قديم 02-06-2016, 08:49 AM   #126
مشاركات الشكر: 83,775
الإصدار الأخير من الروم :
ResurrectionRemix-M-v5.6.8
كان بتاريخ 2016- مايو -03
(أنا لم أجرب الروم حتى الآن)
وهذا رابط الروم :
https://basketbuild.com/filedl/devs?...60503-hlte.zip
وهذه كانت تغييرات الروم :
The Changelog
# ResurrectionRemix - v5.6.8 - Android r30 - 20160502
- Android 6.0.1_r24-> r30
- Update Bootanimations
- Update boot logo same as bootanimation
- Custom Settings Dashboard Colors
- Pulse Visualizer Sanity Level
- Pulse Bar Customizations
- Configurable Pulse Bar Spacing
- ThemeChooser: update UI
- Fix Selinux permessive mode reset after every reboot
- Dyanamically Configurable Pulse Bar Dimensions
- Floating Window
- Add Back Pie
- Add Pulse Tile
- Statusbar weather: fix temp style after refresh
- FWB :SmartBar Button Tint
- Update some settings configurations icons
- Disable expanded status bar weather by default
- Add Option to Enable/Disable ScreenShot & ScreenRecord Shorcut
- Configurable Keyguard Quick Shortcut Colors
- LLS: Show notification panel if LLS crashes
- LLS: Fix screen off event firing when not interactive
- Improve TM animation & use stock detail background
- Use CircularReveal animation to show/hide task manager panel
- Add the ability to hide superuser status bar icon
- Switch back to cm root as default
- Keyguard Charging Current Switch
- Keyguard: show charging current in mAh on lockscreen
- Themes: Update icon mapping on boot
- Update themes icon drawables
- fwb: Add ability to permanently hide apps from recents
- ThemesTile: Don't process clicks on current theme item
- ThemeTile: Custom QS detail header title support for theming apps
- About RR : Add g+ account to profile cards instead of twitter
- Update Some Settings Activities
- Settings: Ensure user has to wait 30 before retrying pattern
- SystemUI: add HeadsUp snooze disabled state
- bootanimation: Switch to readahead
- SystemUI: HeadsUp toast message
- SysUI: Improve Show3g Logic
- add ability to disable bar color in battery saver mode
- Global actions: fix airplane mode switch for MSIM
- SystemUI: Fix nav bar transparency when enabling software keys
- SysUI: Fix reporting of swipe progess in notification panel
- Lockscreen : Ensure we hide bottom area in bouncer
- livedisplay: Moving LiveDisplay to CMSDK
- Lockscreen : Update shortcuts in onAttachWindow
- GlobalActions: Always use setZenMode
- Lockscreen : Fix dead-zone in bottom area
- Remove Hide Settings Icon from header
- SystemUI: fix double tab launching custom lockscreen icon
- Point Amibent display tile longpress action to it's own settings
- Remove Invert Colors and Cast Tiles as Default
- Update A Custom SB logo
- Check for deprecated third party keyguard perm
- packagemanager: Fix bootloop if packages.xml is deleted
- Fix Heads Up and TaskManager buttons in StatusBarHeaderView
- QSTiles: set disconnect callback in bluetooth details list adapter
- SystemUI: Fix Statusbar Clock font size/color on location changes
- Support for new properties to identify country based ecc #s added by RIL
- Remove the brightness mirror
- Give LockClock the location permission by default
- translation imports
- For more info Track Github Activities
قديم 02-06-2016, 05:40 PM   #127
Smile صور للإصدار ResurrectionRemix-M-v5.6.8 من هاتفي
صور للإصدار ResurrectionRemix-M-v5.6.8 من هاتفي :
(قبل مشاهدة صور الروم ، أحب أن أقول بأن الروم وإن كان بنظام 6.0.1 فلا يوجد فيه تأخر في برامج الصلوات ، وأعتقد مشكلة التأخر في بعض الأجهزة بنظام 6.0.1 ليست من جوجل ولا من نظام المارشميلو ، و إنما بسبب تعديل بعض الشركات على النظام وعدم إحسانها في التعديل مثل السامـسونج والهـواوي وغيرها)
الصفحة الرئيسة ، كما جاء بعد تركيب الروم :
02104039am 1157587 83322 0 618519
قسم البرامج :
صورتها قبل تركيب برامجي
02104039am 1157588 83322 0 618519
02104039am 1157589 83322 0 618519
البار العلوي ، الشاشة المنسدلة (يمكن التعديل عليها) :
02104039am 1157590 83322 0 618519
الإعدادات (الضبط) :
02104039am 1157591 83322 0 618519
02104040am 1157592 83322 0 618519
02104040am 1157593 83322 0 618519
02104040am 1157594 83322 0 618519
02104040am 1157595 83322 0 618519
الضبط المخصص (من عمل مطور الروم) :
بواسطته يمكن التعديل على معظم خصائص الروم
02104040am 1157596 83322 0 618519
02104040am 1157597 83322 0 618519
حول الهاتف (معلومات النظام) :
02104040am 1157598 83322 0 618519
02104040am 1157599 83322 0 618519
عدد 5 من الاعضاء يشكرون Nooruddeen على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 05-06-2016, 02:13 PM   #128
مثير
مشاركات الشكر: 24
شكر 141 مرات في 68 مشاركات
شكرا لك أخي محمد على ذكر تجربتك ، وجزاك الله خيرا وبارك فيك...
