here is an edited venom Boot animation , i just removed the moving snake from it ( i hate snakes ) , so it is for any one who feel like i do
thanks to the Developer for a nice Rom
Modified Bootanimation
- Update , it will work with ViperS v1.4.0 ( md5 is the same for all 3 Bootanimations for both v1.4 and v1.3.5 )
- Update , i modified the Bootanimations to play better ( the whole Sensation / Sensation XE / Sensation 4G appear in the first cycle )
- Update , i added both Sensation and Sensation 4G as requested by users
- just push it to system \ customize \ resource ( make sure it replaced the old one ) , change permission and ownership same as the old Bootanimation .
- reboot into recovery , clear dalvik cache and cache let it boot up ( you may need to do this step for a second time if it hangs in a full reboot
- or just put it in your rom.zip before flashing in :
- For Sensation XE and Sensation 4G , Path is extra \ model \ ( XE or 4G ) before flashing according to your choice
- For Sensation , Path is system \ customize \ resource
- or just use tweaks to set it as custom bootanimation
Download links
Modified Initial Wallpaper
if you would like to change the Snake wallpaper that appears after the initial flash of the Rom
Method 1
- open rom.zip in winrar window and navigate to system \ customize \ resource
- choose any htc wallpaper ( usually is named sense_wallpaper_***.jpg ) and drag it to the desktop
- rename it to Viper3.jpg and drag it back to the winrar window to replace the existing Viper3
Method 2
- open rom.zip in winrar window and navigate to system , and drag build.prop to the desktop
- edit the build.prop using Notepad++
- Original Value : dev.defaultwallpaper , value is /system/customize/resource/viper3.jpg
- New Value : dev.defaultwallpaper , value is /system/customize/resource/ sense_wallpaper_***.jpg
- ( *** means the name of the wall paper you choose ,example sense_wallpaper_htc_default.jpg )
- Save changes , drag the edited build.prop back to the winrar window to replace the existing
الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 04:18 AM ----------- المشاركة السابقة اضيفت في 04:09 AM ---------
if you don't know how to replace the file then open : venom tweaks \advanced then use custom bootanimation
or to copy and paste just use root explorer
or use ES file explorer ( in ES file explorer enable root in options )
then mount system read\write
then navigate to system \customize\resource and replace the existing one
edit the permission according to the attached photo
