للاسد اندرويد (5 ابريل) معرب سريع جدا [cLK/MAGLDR]TyphooN CyanogenMod 7 RC4+ v3.0.0[2.3.3][A2SD][tytung r9b]
[LEFT] [B][05.APR.2011][cLK/MAGLDR]TyphooN CyanogenMod 7 RC4+ v3.0.0[2.3.3][A2SD][tytung r9b]
[/B][RIGHT][B]طبعا الروم غنى عن التعريف و يعد من اقوى الرومات المطروحة المبنية على جينجربريد CyanogenMod 7 RC4[/B] [B]بعد تجربة الروم على الاسد الخاص بى الروم اكثر من ممتاز سريع جدا و يدعم العربية و جميع الخصائص تعمل بدون مشكلة[/B] [/RIGHT] [CENTER][B][SIZE=5]TyphooN [COLOR=Blue]CyanogenMod 7 [/COLOR][/SIZE][/B][LEFT][COLOR=Blue][SIZE=3][COLOR=Red]v3.0.0: Changed kernel to tytung r9 beta. Updated to cm_bravo-36 base. Updated initrd to be compatible with tytung r9 beta. Updated to tytung's /system/bin/vold thanks to athulag's testing. Apps running from SD should now work even without A2SD+. Cleaned up /etc/init.d/ of unneeded init.d scripts, this should fix any market issues. Removed ROM Manager from MAGLDR build as it unneeded. Changed build.prop values for PPP stability. I recommend you update your partition layout to one of the newer layouts that uses a smaller /cache/ partition as a bigger one is no longer needed. Updated bootanimation, I think you guys will like this one! Updated hosts file for ad blocking [/COLOR][/SIZE][/COLOR][/LEFT] [B]Features:[/B] -No Custom apps, all apps included that come stock with CM7 -3G / Data -Audio -Bluetooth -Bluetooth Low Power Mode -Bluetooth Unique MAC Address -Bluetooth Auto Reconnect (thanks tytung for all new bluetooth features) -GPS (diem fix) (/system/etc/gps.conf configured for US) -Wi-Fi -Phone -Camera (5MP) -Volume Up/Down rocker camera control -Camcorder (800x480) -720P video playback -Hosts file to stop most web ads. -USB File Transfer -Apps running from SD even without A2SD+ -ADW Launcher (CM7 Stock) -Native WIFI Tethering with or [URL="http://code.google.com/p/android-wifi-tether/"]android-wifi-tether[/URL] -Wired Tethering with [URL="http://code.google.com/p/android-wired-tether/"]android-wired-tether[/URL] -LED Notification -A2SD+ -IEEE 802.1x/EAP authentication -Adjustable CPU voltage via /system/etc/init.d/98cpu_voltage This can help overclocking stability and battery usage. [/CENTER] [B]Clean Install MAGLDR:[/B] 1. [URL="http://forum.xda-developers.com/showthread.php?t=644781"]Task 29[/URL] 2. [URL="http://forum.xda-developers.com/showthread.php?t=611787"]Flash Radio(2.15 Recommended)[/URL] 3. [URL="http://cotulla.pp.ru/leo/Android/DFT_LEO_MAGLDR113_DAF.rar"]MAGLDR 1.13[/URL] 4. [URL="http://www.multiupload.com/9U7L42DO3O"]MAGLDR 130MB System/4MB Cache (ClockworkMod Recovery v3.0.2.4)[/URL] 5. Install TyphooN CyanogenMod 7 .zip with CWM Install tutorials thanks to unsinkable2: [URL="http://www.multiupload.com/16E8GABS6A"]Clean Installation[/URL] [URL="http://www.multiupload.com/XME3QZPGWX"]ROM or Kernel-Update[/URL] [URL="http://www.multiupload.com/PFWB3IDI8S"]ROM-Update including CWM-Update[/URL] [B]Clean Install cLK:[/B] Follow [URL="http://www.multiupload.com/H01L5ZTY2O"]Charmacas's tutorial[/URL] -Reference [URL="http://forum.xda-developers.com/showpost.php?p=12327648&postcount=844"]stirkac's cLK install guide[/URL] if you are confused on any step along the way. You do not need a custom kernel/initrd update package. Everything you need for that is included in my cLK update .zip. [URL="http://forum.xda-developers.com/showthread.php?t=933951"][05.APR.2011][cLK/MAGLDR]TyphooN CyanogenMod 7 RC4+ v3.0.0[2.3.3][A2SD][tytung r9b] - xda-developers[/URL] [B]Download:[/B] -Current Version v3.0.0: [URL="http://www.multiupload.com/Y8DERXROT6"][B]MAGLDR[/B] md5sum 42b0560c2840c0604c99be926184df0d[/URL] | [URL="http://www.multiupload.com/PU97LUHDQD"][B]cLK[/B] md5sum 04e82a3fb679251144d6398ee851d9e2[/URL] [/LEFT] |
هنيئا لمستخدمي الناند.... |
فعلا نغبطهم على هذا الإصدار... عقبالنا إن شاء الله...
