[WM6] XDA Mobile 6 ROM كي جام
تحديث ال XDA إلى wm6
* Windows Mobile 6, OS 5.2.318 Build 15342.4.0.01 * ROM Version: 10.1.0.811 WWE * ROM Date: 08/11/06 * Protocol: 4.1.13.09 * ExtROM version: Faria V5.0 Software * Office 2007 * New 8 Button CommManager (yeah only 8 buttons. If you want more then install one of the many 10 or more button ones ) * Transcriber * VoIP (See next post for instructions to set this up) * SQLCE * mUn designed onscreen Keyboard * HTC X-Button v1.0 (The new 1.5 version has issues with impacting changes on the Today screen so I'm staying with v1.0) and turned on by default * Mobile Justice (a security app that will send an SMS if an unauthorized SIM is placed in your phone) * TodayAgenda * Notepad editor * Pocket RAR * SIP Config 2.0.1 * StartClean * Pocket Screen Capture * HTC Audio Manager * CicleBT (Toggle BlueTooth on and off) * SynchroTime * 1-Calc Lite * Total Commander Beta 2.5 * WiFiFoFum 2.2.9 * PIM Backup to 1.9 * Windows Live Search searches via Google * MoDaCo NoData (so you can turn off data sources) * WM5torage 1.73 * dotFred TaskManager (with registry editor link) * Smartskey 0.56 (DPAD is set to 0 in the .ini so the up and down scrolling works in the Phone dialer as expected in WM6) * SIM Manager * WM5NewMenu * SMSDRFix * DotFred's SoftKeyAppletEx * DotFred's TaskManager (and registry editor) * WiFiFoFum * Regional Settings default to English (United States) and use a slash for the date seperator (M/dd/yyyy) * Menu sounds work by default * Pressing the "End Call" button does not disconnect GPRS but minimized the active application. Pressing and holding the "End Call" button for about 5 seconds will do a GPRS Disconnect * Internet access over ActiveSync (USB) connection works (You must apply a registry fix on your PC first. See the next post for the fix) [IMG]http://www.ce4arab.com/vb7/pub2/9088.imgcache[/IMG] [B][CENTER][COLOR="Blue"][URL="http://rapidshare.com/files/37288886/XDA_Mobile_6.0.0.zip"]التـحميـــــــــل[/URL][/COLOR][/CENTER][/B] |
مشكور جزيل الشكر عزيزي.
للأسف عندي I-mate JAM، لكن اتمنى بأن أخواننا الأعضاء يستفيدون منه. جزاك الله خير |
الف شكر اخوي لكن ياريت لو رابط غير الرابط العجيب (الرابيد شير) :(
[quote=PPC Master;718834]الف شكر اخوي لكن ياريت لو رابط غير الرابط العجيب (الرابيد شير) :([/quote]
[CENTER][SIZE=5]من يسأل عن [URL="http://www.mediafire.com/?bgm1obxgge2"][U]رابط آخر لتحميل الـXDA WM6 [/U][/URL][/SIZE] [SIZE=5]حصري لاخواننا في المنتدى الحبيب؟[/SIZE][/CENTER] [CENTER]:thumbup: :thumbup: :thumbup: :thumbup: :thumbup: [/CENTER] |
[quote=samery;718992][CENTER][SIZE=5]من يسأل عن [URL="http://www.mediafire.com/?bgm1obxgge2"][U]رابط آخر لتحميل الـXDA WM6 [/U][/URL][/SIZE]
[SIZE=5]حصري لاخواننا في المنتدى الحبيب؟[/SIZE][/CENTER] [CENTER]:thumbup: :thumbup: :thumbup: :thumbup: :thumbup: [/CENTER] [/quote] انت احسن واحد بالدنيا :o |
انا دائمآ موجود لخدمة الجميع والله يعيني دائمآ على خدمتكم وعلى ان اكون عند حسن ظنكم. :D:D:D
وشكرآ على مرورك يا اخي الحبيب وهلا بجميع اهالي البحرين الغالين على القلب على راسهم PPC Master :thumbup: |
dear great job I realy likt to try
عند تنزيل التعريب ،الازرار تتوقف عن العمل
ما هو التعريب الذي إستخدمته؟
يا شباب هل جربتم التعريب مع هذه الروم؟ يمكنك مساعدة اخوكم في هذا الحال |
شكراا لك اخي ولكن افضل ان اجرب قبلها tnt 4
تحياتي لك اخي وارجو ان نرى منك المزيد من الابداع |
