مود سحري للنوت 2
السلام عليكم اعضاء وزوار المنتدى
اضع بين ايديكم اليوم هذا المود الرائع الخاص بالجالكسي نوت 2 وهو عبارة عن صندوق ادوات متعدد الوظائف ويحتوي على العديد والعديد من المميزات والادوات اللتي ستساعد الى حد كبير في تحسين اداء الهاتف وعن تجربة شخصية :) اذكر من بينها * تطوير حساسية اللمس * تسريع الانترنت * تحسين جودة الكميرا والفيديو (والفرق واضح) :thumbup: *تحسين اداء المعالج * تحسين جودة الصور jpg * تسريع الرام * بطارية ادوم [B][I]init.d scripts ------------------- [/I][/B] "Touchscreen Responsiveness", "Improve the touchscreen for a better responsiveness and user experience" "Internet speed tweaks","Improve overall browsing speed" "Battery consumption tweaks","Make battery last longer" "Defragmentation of sqlite3 databases at each boot","Defrags databases to increase write-speed" "Force GPU 2D Rendering","Force GPU rendering on 2D operations" "Improve Multi-Tasking","Change system task-killer settings" "Install various init.d smoothness tweaks","Improve general responsiveness and fixes lag" "Enable Internal/External-SdCard I/O tweaks","Improve write/read speed and mount speed" "Zipalign apks at each boot","Will zipalign all apk files to increase smoothness" "Enable main thunderbolt system_tweak script","Increase multitasking and general performances" "Use TCP buffers tweaks","Tweak the tcp buffers to improve internet browsing speed" [B][I][B][I]Build.prop Tweak[/I][/B] --------------------------------------- [/I][/B] "3G Signal and Speed tweaks","Improve signal reception and dl/ul speed when using 3g" "Battery saving tweaks","Saves battery without reducing performances" "Camera quality tweaks","Increase camera's photo and video recording quality" "Wifi tweaks","Connects and disconnects faster" "Dalvik Ram tweaks","More free ram and apps load faster" "Deeper Sleep","Saves more battery when on sleep mode" "Dialing time tweaks","Dials faster, phone will ring instantly" "Increase Jpg images quality","Raises the jpg image quality to 100%" "Disable kernel error checking","Prevents some fc's from happening" "Internet speed tweaks","Faster browsing and downloads" "Touchscreen tweaks","Increase general touchscreen responsiveness" "Remove black screen after calling","Reduces the time proximity sensor takes to make screen on" "Allow purgeable assets","Free-up more ram" "Scrolling tweaks","Better, faster and stronger scrolling" "Video-Streaming tweaks","Smoother and faster internet video streaming" "Quick Power-On","The device will boot faster" "Flash-Led Tweaks","Better flash-led intensity and camera-flash quality" [B][I]Enable/Disable Functionalities ----------------------------------- [/I][/B]"Enable video hardware acceleration","Hardware video decoding enabled" "Enable Gpu ui rendering","Force the ui to be rendered by the gpu" "Disable Normalized Sleeper","Saves battery by transforming some wait-times into sleep times" "Disable Gentle Fair Sleepers","Saves battery by transforming some wait-times into sleep times" "Disable New Fair Sleepers","Saves battery by transforming some wait-times into sleep times" [ B][I]Networks & Internet Sysctl Tweak ------------------------------------------- [/I][/B]"Network multitasking stability","Improve buffer size and queue size for each tcp sockets" "Avoid time-wait","Re-use Sockets in time-wait state to avoid memory-loading" "IPv4 protocol sysctl tweaks","Overall ipv4 speed improvements" "DNS and ppp0 interface tweaks","faster ppp0 interface & faster name resolution (faster connection to websites)" التثبيت من الريكوفري يستحسن عمل nandroid backup ويحب عمل تسخة احتياطية من ملف build.prop عبر برنامج Root explorer اذهب الى system حول mount الى r/o ومن تم انسخ ملف build.prop واحتفظ به في الذاكوة الخارجية في حال اردت الرجوع الي الاعدادات السابقة . * الموضوع مجهود شخصي * ----------------------- ارجو ان اكون قد وفقت في الشرح وفي اختيار الموضوع ودمتم بالف خير التحميل من موقع xda devellopers [url="http://forum.xda-developers.com/showpost.php?p=41922793&postcount=3"]xda-developers - View Single Post - [TOOL][28/05/13] ##### Tweak BOX ##### [init.d, build.prop, internet and 3G tweaks][/url] |
شكرا لك عزيزي ، السؤال يركب لنوت2 فورجي والا لا؟ وشكرا
شكرا اخي cayberfoxe على هذا المجهود وهل ممكن ان توضح الموضوع اكثر
تحياتي |
[quote=T2btmnk;4191783]شكرا لك عزيزي ، السؤال يركب لنوت2 فورجي والا لا؟ وشكرا[/quote]
المود خاص للنسخة العالمية Galaxy note 2 N7100[COLOR="Silver"] [SIZE=2]الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 08:54 PM ----------- المشاركة السابقة اضيفت في 08:45 PM --------- [/SIZE] [/COLOR][quote=M H N;4191853]شكرا اخي cayberfoxe على هذا المجهود وهل ممكن ان توضح الموضوع اكثر تحياتي[/quote] اخي الكريم اعتقد ان الشرح وافي المود يحتوي على ادوات لتحسين اداء النوت 2 يركب عن طريق الريكوفري ببساطة كاي مود اخر وبالطبع يحتاج رووت |
مشكوووووووور
تم الإرسال من جهازي GT-N7100 بواسطة تاباتوك 2 |
جزاك الله كل خير
وبارك الله فيك مشكور وتسلم أيدك |
هل يحتاج روت ؟
لاكن هناك خيارات كثيره بالاروما
للاسف الكثير لايجيد الانجليزيه ممكن شرح تم الإرسال من جهازي GT-N7100 بواسطة تاباتوك 2 |
[quote=drahmedaa;4192088]جزاك الله كل خير
وبارك الله فيك مشكور وتسلم أيدك[/quote] وبارك فيك اخي[COLOR="Silver"] [SIZE=2]الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 05:59 PM ----------- المشاركة السابقة اضيفت في 05:57 PM --------- [/SIZE] [/COLOR][quote=سام جدا;4192215]هل يحتاج روت ؟[/quote] نعم يتطلب رووت[COLOR="Silver"] [SIZE=2]الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 05:59 PM ----------- المشاركة السابقة اضيفت في 05:59 PM --------- [/SIZE] [/COLOR][quote=moobidat;4192267]سلمك الله واعطاك الصحة والعافية[/quote] الله يسلمك[COLOR="Silver"] [SIZE=2]الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 06:07 PM ----------- المشاركة السابقة اضيفت في 05:59 PM --------- [/SIZE] [/COLOR][quote=همام الكلدي;4192441]لاكن هناك خيارات كثيره بالاروما للاسف الكثير لايجيد الانجليزيه ممكن شرح تم الإرسال من جهازي GT-N7100 بواسطة تاباتوك 2[/quote] اخي همام المود لتحسين اداء المعالج .الكاميرا .جودة الصور والفيديو ولتسريع الرام وتنقية صوت السبيكر والكثير من المزايا الاخرى |
اخي هل يعمل على الاس 3 I9300
[quote=طلال اسلام;4193362]اخي هل يعمل على الاس 3 I9300[/quote]
اخي اقرا عنوان الموضوع المود للنوت 2 طراز N7100 فقط == |
ممكن رابط اخر لتنزيل المود
الان موقع التنزيل موقف في بلدي |
