[روم] الثوره Revolution لجهاز Asus Transformer
[B][I][SIZE="4"][SIZE="4"][SIZE="7"][SIZE="4"][COLOR="Red"][SIZE="4"][/SIZE][/COLOR][/SIZE][/SIZE][/SIZE][/SIZE][/I][/B][B][SIZE=4][COLOR=darkslateblue]السلام عليكم ورحمة الله وبركاته[/COLOR][/SIZE][/B]
[B][I][FONT=Book Antiqua][SIZE=5]Revolution ROM for Asus Transformer[/SIZE][/FONT][/I][/B] [FONT=Book Antiqua][SIZE=3][B]الروم يدعم كل من[/B] [B]TF101 & TF101G[/B][/SIZE][/FONT] [B][FONT=Book Antiqua][SIZE=3]عباره عن تطوير وتحسين للروم الاساسي من اسوس[/SIZE][/FONT][/B] [B][FONT=Book Antiqua][SIZE=3]سريع جدا ونظيف ومستقر[/SIZE][/FONT][/B] [B][FONT=Book Antiqua][SIZE=3]نسخة WWE اي يدعم جميع اللغات بما فيها العربيه[/SIZE][/FONT][/B] [CENTER][B][FONT=Book Antiqua][SIZE=3]مواصفات الكيرنل[/SIZE][/FONT][/B][/CENTER] [LEFT]New kernel: 2.6.36.4 CPU up to 1.60 GHz ([B]1.20 GHz by default[/B]) - controlled automatically by built it O/C Daemon NOOP as default scheduler SLQB Memory Management CIFS, TUN & UTF8 support LZMA compression Wi-Fi module improved drivers Code cleaned up with custom voltages, tweaks & many more![/LEFT] [CENTER][B][SIZE=3]مواصفات الروم[/SIZE][/B][/CENTER] [LEFT]Fully optimized and tweaked ROOT Unsecured boot.img Newest BusyBox RAM optimizations Speed optimizations SD Card speed tweak Data, cache and system partitions mounting tweaks Battery auto-calibration script Bloatware applications removed All system applications updated to latest available Zipaligned Zipalign on boot Fully de-odexed init.d scripts (BusyBox run-parts) support Signatures hack [B]Excellent battery life[/B] [B]Device partitions mounted & formatted as fast EXT4 with many optimizations and EXT4 alignment[/B] Support almost 24h a day:eek: and many more...[/LEFT] [CENTER][B][SIZE=4]لتركيب الروم[/SIZE][/B][/CENTER] [CENTER][B]تحتاج الى روت من هنا[/B] [URL]http://www.ce4arab.com/vb7/showthread.php?t=378072[/URL][/CENTER] [CENTER][B]وتحتاج الى ريكوفري من هنا[/B] [URL]http://www.ce4arab.com/vb7/showthread.php?t=380606[/URL][/CENTER] [CENTER][B][SIZE=5]طريقة التركيب[/SIZE][/B][/CENTER] [CENTER][B][SIZE=4][I][COLOR=#ff0000]ملاحظة: لا يتحمل كاتب الموضوع أو منتديات [/COLOR][URL="http://www.ce4arab.com/"]الكمبيوتر الكفي[/URL][COLOR=#ff0000] أي عطل قد يصيب جهازك[/COLOR][/I][/SIZE][/B][/CENTER] [RIGHT][SIZE=3][B]حمل الروم وانقله على ذاكرة [/B]SD card[/SIZE] [SIZE=3][B]حمل [/B]Super Wipe [B]وانقله ايضا على ذاكرة [/B]SD card[/SIZE] [SIZE=3][B]ادخل على الريكافري وذلك باعادة التشغيل مع التعليق