[FONT="Tahoma"][SIZE="3"][COLOR="Navy"]شكراً لك mahernokia على جهودك، ولكن هل تكمل معروفك وتضع لنا طريقة التركيب باللغة العربية؟[/COLOR][/SIZE][/FONT]
جارى اعداد دليل التثبيت باللغة العربية
بارك الله فيك والف شكر
بارك الله فيك و مشكور على الطرح
جاري التحميل و التجربة..... |
ألف ألف ألف ألف ألف ألف شكرااااا
تم التنزيل .. ذهب .. :) سلمت للنقل _____ [U][COLOR="Red"]Update[/COLOR][/U] في مشكلة مهمة .. وهي ظهور رموز صينية أحياناً بين الحروف والأرقام .. أيضاً عند وصول إيميل أو مسج يظهر في التاسك بار وفي التنبيهات على شكر مربعات, علماً أني جربتها باستخدام 3 خطوط منهم الخط المعتمد من اندرويد .. |
[B][SIZE="5"][B][COLOR="Red"]تثبيت الروم سوف يلغى روم الويندوز الموجود على الاسد للرجوع مرة اخرى الى الويندوز يرجى تثبيت الروم الاصلى[/COLOR][/B][/SIZE][/B]
[COLOR="Blue"][B]هذا يعني أنك تفقد الإعدادات والتطبيقات والبيانات. [/B][/COLOR] [COLOR="Red"][B][SIZE="5"]متطلبات التثبيت[/SIZE][/B][/COLOR] [B][SIZE="4"][COLOR="Blue"][RIGHT] Hard SPL 2.08 Task29 Radio Leo 2.15.50.14 MAGLDR 1.13 Recovery_130M_system_4M_cache[v3.0.2.4] تقسيم الذاكرة تثبيت الروم[/RIGHT][/COLOR][/SIZE][/B] [B]يجب أن يكون الجهاز مشحون لا يقل عن 50 ٪ من طاقة البطارية[/B] [COLOR="Red"][B][SIZE="3"]اولا HSPL2.08 2.15.50.14[/SIZE][/B][/COLOR] يجب فك حماية الاسد HSPL2.08 2.15.50.14 سبق ان شرحة الاخ ابو كريم [url="http://www.ce4arab.com/vb7/showthread.php?t=188723"]موضوع فك الحماية للاتش دي2 -الاسد - تم :) - الكمبيوتر الكفي[/url] [B][COLOR="Red"][SIZE="3"]ثانيا Task29 [/SIZE][/COLOR][/B] إدخل على البوت لودر يجب اعادة تشغيل الجهاز مع الضغط على الزر الجانبى للصوت الى اسفل سوف تظهر شاشة من ثلاثة الوان و هى شاشة البوت لودر نصل الاسد بالكمبيوتر عن طريق وصلة يو اس بى إفتح ملف Task29 provided by doloop وقم بتشغيل برنامج Task29 provided by بعد الإنتهاء من التنصيب يتم اعادة التشغيل اتوماتيكيا [B][COLOR="Red"][SIZE="3"]ثالثا Radio