TSF Shell Theme Classic v1.0
[IMG]http://www.ce4arab.com/vb7/images/sub/01_2012/643827.gif[/IMG]
ربي اغفر لي و لوالدي وللمسلمين كافة [IMG]http://www.ce4arab.com/vb7/images/sub/04_2012/709044.gif[/IMG] [IMG]https://lh6.ggpht.com/6jww2P3x2_tUKxq2iiQgJL-NPGtMEIuvh_i5LI1qvr9U_7TxtXSHKkYlhpGlc5MqNFQ=w124[/IMG] [COLOR="Red"]سعر البرنامج 1.19$ وهنا مجانا[/COLOR] [IMG]https://lh3.ggpht.com/IEnTwSGX9xt9XHC4843i0PlmijfDxI1h0UwJTUFdxyawhC8E6Ajyw62f89imWst7dA[/IMG] [IMG]https://lh3.ggpht.com/Iat-Tj2630HiGmtirB59vSEOC7zqDMH6epNSQOlOdUWBzBKeglHU8mKHdVrz0rcHqQ[/IMG] [IMG]https://lh6.ggpht.com/npyXneEeSRRcwzvSZzKqHfUOMwOtxcUi7N8O3uoDAMFt6DA7WoB9qKLtDsiqtKuQT2Y2[/IMG] [IMG]https://lh5.ggpht.com/-mKTdCDjNN7hxzSFktxXHKMu5RGdNa_lj396CZy1Y9vkZvp3AxmPik2cWHTduEs4avQ[/IMG] [IMG]https://lh4.ggpht.com/tSxahJgeRGVpPfCRssgcNN5AS7Hxwnxt9l3EipLUjYUHoJDOQStVgQhWcS3U8kZXAtk[/IMG] [IMG]http://www.ce4arab.com/vb7/images/sub/04_2012/709044.gif[/IMG] I present my new theme for the TSF Shell !!! INCLUDED IN THIS THEME~ -complete set of high resolution icons that automatically change ALL icons once the theme is applied -2 interchangeable high resolution wallpapers -Custom folders -Custom side drawer -Custom interface & much more! *TO APPLY THIS THEME* After installing and applying TSF Shell as your home launcher, go to MENU>THEMES>(Theme Name)>click on theme image> hit APPLY - and you're all set! :) *TO CHANGE THE WALLPAPER* After applying TSF Shell as your home launcher, go to MENU>WALLPAPER>TSF WALLPAPER>scroll through the thumbnails at the bottom to find the wallpaper of choice that you'd like to use and hit>SET WALLPAPER>and you're all set! ***I really hope you liked my theme, and if you do not hard postavte 5 stars.*** Enjoy! [IMG]http://www.ce4arab.com/vb7/images/sub/04_2012/709044.gif[/IMG] [url=http://www.mediafire.com/?wkv4ccd9ci17ldr]اضغط هنا للتنزيل[/url] [IMG]http://www.ce4arab.com/vb7/images/sub/04_2012/709044.gif[/IMG] |
مشششششكووووور
تسلم الأيادي :)
انت بطل يا بطل
جميع الأوقات بتوقيت GMT +3. الساعة الآن 02:28 AM. |