على زر خفض الصوت وزر التشغيل[/B][/SIZE] [SIZE=3][B]اختر من قائمة الريكافري [/B]install zip from sdcard[/SIZE] [SIZE=3][B]بعد ذلك اختر [/B]choose zip from sdcard[/SIZE] [SIZE=3][B]اختر ملف [/B]Super Wipe [B]واعمل له تثبيت[/B][/SIZE] [SIZE=3][B]بعد الانتهاء مره اخرى اختر [/B]choose zip from sdcard[/SIZE] [SIZE=3][B]اختر ملف الروم [/B]Revolution ROM [B]واعمل له تثبيت[/B][/SIZE] [SIZE=3][B]بعد الانتهاء اعد تشغيل الجهاز باختيار [/B]reboot [B]ومبروك عليك احلى روم ;)[/B][/SIZE][/RIGHT] [CENTER][B][SIZE=3]رابط تحميل الروم[/SIZE][/B] [URL]http://www.androidrevolution.nl/downloader/download.php?file=Android_Revolution_HD-EeePad_2.2.0.zip[/URL][/CENTER] [CENTER][B]رابط تحميل Super Wipe[/B] [URL]http://www.4shared.com/file/EcU6-_aX/Super_Wipe_Full_EeePad.html[/URL][/CENTER] [SIZE="4"][B][COLOR="DarkRed"]هذا الروم سوف يمسح جميع بياناتك وبرامجك السابقه ارجو الانتباه[/COLOR][/B][/SIZE] [CENTER][B]للأخوه اللذين يريدون تركيب 3g كونكت اي اصحاب الواي فاي فقط ثبت الملف عن طريق الريكافري مثل تثبيت الروم[/B][/CENTER] [url="http://www.4shared.com/file/Zvk2prFf/Android_Revolution_HD_3G_Dongl.html"]Android_Revolution_HD_3G_Dongle_Mod_v.0.2.zip - 4shared.com - online file sharing and storage - download[/url] [B][CENTER]ايضا زياره هذه الصفحه وقرائتها[/CENTER][/B] [url="http://forum.xda-developers.com/showpost.php?p=19545637&postcount=1732"]xda-developers - View Single Post - [ROM] Android Revolution HD Performance | O/C | 8.6.6.19[/url] |
هل يدعم 3جي يو اس بي+ هل هو لجميع اسوس اي باد!!!
[quote=شبر الصابري;3051398]هل يدعم 3جي يو اس بي+ هل هو لجميع اسوس اي باد!!![/quote]
يدعم كل من [B][FONT=Book Antiqua]TF101 & TF101G[/FONT][/B] بالنسبة ل 3G Dongle الروم يدعم بس يبيلك ملف تثبته عن طريق الريكافري ويشتغل معك ابحاول ابحث عن الملف وارفعه لك |
شلون اعرف اذا يدعم جهازي ولا لا شلون اعرف تفصايل جهازي هل الروم يركب له ولالا
[quote=شبر الصابري;3051455]شلون اعرف اذا يدعم جهازي ولا لا شلون اعرف تفصايل جهازي هل الروم يركب له ولالا[/quote]
روح على الاعدادات بعدين حول الجهاز اللوحي بعدين شوف رقم الطراز سهله:) |
دايم مواضيعك مميزه اخي الكريم دعاء لك من القلب( الله يوفقك بما تسعي فيه لاخوانك والله يسهل اورك وييسرها لك لما تحب وترضا قول امين
[quote=شبر الصابري;3051544]دايم مواضيعك مميزه اخي الكريم دعاء لك من القلب( الله يوفقك بما تسعي فيه لاخوانك والله يسهل اورك وييسرها لك لما تحب وترضا قول امين[/quote]
اااااااامين :) الله يجزاك خير على الدعاء الحلو |
تم اضافة ملف 3g في الموضوع
لا أملك الجهاز
لكن اعجبني طرحك فأحببت ان اضع لي بصمة لموضوعك الجميل فجزاك الله خيراً على ما تقوم به لخدمة اخوانك |