لقد جربت هذه النسخة و لم تكن ثابتة أبدا خصوصا بعد التعريب
.... قمت بتجريب أنواع التعريب الثلاثة معها ..... أنا أقيمها بنصف نجمة فقط مع العربي بدون التعريب نجمتان والسلام عليكم |
السلام عليكم تم التحميل والتجربه على XDA IIs w2005
واعطى رساله انه لايتعرف على الجهاز ارجو التفضل بالرد اذا الروم غير مصمم لهذا الجهاز او هناك طريقه تختلف عن 2005 |
[quote=حسين الجبوري;722944]السلام عليكم تم التحميل والتجربه على XDA IIs w2005
واعطى رساله انه لايتعرف على الجهاز ارجو التفضل بالرد اذا الروم غير مصمم لهذا الجهاز او هناك طريقه تختلف عن 2005[/quote] نعم اخي الكريم الجهازين مختلفين ولا ينصح التجربة وشكرآ |
سوف يتم تحريب النسخة ان شاء الله اليوم واعطيكم الرد غدا بازن الله تعالى بس عايز اعرف استخدم اى تعريب معاها ارجو الرد اخوكم ماجدامين |
جربتها ولكن غير مستقرة ويعلق الجهاز
أحيانا اتصل على الجهاز يرن ولكن الجوال لا يظهر اي شيء لا رنه ولا صوت ولا تعرف ابدا ان هناك اتصال |
مشكور جدا جدا جدا[quote=vidodido;718725]تحديث ال XDA إلى wm6
* Windows Mobile 6, OS 5.2.318 Build 15342.4.0.01 * ROM Version: 10.1.0.811 WWE * ROM Date: 08/11/06 * Protocol: 4.1.13.09 * ExtROM version: Faria V5.0 Software * Office 2007 * New 8 Button CommManager (yeah only 8 buttons. If you want more then install one of the many 10 or more button ones ) * Transcriber * VoIP (See next post for instructions to set this up) * SQLCE * mUn designed onscreen Keyboard * HTC X-Button v1.0 (The new 1.5 version has issues with impacting changes on the Today screen so I'm staying with v1.0) and turned on by default * Mobile Justice (a security app that will send an SMS if an unauthorized SIM is placed in your phone) * TodayAgenda * Notepad editor * Pocket RAR * SIP Config 2.0.1 * StartClean * Pocket Screen Capture * HTC Audio Manager * CicleBT (Toggle BlueTooth on and off) * SynchroTime * 1-Calc Lite * Total Commander Beta 2.5 * WiFiFoFum 2.2.9 * PIM Backup to 1.9 * Windows Live Search searches via Google * MoDaCo NoData (so you can turn off data sources) * WM5torage 1.73 * dotFred TaskManager (with registry editor link) * Smartskey 0.56 (DPAD is set to 0 in the .ini so the up and down scrolling works in the Phone dialer as expected in WM6) * SIM Manager * WM5NewMenu * SMSDRFix * DotFred's SoftKeyAppletEx * DotFred's TaskManager (and registry editor) * WiFiFoFum * Regional Settings default to English (United States) and use a slash for the date seperator (M/dd/yyyy) * Menu sounds work by default * Pressing the "End Call" button does not disconnect GPRS but minimized the active application. Pressing and holding the "End Call" button for about 5 seconds will do a GPRS Disconnect * Internet access over ActiveSync (USB) connection works (You must apply a registry fix on your PC first. See the next post for the fix) [URL]http://www.ce4arab.com/vb7/pub2/9088.imgcache[/URL] [B][CENTER][color="Blue"][URL="http://www.ce4arab.com/vb7/redirector.php?url=http%3A%2F%2Frapidshare.com%2Ffiles%2F37288886%2FXDA_Mobile_6.0.0.zip"]التـحميـــــــــل[/URL][/color][/CENTER] [/B][/quote] |
المعذرة اقصد في الشكر الاخ صاحب الموضوع
لا يوجد من مشكلة، الشكر للجميع على التواصل والإفادة والخدمات
هل هذه النسخة يوجد بها عربي
اخي الكريم برنامج التعريب لجهازك شغال إن شاء الله على اي روم ومرفوع على:
[url]Http://samery.4shared.com[/url] password = ce4arab go to KJAM |
جميع الأوقات بتوقيت GMT +3. الساعة الآن 12:27 PM. |