هل يشتغل عاي روم ونام 3.5
شكرا اخي الكريم Sent from my GT-N7100 using Tapatalk 2 |
ياليت احدمن الشباب الذي استخدم المودينزللنا صورة توضح الفرق في جودة الصور
اسئال الاخ الحبيب صاحب الموضوع عن طريقة الرجوع للمود الاصلي هل عن طريق الريكفري ام مجرد نقل للملف اذي نسخة من قبل |
كل الشكر اخي العزيز هل ينفع على الروم الرسمي ونوع الركفري لو سمحت الذي تستخدمه مع شكري الخالص
[quote=cyberfoxe;4193431]اخي اقرا عنوان الموضوع المود للنوت 2 طراز N7100 فقط
==[/quote] السلام عليكم طيب ممكن مود مثل هذا للاس 3 شكرا مقدما |
[quote=cyberfoxe;4193264]اخي همام المود لتحسين اداء المعالج .الكاميرا .جودة الصور والفيديو ولتسريع الرام وتنقية صوت السبيكر والكثير من المزايا الاخرى[/quote]
طيب اخوي من افلش المود من الركفري تاتي خيارات بالاروما اشر على الجميع بالصح ولا كيف تم الإرسال من جهازي GT-N7100 بواسطة تاباتوك 2 |
أكرر ممكن رابط اخر لتنزيل المود
تم التثبيت من الريكفري على النوت 2 فور جي روم ونام الاخير..وقد قمت اثناﺀ التثبيت بوضع صح على جميع الخيارات وجاري اكتشاف اي متغيرات..مبدئيا لا أشعر بوجود شي قد تغير
[quote=awsx;4193726]ياليت احدمن الشباب الذي استخدم المودينزللنا صورة توضح الفرق في جودة الصور
اسئال الاخ الحبيب صاحب الموضوع عن طريقة الرجوع للمود الاصلي هل عن طريق الريكفري ام مجرد نقل للملف اذي نسخة من قبل[/quote] يستحسن عمل نسخة احتياطية بواسطة الريكوفري nandroid backup في حالة اردت الرجوع الى الاعدادات الستبقة[COLOR="Silver"] [SIZE=2]الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 04:46 PM ----------- المشاركة السابقة اضيفت في 04:41 PM --------- [/SIZE] [/COLOR][quote=sabbar2011;4193846]كل الشكر اخي العزيز هل ينفع على الروم الرسمي ونوع الركفري لو سمحت الذي تستخدمه مع شكري الخالص[/quote] نعم ينفع اخي . انا استعمل clocworkmod مع كيرنل perseus المفضل لدي[COLOR="Silver"] [SIZE=2]الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 04:47 PM ----------- المشاركة السابقة اضيفت في 04:46 PM --------- [/SIZE] [/COLOR][quote=طلال اسلام;4193849]السلام عليكم طيب ممكن مود مثل هذا للاس 3 شكرا مقدما[/quote] للاسف لا يوجد[COLOR="Silver"] [SIZE=2]الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 04:54 PM ----------- المشاركة السابقة اضيفت في 04:47 PM --------- [/SIZE] [/COLOR][quote=همام الكلدي;4194030]طيب اخوي من افلش المود من الركفري تاتي خيارات بالاروما اشر على الجميع بالصح ولا كيف تم الإرسال من جهازي GT-N7100 بواسطة تاباتوك 2[/quote] الامر يتعلق بك اخي حسب احتياجاتك الخاصة عموما اغلب الخيارات مفيدة |
[COLOR="Green"][SIZE="4"]جربت تحسين صور الكاميرا, لم أجد اختلافا يذكر. ربما الروم الذي أنا عليه يشمل هذه المودات.[/SIZE][/COLOR]
[quote=hskeik;4195870][COLOR="Green"][SIZE=4]جربت تحسين صور الكاميرا, لم أجد اختلافا يذكر. ربما الروم الذي أنا عليه يشمل هذه المودات.[/SIZE][/COLOR][/quote]
انا جربت المود بنفسي الفرق واضح جدا في جودة الصور .الرزولوشن انقى بمراحل |
[CENTER][B][COLOR="Red"][SIZE="6"]أكرر للمره الثالثة
ممكن رابط اخر لتنزيل المود الان موقع التنزيل موقف في بلدي[/SIZE][/COLOR][/B][/CENTER] |
[quote=طير المهاجر;4196247][CENTER][B][COLOR="Red"][SIZE=6]أكرر للمره الثالثة
ممكن رابط اخر لتنزيل المود الان موقع التنزيل موقف في بلدي[/SIZE][/COLOR][/B][/CENTER] [/quote] للاسف عزيزي لا املك رابطا اخر واعتذر عن التاخير |
جميع الأوقات بتوقيت GMT +3. الساعة الآن 07:45 AM. |