اخي الغالي
انا اشتكي من مشكلة غريبة وهي عدم دقة الضغط على الشاشة فعندما يكون هناك رابط اريد الضغط علية يجب ان اضغط تحته مباشرة وليس عليه تماما؟؟؟؟ لا اعلم هل هي سوفتوير او هارد وير علما ان جهازي جديد له اقل مناسبوع و تم تحديثة الى 3.2.1 هل تنصحني بتركيب الروم المطبوخ هذا أو لا؟؟ شكرا لك مقدما اخي الكريم |
[quote=abo_noora;3052975]اخي الغالي
انا اشتكي من مشكلة غريبة وهي عدم دقة الضغط على الشاشة فعندما يكون هناك رابط اريد الضغط علية يجب ان اضغط تحته مباشرة وليس عليه تماما؟؟؟؟ لا اعلم هل هي سوفتوير او هارد وير علما ان جهازي جديد له اقل مناسبوع و تم تحديثة الى 3.2.1 هل تنصحني بتركيب الروم المطبوخ هذا أو لا؟؟ شكرا لك مقدما اخي الكريم[/quote] هلا اخوي اعتقد ان فيه مشكله في الشاشه عندك فالافضل انك ترجعه وتستبدله لان هذا عيب مصنعي واذا بدلته بواحد جديد ركب الروم لانه افضل من الروم الاصلي |
واجهتني مشكلة
عند اختيار "install zip from sdcard" "choose zip from sdcard" تظهر لي رسالة خطاء E:Can't mount /sdcard هل هناك حل؟ |
[quote=abo_noora;3055004]واجهتني مشكلة
عند اختيار "install zip from sdcard" "choose zip from sdcard" تظهر لي رسالة خطاء E:Can't mount /sdcard هل هناك حل؟[/quote] اعتقد ان جهازك ماقرا الميموري كارد او انك ما ادخلتها زين في الجهاز جرب مره ثانيه ورد لي |
تكفه يامحمد اشرح لنا تنصيب [url="http://www.ce4arab.com/vb7/showthread.php?t=366516.النظام"]تشغيل Native Ubuntu على الايسوس ترانسفورمر - الكمبيوتر الكفي[/url] هذا علي اجهزتنا مافي غيرك يا فكاكا النشايب يفزعلنا ويشرحها لنا بالعربي اشرح متوفر بالانجليزي بس اخوك مييح بالانجلييزي مافتهم تكفه اشرحه لناوطريقت التنقل بينه وبين الاندرويد تكككككككككفه داخل علي الله ثثثم علييييك
[quote=شبر الصابري;3055412]تكفه يامحمد اشرح لنا تنصيب [url="http://www.ce4arab.com/vb7/showthread.php?t=366516.النظام"]تشغيل Native Ubuntu على الايسوس ترانسفورمر - الكمبيوتر الكفي[/url] هذا علي اجهزتنا مافي غيرك يا فكاكا النشايب يفزعلنا ويشرحها لنا بالعربي اشرح متوفر بالانجليزي بس اخوك مييح بالانجلييزي مافتهم تكفه اشرحه لناوطريقت التنقل بينه وبين الاندرويد تكككككككككفه داخل علي الله ثثثم علييييك[/quote]
هلا اخوي شبر انا ما اشوف ان له اي داعي انك تركب ابونتو على جهازك لانه مبني على اللينوكس والاندرويد ايضا مبني على اللينوكس فما راح تشوف شي جديد وبعدين نضام التشغيل الموجود حاليا مأدي الغرض واكثر انت جرب الروم هذا وبتلاحظ فرق واضح في السرعه والاداء لكن مافيه مانع ابلقي نضره وبشوف بس ما اوعدك بشي :D |
[quote=bluemohammad;3055615]هلا اخوي شبر انا ما اشوف ان له اي داعي انك تركب ابونتو على جهازك لانه مبني على اللينوكس