Leo 2.15.50.14 [/SIZE][/COLOR][/B][SIZE="3"]إدخل على البوت لودر مرة اخرى افتح ملف Radio Leo 2.15.50.14 و قم بتثبيت ROMUpdateUtility بعد الإنتهاء من التنصيب يتم اعادة التشغيل اتوماتيكيا [B][SIZE="3"][COLOR="Red"]رابعا MAGLDR113[/COLOR][/SIZE][/B] إدخل على البوت لودر مرة اخرى إفتح ملف MAGLDR113 و قم بتشغيل برنامج ROMUpdateUtility بعد الإنتهاء من التنصيب يتم اعادة التشغيل اتوماتيكيا[/SIZE] [B][SIZE="3"][COLOR="Red"]خامشاRecovery_130M_system_4M_cache[v3.0.2.4][/COLOR][/SIZE][/B] بعد ذلك و عند اعادة التشغيل استمر فى الضغط على رز الباور للدخول على قائمة MAGLDR اختار الاختيار الخامس USB FLASHER انتظر الى ان يتم التوصيل USB قم بتثبيت الريكفرى عن طريق تشغيل برنامج DAF [B][SIZE="3"][COLOR="Red"]سادسا تقسيم الذاكرة[/COLOR][/SIZE][/B] [B][SIZE="4"][COLOR="Navy"]يجب ان يكون كارد الذاكرة سبق تقسيمة الى قسمين[/COLOR][/SIZE][/B] fat32 ext2,3,4 سبق تناولة بالتفصيل فى المشاركة [URL="http://www.ce4arab.com/vb7/showthread.php?t=285067"]http://www.ce4arab.com/vb7/showthread.php?t=285067[/URL] [B][COLOR="Red"][SIZE="3"]سابعا تثبيت الروم[/SIZE][/COLOR][/B] يتم نسخ الروم الى الذاكرة ثم الدخول الى قائمة MAGLDR مرة اخرى ثم اختار رقم 8 AD RECOVERY انتظر التحميل ثم اختيار INSTALL ZIP FROM SDCARD ثم CHOOSE ZIP FROM SDCARD و اختيار الروم ادعو الله ان اكون قد ساهمت فى شرح طريقة التثبيت سامحونى لو قصرت فى شئ فى الشرح |
[U][COLOR="Red"]في مشكلة مهمة ..[/COLOR][/U]
[quote=adel86;2353068][U][COLOR="Red"]في مشكلة مهمة ..[/COLOR][/U]
وهي ظهور رموز صينية أحياناً بين الحروف والأرقام .. أيضاً عند وصول إيميل أو مسج يظهر في التاسك بار وفي التنبيهات على شكر مربعات, علماً أني جربتها باستخدام 3 خطوط منهم الخط المعتمد من اندرويد ..[/quote] سوف احاول البحث عن هذا رغم اننى استخدم الروم بدون مشاكل حتى الان و لم اضف اى تعريب اضافى للروم |
[FONT="Tahoma"][SIZE="3"][COLOR="Navy"]جزاك الله خيراً، وشكراً على جهودك.
