ONE X-ROM-InsertCoin 17.0.0-SENSE 5 Addons-APM-EQS-OPTIMIZED-3.19
[CENTER]السلام عليكم ورحمة الله
مساكم الله بالخير [COLOR="Red"]تحديث 10.2.5[/COLOR][/CENTER] [LEFT]Changelog for 10.2.5 – Full Rom: - updating boot.img – this means you need to flash it again1 - boot.img: cleaned ramdisk - boot.img: added proper init.d support - boot.img: changed the way partition were mounted - boot.img: removed debugging stuff - fixed reboot binary – props shniz - aligned numbers in calculator app – props shniz - changed gps.conf’s NTP_SERVER from US to Europe - disabled by default HTC FASTBOOT - changed Battery to blue to match the ROM overall color – props Vorbeth - changed GPS icons from green to blue – props Vorbeth - changed Call button from green to blue – props Vorbeth - changed Select all buttom from green to blue – props Vorbeth - added more languages support[/LEFT] [CENTER][url="http://mirror.rawempire.org/baadnewz/InsertCoin_ONE_X_v10.2.5.zip"]HTC Android Custom ROMs[/url] [url="http://d-h.st/keO"]Dev-Host - InsertCoin_ONE_X_v10.2.5.zip - The Ultimate Free File Hosting / File Sharing Service[/url] [url="http://www.xdafileserver.nl/insertcoin-one-x/"]http://www.xdafileserver.nl/insertcoin-one-x/[/url][/CENTER] [COLOR="Red"][CENTER]تحديث 10.7.1[/CENTER][/COLOR] [LEFT]Changelog for 10.7.1 – Full Rom: (It can be flashed on top of IC 10.5.0 w/out wiping) - fixed Exchanged Disable Security optional - reverted Gapps 412 update - fixed syncing problems - fixed reboots[/LEFT] [CENTER][url="http://d-h.st/h3H"]Dev-Host - InsertCoin_ONE_X_v10.7.1.zip - The Ultimate Free File Hosting / File Sharing Service[/url] [url="http://www.xdafileserver.nl/index.php?dir=HTC/One%20X/InsertCoin"]http://www.xdafileserver.nl/index.php?dir=HTC/One%20X/InsertCoin[/url] [COLOR="Red"]تحديث 11.0.0[/COLOR][/CENTER] [LEFT]Changelog for 11.0.0 – Full Rom: (I strongly suggest to perform a full wipe coming from 10.x.x rom) - rebased to One X+ Base 1.14.401.13 – props Football - added APM - added optional 3 levels of AutoBrightness Settings - added optional Disabled Exchange Security - updated market apps to their latest versions[/LEFT] [CENTER][url="http://d-h.st/6GR"]Dev-Host - InsertCoin_ONE_X_v11.0.0.zip - The Ultimate Free File Hosting / File Sharing Service[/url] [url="http://www.xdafileserver.nl/index.php?dir=HTC/One%20X/InsertCoin"]http://www.xdafileserver.nl/index.php?dir=HTC/One%20X/InsertCoin[/url] [CENTER][CENTER][COLOR="Red"]تحديث v11.0.1[/COLOR][/CENTER] [LEFT]- fixed syncing issues - fixed gallery issue with dropbox pics[/LEFT] [url="http://d-h.st/rrN"]Dev-Host - InsertCoin_ONE_X_v11.0.1.zip - The Ultimate Free File Hosting / File Sharing Service[/url] [url="http://www.xdafileserver.nl/index.php?dir=HTC/One%20X/InsertCoin"]http://www.xdafileserver.nl/index.php?dir=HTC/One%20X/InsertCoin[/url] [COLOR="Red"]تحديث 11.5.0 الشكر موصول لأخي مازن 34[/COLOR][/CENTER] [LEFT]hangelog for 11.5.0 – Full Rom: (I strongly suggest to perform a full wipe) - rebased to HTC official JB for ONE X (709.16 with WWE Enabled) – props shniz for base - added battery % mod – props shniz - added APM – props jotha - added optional 3 levels of AutoBrightness Settings – props jotha - added optional Disabled Exchange Security – props shniz - updated market apps to their latest versions - removed apks and lib for bloatware - the ussual optimizations and tweaks - YOU NEED HBOOT 1.28/1.31 - YOU NEED TO UPDATE YOUR boot.img with the one provided in rom.zip[/LEFT] [CENTER][url="http://d-h.st/tV3"]Dev-Host - InsertCoin_ONE_X_v11.5.0.zip - The Ultimate Free File Hosting / File Sharing Service[/url] [url="http://www.xdafileserver.nl/insertcoin-one-x/"]http://www.xdafileserver.nl/insertcoin-one-x/[/url][/CENTER] [COLOR="Red"][CENTER]تحديث 12.0.0 الشكر موصول لأخي مازن [/CENTER] [/COLOR]Changelog for 12.0.0 – Full Rom: (I strongly suggest to perform a full wipe) - rebased on NEW ELEVATE OTA 3.14.401.190 - WiFi should be fixed now - all other mods / tweaks included - you need to flash the new firmware with hboot 1.31 from here [url="http://d-h.st/QBv"]Dev-Host - firmware.zip - The Ultimate Free File Hosting / File Sharing Service[/url] - YOU NEED TO UPDATE YOUR boot.img with the one provided in rom.zip Custom Full ROM [url="http://www.ab-ed.de/baadnewz/InsertCoin_ONE_X_v12.0.0.zip"]http://www.ab-ed.de/baadnewz/InsertCoin_ONE_X_v12.0.0.zip[/url] [url="http://www.xdafileserver.nl/insertcoin-one-x/"]http://www.xdafileserver.nl/insertcoin-one-x/[/url] [CENTER][COLOR="Red"]تحديث 13.0.0 الشكر موصول لأخي مازن[/COLOR][/CENTER] Changelog for 13.0.0 – Full Rom - updated base to 3.14.401.22 (Final JB HTC Base) - removed call recording support (was causing bugs) - removed multitasking extreme (due to new kernel the minfree values don’t stick) - ported APM - all previous tweaks Included - updated all market app to their latest versions - ported stock % battery - ported all blue + blue stock % battery YOU NEED HBOOT 1.31/1.33 [url="http://d-h.st/Wbq"]Dev-Host - InsertCoin_ONE_X_v13.0.0.zip - The Ultimate Free File Hosting / File Sharing Service[/url] [COLOR="Red"]تحديث 14.0.2 الشكر موصول لأخي mahal [/COLOR] Changelog for 14.0.2 – Full Rom – No wipe needed but recommended - cleaned rom a bit more - updated mydropbox – thx lyapota for the fix - updated facebook - replaced ES File Explorer with Solid Explorer - added option to remove Chrome - added option to remove SoundHound Freemium - added option to remove Solid Explorer - added option to remove TuneIN - removed “update only” option in Aroma due issues - added warnings for 3dot option and Friend stream removeable YOU NEED HBOOT 1.33/1.36 [url="http://www.xdafileserver.nl/index.php?dir=HTC/One%20X/InsertCoin"]http://www.xdafileserver.nl/index.php?dir=HTC/One%20X/InsertCoin[/url] [COLOR="Red"]تحديث 15.0 الشكر موصول لأخي مازن[/COLOR] تحديث 15.0 [url="http://www.xdafileserver.nl/index.php?dir=HTC/One%20X/InsertCoin"]http://www.xdafileserver.nl/index.php?dir=HTC/One%20X/InsertCoin[/url] Changelog for 15.0.0 – Full Rom – No wipe needed but recommended - updated base to 3.14.401.31 - system enhacement - fixed htc sync – prop lyapota - updated market apps - removed long press back to kill (causing google now issues) - all previous tweaks optimizations available on latest base - make sure to flash the new boot.img - recommended to update firmware to 1.39 if possible [CENTER][COLOR="Red"]تحديث 15.0.1 الشكر موصول لأخي mahal [/COLOR] Changelog for 15.0.0 – Full Rom – No wipe needed but recommended - fixed long press back to kill option – props lyapota YOU NEED HBOOT 1.31 or higher [/CENTER] [url="http://www.xdafileserver.nl/index.php?dir=HTC/One%20X/InsertCoin"]http://www.xdafileserver.nl/index.php?dir=HTC/One%20X/InsertCoin[/url] [url="http://forum.xda-developers.com/showthread.php?t=1924003"][TOOL] JB FW Easy Flasher Fastboot Toolkit *Update Dec21* hboot 1.31/1.33/1.36/1.39 - xda-developers[/url] YOU NEED HBOOT 1.31 or higher [url="http://www.ce4arab.com/vb7/showthread.php?p=3778992#post3778992"]أداة JBFWTOOL21 لتحديث hboot-htc one x- لمن يرغب بنظام jelly bean [/url] [COLOR="Red"]تحديث 16.13 sense 5[/COLOR] [IMG]http://www.ce4arab.com/vb7/images/sub/03_2013/886169.jpg[/IMG] [IMG]http://www.ce4arab.com/vb7/images/sub/03_2013/886170.jpg[/IMG] •Based on 3.18.401.1 RUU. •Android 4.1.1 with Sense 4+. •Sense 5 AddOns. •Multi-language (WWE). •Deodexed, Recompressed & Zipaligned using SDK r21.1. •Unsecured boot.img. •Persistent ADB enabled. •SuperUser, Busybox, SQLite. •sysrw & sysro binaries. •Launcher prioritization. •Improved RAM management. •Enhanced I/O performance. •Ensured Journalism is disabled. •Partition mount tuneups. •EXT4 filesystem tuneups. •Apps cache cleaned on boot. •SQLITE Vacuum on boot or at every 2 days. •Faster application loading times. •Interactive AROMA Installer. •Option to remove apps (AROMA installer). •Option to install additional mods (AROMA installer). •Bloatware FREE. •Stripped Debugging info Changed from 16.1.3 to 16.1.3_REPACK - fixed missing horzional EQS - fixed % battery issues 16.1.3 - more Sense 5 Icons - horizontal EQS ( props lyapota) - small fixes and changes - boot.img is the same as 16.0.0/16.1.0/1/1/2 NO need to reflash YOU NEED HBOOT 1.31 or higher [url="http://forum.xda-developers.com/showthread.php?t=1924003"][TOOL] JB FW Easy Flasher Fastboot Toolkit *Update Dec21* hboot 1.31/1.33/1.36/1.39 - xda-developers[/url] Custom Full ROM [url="http://www.xdafileserver.nl/index.php?dir=HTC/One%20X/InsertCoin"]http://www.xdafileserver.nl/index.php?dir=HTC/One%20X/InsertCoin[/url] Incremental from 16.1.3 to 16.1.3_Repack [url="http://d-h.st/k6G"]Dev-Host - - The Ultimate Free File Hosting / File Sharing Service[/url] [COLOR="Red"]تحديث 17.0.0 الشكر موصول لأخي مازن[/COLOR] [LEFT]- updated base to 3.19.401.1 - fixed