والاندرويد ايضا مبني على اللينوكس فما راح تشوف شي جديد وبعدين نضام التشغيل الموجود حاليا مأدي الغرض واكثر انت جرب الروم هذا وبتلاحظ فرق واضح في السرعه والاداء لكن مافيه مانع ابلقي نضره وبشوف بس ما اوعدك بشي :D[/quote] اشرحه تكفه ترى مالنا الا الله ثم انت والله انك الوحيد اللي افهم منه الشرح لسهولة شرحك |
[quote=bluemohammad;3055060]اعتقد ان جهازك ماقرا الميموري كارد او انك ما ادخلتها زين في الجهاز
جرب مره ثانيه ورد لي[/quote] شكر الله لك اخي الكريم ليس لدي ذاكرة خارجية!!! هل من الضروري وجودها؟ لاني اعمل على الذاكرة الداخلية فقط ولا احتاج الخارجية!!! تحياتي |
[quote=abo_noora;3057297]شكر الله لك اخي الكريم
ليس لدي ذاكرة خارجية!!! هل من الضروري وجودها؟ لاني اعمل على الذاكرة الداخلية فقط ولا احتاج الخارجية!!! تحياتي[/quote] هلا اخوي لتركيب اي ملف او اي روم على جهاز الترانسفورمر لابد من ذاكره خارجيه خذ لك وحده اثنين قيقا بعشرين ريال تقريبا وخلها للترقيات |
شباب مين ركب الروم مع ال3g انا ركبته بس مفيش اعدادات لل internet
[quote=abbas harb;3059066]شباب مين ركب الروم مع ال3g انا ركبته بس مفيش اعدادات لل internet[/quote]
اخوي انا جهازي 3g مجرد ماخلصت من تثبيت الروم ركبت شريحة البيانات واشتغل معي دايركت |
مشكور بس انا قصدي يالي ماعندو 3g? كيفية تعرف الجهاز على الموديم
[quote=abbas harb;3065025]مشكور بس انا قصدي يالي ماعندو 3g? كيفية تعرف الجهاز على الموديم[/quote]
اخوي انا ارفقت في اخر الموضوع ملف للي ماعنده 3g وحاب يشبك اليو اس بي كونكت في مخرج اليو اس بي الموجود في الكيبورد هذا الملف يخلي جهازك يستطيع قراءة الكونكت ارجو اني افدتك |
[quote=bluemohammad;3065318]اخوي انا ارفقت في اخر الموضوع ملف للي ماعنده 3g
وحاب يشبك اليو اس بي كونكت في مخرج اليو اس بي الموجود في الكيبورد هذا الملف يخلي جهازك يستطيع قراءة الكونكت ارجو اني افدتك[/quote] انا سويت كل التطبيقات يالي انت شارحها والروم تمام واعدادات ال anp كمان من شركة المودم usb ولاكن عندي جملة تطلع كل ماحولة ادخل النت لا يمكن الاتصال بي الشبكة .علمأ هادي ثاني روم بجربها وش احل برأيك :cold::cold::( |
اتفضل عزيزي
[quote=شبر الصابري;3055408]تكفه يامحمد اشرح لنا تنصيب [url="http://www.ce4arab.com/vb7/showthread.php?t=366516.النظام"]تشغيل Native Ubuntu على الايسوس ترانسفورمر - الكمبيوتر الكفي[/url] هذا علي اجهزتنا مافي غيرك يا فكاكا النشايب يفزعلنا ويشرحها لنا بالعربي اشرح متوفر بالانجليزي بس اخوك مييح بالانجلييزي مافتهم تكفه اشرحه لناوطريقت التنقل بينه وبين الاندرويد تكككككككككفه داخل علي الله ثثثم علييييك[/quote]
[url="http://www.ce4arab.com/vb7/showthread.php?t=366516"]تشغيل Native Ubuntu على الايسوس ترانسفورمر - الكمبيوتر الكفي[/url] |
جميع الأوقات بتوقيت GMT +3. الساعة الآن 07:25 PM. |
