pic1---pic2
15. Load the NeatROM.zip file with "OTA / Update ZIP"---pic1,---pic2
16. UN-TICK "Enable EverRoot" (NeatROM is already rooted)---pic1
17. UN-TICK "Wipe data and cache"---pic1
18. UN-TICK "Wipe Dalvik cache"---pic1
19. Select "After flash..." then select "Download mode"---pic1,---pic2
20. Select "Flash firmware"---pic1
21. Once the Aroma Installer starts, select the options that you would like to install
22. When the ROM has finished installing, and at the end of the installation process in Aroma, UN-TICK "Reboot Device"---pic1
23. When the phone goes into Download Mode, download and open PC Odin
24. Extract and flash MODEM (load as CP) and BOOTLOADER (load as BL) in ONE STEP---pic1---pic2
25. If something goes wrong and your device will not boot after flashing, try to remove the battery for a few moments and then put it back in, press and hold VolumeUP + Home + Power to boot the device into recovery mode and do a "wipe data/factory reset" then "reboot system now"
26. Go to Settings/Security/Security policy updates/ and UN-TICK "Automatic updates"
27. Go to Settings/Security/ and UN-TICK "Send security reports"
28. Enjoy your NeatROM with KNOX 0x0
الموضوع الاصلي
http://forum.xda-developers.com/gala...om-v1-t2828562
انا لا املك الاس 5 ولكني نقلت هذا الموضوع لهذا المنتدى للفائده للاخوه الاعضاء
لاتقل شكرا اضغط كلمه شكر
george_shudi غير متصل   رد مع اقتباس
عدد 4 من الاعضاء يشكرون george_shudi على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
اخر 5 مواضيع للعضو george_shudi
مساعدة لو سمحتم: جهازي لم يعد يعمل نهائيا ولا... قسم ترقيات أجهزة Samsung بنظام Google Android عش الصقر 3 1499 02-01-2016 08:46 PM
طلب فك تشفير sim card الرجاء التفاعل جهازي هو S4... ملتقى المطورين لنظام Google Android mahmoodmomani 2 2100 12-05-2015 01:45 PM
Samsung Galaxy S4 I9505XXUHOB7 (BTU) (Android... قسم ترقيات أجهزة Samsung بنظام Google Android adoosy 8 5471 14-03-2015 03:23 PM
Whatsapp Plus New versions منتدى Google Android للبرامج HILALHATEM 17 3903 12-03-2015 12:04 AM
اسامه غريب واتس اب بلس 6.40 مكرك ومعرب منتدى Google Android للبرامج حسنكو 23 17634 14-11-2014 08:14 PM
قديم 26-07-2014, 04:13 PM   #2
sazindia
الصورة الرمزية sazindia
مشاركات الشكر: 2,655
شكر 340 مرات في 198 مشاركات
شكرا لك أخي ..
george_shudi
sazindia غير متصل   رد مع اقتباس
قديم 27-07-2014, 07:44 PM   #3
george_shudi
مشاركات الشكر: 59
المشاركة الأصلية كتبت بواسطة sazindia مشاهدة المشاركة
شكرا لك أخي ..
george_shudi
عفوا اخي ... يرفع للفائده
قديم 27-07-2014, 10:53 PM   #4
aletewy
الصورة الرمزية aletewy
مشاركات الشكر: 5,055
شكر 3,510 مرات في 2,159 مشاركات
بالتاكيد هيكون تحفة لكن هل يحتاج الاس5 لروم معدل ام ان الانسان يحتاج للتغيير دوما
aletewy غير متصل   رد مع اقتباس
قديم 27-07-2014, 10:59 PM   #5
george_shudi
مشاركات الشكر: 59
المشاركة الأصلية كتبت بواسطة aetewy مشاهدة المشاركة
الانسان مدمن تغيير في كل شيء حتى لايمل من الروتين اليومي.
العضو التالي يشكر george_shudi على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 22-08-2014, 11:07 AM   #6
george_shudi
مشاركات الشكر: 59
يبدو ان لا احد يمتلك الاس 5 هذا الاصدار
S5 G900F
android, dropbox, firmware, galaxy, galaxy s, google, mms, rom, samsung, samsung galaxy, sms
جميع الأوقات بتوقيت GMT +3. الساعة الآن 10:17 AM.