wifi issues - updated market apps - fixed some errors in update-script - all previous mods and tweaks included[/LEFT] [url="http://www.xdafileserver.nl/index.php?dir=HTC/One%20X/InsertCoin"]http://www.xdafileserver.nl/index.php?dir=HTC/One%20X/InsertCoin[/url] المصدر[/CENTER] [CENTER][url="http://forum.xda-developers.com/showthread.php?t=1588669"][ROM]InsertCoin 17.0.0 | SENSE 5 Addons | APM | HTC One X > XDA[/url] [url="http://insertcoin-roms.org/category/devices/one-x/"]One X | InsertCoin - Android Custom Roms[/url] بالتوفيق[/CENTER] |
ماشاء الله عليك
بشرنا صاحبك وصل ؟؟؟؟[COLOR="Silver"] [SIZE=2]الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 03:59 PM ----------- المشاركة السابقة اضيفت في 03:56 PM --------- [/SIZE] [/COLOR]أنا أستخدم ليدرويد وماشاء الله ممتاز جدا |
إن شاء الله سيصل
بالبركه الجهاز اخوي ربيعه[COLOR="Silver"]
[SIZE=2]الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 05:41 PM ----------- المشاركة السابقة اضيفت في 05:39 PM --------- [/SIZE] [/COLOR]بالنسبه للروم انا من ايام الدزاير متعود على طبخ ليدرويد مادري عن هذا الطباخ اخاف اجرب وبطني يعورني هههههه |
ع البركه شاكر جهودك الطيبه مع كل الناس ربنا يوفقك دنيا واخره
الله يبارك فيكم أحبابي
[quote=ربيعة بن نزار;3385213]الله يبارك فيكم أحبابي[/quote]
الله يباركلك بالجهاز بس ما تنسانا نحنا الفقراء لله بالسنسيشن مع اني اعرف نواياك بأنك بعون الله لا تنسى بالمنتدى الله يعطيك القوة لعون هالمنتدى الرائع |
آمين والفال لك إن شاء الله
sensation بقلبي وباقي على متابعة مواضيعه إن شاء الله لم تبدأ متعة sensation حتى الآن |
تم تحديث الروم
17 apr |
مشكور اخي ربيعة بن نزار والله ما بتقصر
الله يبارك فيك
طمنا اخي ربيعة انشالله وصل جهازك one x؟
له يومين أو ثلاثه
بعد شوفة هذا الروم أفكر احذف الروم الرسمي |
تم تحديث الروم
3.2.0 |
مبروك الجهاز كنت انتظر امتلاكك للجهاز حتى تكشف لنا امكانيات هذا الجهاز |
وعليكم السلام ورحمة الله
حياك الله أخي kamal6600 والله يبارك بعمرك يرجى الإطلاع قبل عمل أي شيء [url="http://www.ce4arab.com/vb7/showthread.php?t=418132"]نصيـحـة لمـــلاك HTC ONE X نسخة الشـــرق الأوســـط [/url] |
تم تحديث الروم
3.3.0 |
تم تحديث الروم
3.5.1 |
تم اضافة صور للتحديث الأخير
ويحتوي على الكيبورد العربي |
سلام اخي ربيعة انشا لله بخير .
ويكون جهازك صار تمام شو وضع هذه روم. هل تنصح بها انا مازالت علي روم رسمي بس عملت روت و ريكفوري وفي انتظر خبرتك في اي روم نركب علي ONE X . وشكرا لك . |
هلا بك حاليا في الروم الموجود في هذا الموضوع وجاري الاستكشاف انصح بعمل باكب للروم الأصل عن طريق الريكفري ونقل ملف الروم المطبوخ قبل عمل أي شيء لضمان عدم حصول خطأ |
شكرا لك .
يعني نتظر جوابك نهائي . وتجربتك وشو حسناتها. |
هذا اول روم استفتح به
والقافلة تسير !!! لم يعمل root explorer وهو برنامج يطلب root |
انشا الله خير .
طيب شو طريقة تنزيل روم يعني علي ركفوري وعمل فلاش لروم عادي ، وبعدها ريستارت لجهاز. انا مازلت علي رسمي ما في مشكلة . والله يعطيك العافية علي كل مجهود تنفعنا فيه. سلام |
هلا بك التثبيت عن طريق الريكفري
اعمل نسخة للنظام الرسمي وانقل الروم للجهاز قبل عمل اي شيء |
جميع الأوقات بتوقيت GMT +3. الساعة الآن 10:32 PM. |