ننتظر الأخ مثير ليعدل الموضوع ويحدثه إلى أحدث إصدار...
أنا ما زلت أنتظر رومات CyanogenMod من الفريق نفسه لكي أجرب النظام6 الخام الأقرب إلى النظام الخام المستخدم في رومات النكسوس، مع أني أحب رومات CyanogenMod أكثر من رومات النكسوس بسبب الخيارات والتعديلات الجميلة المفيدة التي في رومات CyanogenMod
والحمد لله.
شكراً أخي نور الدين .. تم التعديل ..
وتم تحميل الاصدار الأخير من الروم على جهاد أحد الأصدقاء .. وكان رائعة وسلس وسريع ولا يصرف البطارية مع أداء رائع .. لا ينقصه غير القلم ودعم الذاكرة الخارجية بشكل كامل ..
أكرر شكري الجزيل لك .. والشكر موصول لباقي الاخوة الذي تفاعلوا مع هذا الإصدار ..
كنت متحمس جداص لهذا الروم لأنه أول روم يعطي روعة المارشميلو على النوت
لكن بعد نزول الاصدارات الجديد المعدلة للنوت 3 للمارشميلو .. قللت من متابعة هذا الروم ..
وهذا لا يقلل من أهميته وروعة أدائه ..
شكراً للجميع
مثير غير متصل   رد مع اقتباس
العضو التالي يشكر مثير على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 05-06-2016, 06:02 PM   #129
المشاركة الأصلية كتبت بواسطة مثير مشاهدة المشاركة
شكراً للجميع
العفو...
وشكرا لك على متابعة الموضوع ، وجزاك الله خيرا وبارك فيك...
وأسأل الله أن ينفع بالموضوع المسلمين...
قديم 03-12-2016, 12:42 AM   #130
مـسطح
الصورة الرمزية مـسطح
مشاركات الشكر: 143
شكر 917 مرات في 326 مشاركات
ما فيه اخبار عن الروم هذا
و التحديث لنوجا !!
مـسطح غير متصل   رد مع اقتباس
عدد 2 من الاعضاء يشكرون مـسطح على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 03-12-2016, 08:23 AM   #131
المشاركة الأصلية كتبت بواسطة مـسطح مشاهدة المشاركة
و التحديث لنوجا !!
آخر تحديث هو v5.7.4 بنظام المارشميلو ، وكان بتاريخ 2016-09-21
ولا توجد أخبار عن التحديث إلى نوجا (حسب علمي)
قديم 03-12-2016, 08:34 AM   #132
yassein2
مشاركات الشكر: 4,038
شكر 1,054 مرات في 307 مشاركات
من كلام المطور في صفحه الروم علي xda الاحظ انه يعمل علي اصدار جديد بنظام نوجا
أرسلت من SM-N930F بإستخدام تاباتلك
yassein2 غير متصل   رد مع اقتباس
عدد 3 من الاعضاء يشكرون yassein2 على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 03-12-2016, 06:55 PM   #133
مـسطح
مشاركات الشكر: 143
شفت قبل فتره انو محدثين بعض الاجهزه ل نوجا
العضو التالي يشكر مـسطح على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 03-12-2016, 07:25 PM   #134
yassein2
فعلا انا متابع صفحه مطورين الروم علي جوجل بلس وحدثوا اجهزه والباقي قالوا انهم شغالين عليه
أرسلت من SM-N9300 بإستخدام تاباتلك
عدد 2 من الاعضاء يشكرون yassein2 على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 03-12-2016, 09:25 PM   #135
مـسطح
مشاركات الشكر: 143
شي جميل
ننتضر يوصل لنوت 3
قديم 05-12-2016, 10:23 AM   #136
ankedo7000
شكر 40 مرات في 30 مشاركات
روم روعه خفيف مستقر خالي من المشاكل البطاريه ممتازه بصراحه امتيازافضل بي مراحل من رومات بورتات النوت سبعه بعد الاستعمال المكثف لمده ثلاث ايام استطيع ان اقول لا ينقصه الا القلم عسى من الاعضاء ان يرفعوا لنا برنامج القلم المدفوع وشكرا
ankedo7000 غير متصل   رد مع اقتباس
عدد 2 من الاعضاء يشكرون ankedo7000 على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
galaxy, google, rom, البطارية, تحميل, تنصيب, ثيم, رسمي, روم, شرح, قوقل
جميع الأوقات بتوقيت GMT +3. الساعة الآن 01:05 AM.