جاري التجرية.[/COLOR][/SIZE][/FONT] |
1 مرفق
وهي ظهور رموز صينية أحياناً بين الحروف والأرقام .. أيضاً عند وصول إيميل أو مسج يظهر في التاسك بار وفي التنبيهات على شكر مربعات, علماً أني جربتها باستخدام 3 خطوط منهم الخط المعتمد من اندرويد ..[/quote] [B]جرب هذا الحل : عن طريق برنامج روت اذهب إلى مجلد system ثم مجلد الخطوط fonts وابحث عن الخط الذي نسخته لنفرض انه خط المهند واضغط عليه ضغطه طويلة لتظهر لك خيارات اختر permissions ثم اجعل صلاحيات الخط كما في الصورة المرفقة .[/B] [B]ملاحظة : لم اجرب الروم بعد ولكن هذا الحل نجح معي في رومات اخرى .[/B] |
كل الشكر لك
ويعطيك العافية على هالروم |
السلام عليكم اخوووي بس لو حملت الروم راح اقدر اقلع فيه على طووول بالطريقة العادية ولا فيها الساالفة ريكفري وعفسة ؟؟؟ ياليت لو ترد علي بسرررعة انا اعيش الحين بدون ررروم كل ماأحمل رووم يبيله ريكفري جسبي الله على الريكفري بس تكفى قلي انه بدووون ريكفري
بالنسبة امزامنة الاسماء مع حسباب الجي ميل لايعمل فما الحل
حاولت أركب الروم لكنه رفض
بعد كل العمليات يرجع لي الى صفحة ماجلدر ولا يعمل الروم مع أني طبقت جميع الخطوات علما بأني أركب الرومات عادي ولا عندي مشكلة وعندي خبره فيها الا هذي رفضت تمام 3 مرات اعد العملية ما أعرف وش السبب |
[quote=INTER-MLANO;2354535]السلام عليكم اخوووي بس لو حملت الروم راح اقدر اقلع فيه على طووول بالطريقة العادية ولا فيها الساالفة ريكفري وعفسة ؟؟؟ ياليت لو ترد علي بسرررعة انا اعيش الحين بدون ررروم كل ماأحمل رووم يبيله ريكفري جسبي الله على الريكفري بس تكفى قلي انه بدووون ريكفري[/quote]
لابد من تحميل الريكفري قبل تحميل الروم |
شكرا لك اخي العزيز
لكن الشاشه معلقة على شعار الاندرويد الابيض ويش الحل |
ويش الحل
up |
[quote=سرنديب;2356075]ويش الحل
up[/quote] تاكد من اصدار الراديو المستخدم و حاول تثبيت الروم من جديد |
يعطيك الف عافية و الله مجهودك في شرح التركيب وتعبك في جلب الموضوع اكبر من الروم نفسها
ما ادري هي روم والا خيال روم؟ |
بالنسبة لمزامنة الاسماء مع حساب اجي ميل لايعمل فما الحل ؟
sync for contact from gmail for google to my phon لم اجد رد فما الحل ؟ |
تمت مراسلة الطباخ لمعرفة سبب المشكلة
لمن يعاني من مشكلة مزامنة الأسماء من Gmail نزل الملف المرفق في هذا الموضوع الذي في الرابط [url="http://www.ce4arab.com/vb7/showthread.php?t=305604"][5/4/2010] الخبز العربي الإصدار الرابع AraBread v4.0 (ستوك جينجربريد 2.3.3)(محاذاة)(إستقرار)(كيبورد عربي)(تعريب النظام والقوائم والبرامج)(توفير البطارية) - الكمبيوتر الكفي[/url] وطبق الخطوات تم حل مشاكل جهات الإتصال والرسائل -- يوجد ملف في المرفقات يقوم بهذه العملية طريق تثبيت fix جهات الإتصال والرسائل تحميل الملف المرفق في الموضوع نقل محتويات المجلد وليس المجلد كامل الى مجلد gscript في كرت الذاكرة الخارجي الدخول لتطبيق gscript ومن ثم الضغط على زر اوبشن (علامة الوندوز) بعدها قم باختيار add script ومن ثم load file راح تجد ملف اسمه fix.sh اضغط عليه وبعدها اعمل save راح يظهر لك في وسط البرنامج كلمة fix اضغط عليه وراح يصير اعادة تشغيل للهاتف بعدها راح تنحل مشاكل جهات الإتصال وياليت تسوو هالخطوة قبل لاتنقلو الأسماء منقول من [url="http://www.ce4arab.com/vb7/showthread.php?t=305604"][5/4/2010] الخبز العربي الإصدار الرابع AraBread v4.0 (ستوك جينجربريد 2.3.3)(محاذاة)(إستقرار)(كيبورد عربي)(تعريب النظام والقوائم والبرامج)(توفير البطارية) - الكمبيوتر الكفي[/url] |
جميع الأوقات بتوقيت GMT +3. الساعة الآن 07:39 AM. |
