تحديث 12-8-2011
Current Release: 08.12.11 - UPDATE adjusted lcd auto backlight levels adjusted light sensor lux levels adjusted some notification led settings in the build enabled mms content disposition support (lets see if this fixes our mms issues) Added tytung libgps 1.9 NMEA Added cedesmith libhtc_ril_wrapper 0.8b4 Added tablet tweaks Added various changes to config.xml for framework core removed recovery.fstab.magldr, as it is not required Fixed permissiond of /dev/smd27 for gps cyanogenmod changes from Aug 7 to Aug 12 08.12.11 - UPDATE !NEW DATA.IMG RECOMMENDED FOR USERS UPDATING FROM 2.3.4 to 2.3.5! AmeriCanAndroid SD - [url="http://www.multiupload.com/X3DGZSE8VQ"]http://www.multiupload.com/X3DGZSE8VQ[/url] |
ما شاء الله سرعة الاصدار الاخير 2.3.5 من رومات السيانوجين تمتاز بسرعة عالية و استقرار مذهل ، انصح الجميع بالتحديث
جاري التحميل والتجربة إن شاء الله
[CENTER][B]جاري التحميل والتجربة إن شاء الله
جزك الله خيراً :thumbup: [/B][/CENTER] |
شكرا على الروم الرائعة ولكن الماركت لم يظهر عندي ضمن البرامج علما بأني نزلت الروم بالتحديث الأخير 12/8 وشكراً
مشكووووور على هالموضوع
[LEFT]تحديث 17-8-2011
Current Release: 08.17.11 - UPDATE ACAKernel r816 updates: - kgsl updates: *msm_kgsl: Move kgsl_sharedmem_init to module load *kgsl_sharedmem_init/kgsl_sharedmem_close only need to be called once, so move them to the the module load and close functions so they can be available through the life of the module. *msm_kgsl: Optimize TLB flushing Only flush TLB when it is absolutely nessasary as opposed to flushing it on every map and unmap *msm: kgsl: Fix a potential subtraction overflow issue *msm_kgsl: Reuse vmalloced memory buffers Memory buffers that are vmalloced and can be freed are put into a free list and reused later if an allocation of same size is required. - Tweaked the Audio levels a bit more. - Added the HTC Auto White Balance Calibration to the leo. - Modded compile script a tid bit ACABuild Updates 081711: - various aca build tweaks - cyanogenmod updates from 0812 to 0817 08.17.11 - UPDATE AmeriCanAndroid SD - [url="http://www.multiupload.com/9L3IJ2P4AV"]http://www.multiupload.com/9L3IJ2P4AV[/url][/LEFT] |
ممتاز ما شاء الله عليك اخي jaCk متابع التحديث اول باول :)
استهلاك البطارية في نسخة 12 اب كان مرتفعا بشكل جنوني , رغم ان الروم سريعة و ممتازة , أرجو ان يكونو قد وجدو حلا في هذا التحديث الجديد
[CENTER][B][SIZE=4]يا اخوان من تجاربكم لهذه الروم الجميله أي هذه التحديثات أقل استهلاك للبطارية :confused:
بانسبه لي أنا أعتقد ان التحديث [/SIZE][SIZE=4][COLOR=Red]062511[/COLOR][/SIZE][SIZE=4]أو[/SIZE][SIZE=4][COLOR=Red]070511[COLOR=Black] أقل استهلاك للبطارية :) والشكر موصول للقائمين على هذه الروم والإخوة المشاركين جزاكم الله خيراً وتقبل الله صيامكم وقيامكم :thumbup: [/COLOR][/COLOR][/SIZE][/B] [/CENTER] |
أخي البتار سأجرب الاصدار 070511 الذي تفضلت به و نصحت , و عسى أن يكون استهلاكه أفضل , و سنرد بالنتيجة غدا ان شاء الله
جزاك الله كل خير أخي علي هذا الموضوع وجعله في ميزان حسناتك يارب أمين لكن عندي استفسار،اولا الروم مش متعربه هل أحمل أي تعريب من تعريبات الاصدارات السابقه؟
ثانيا مش بتدخل نت من موبينيل (مش عارفه اضيف اكسس بوينت زي ما كنت بعمل في الوندوز) ثالثا استهلاك البطاريه رهيب رغم اني لاغيه الانيماشن.فهل فيه برنامج يقلل الاستهلاك. رابعا التاريج و الساعه كل لما اظبطهم في الاندرويد يبوظوا في الوندوز والعكس. معلش اسألتي كتير بس انا اول مره انزل اندرويد |
ربي يعطيك العااافيه مشكوووور
[CENTER]لا يوجد تجارب من الإخوان:wacko:[/CENTER]
عندي مشكله كمان ان كل لما انزل ابليكيشن من الماركت واجي افتحها يديني failed
و تظهر رساله فورس كلوز |
08.28.11 - UPDATE
AmeriCanAndroid SD - [url="http://www.multiupload.com/3HN1CMKFHQ"]http://www.multiupload.com/3HN1CMKFHQ[/url] |
I will download and try it.Hope all problems that i faced in last version vanished.
بارك الله فيكم
الروم الاخير تم تجربته علي ويندوز فون 7 ولاكن صادفتني مشكله في تكبير حجم الايقونات بلطريقه العاديه بتعديل الحجم الي240 وعند اعاده التشغيل كان شئ لم يكن هل صادفتكم نفس المشكله |
[quote=marracash2009;2783989]بارك الله فيكم
الروم الاخير تم تجربته علي ويندوز فون 7 ولاكن صادفتني مشكله في تكبير حجم الايقونات بلطريقه العاديه بتعديل الحجم الي240 وعند اعاده التشغيل كان شئ لم يكن هل صادفتكم نفس المشكله[/quote] اخي الكريم ارجوا مطالعة هذه المشاركة ولعلها تنفع لانني بالبداية حدث معي ذالك ولكن بالطريقة المذكورة والمنقولة من صفحة الروم على موقع المطورين انحلت المشكلة تماما [url="http://www.ce4arab.com/vb7/showpost.php?p=2705468&postcount=248"]الكمبيوتر الكفي - عرض مشاركة واحدة - للأسد | أندرويد | كارد SD فقط | Gingerbread Cyanogen Mod | رومات AmeriCanAndroid | موضوع متجدد بإذن الله[/url] |
[quote=M K;2784232]اخي الكريم ارجوا مطالعة هذه المشاركة ولعلها تنفع لانني بالبداية حدث معي ذالك ولكن بالطريقة المذكورة والمنقولة من صفحة الروم على موقع المطورين انحلت المشكلة تماما
[url="http://www.ce4arab.com/vb7/showpost.php?p=2705468&postcount=248"]الكمبيوتر الكفي - عرض مشاركة واحدة - للأسد | أندرويد | كارد SD فقط | Gingerbread Cyanogen Mod | رومات AmeriCanAndroid | موضوع متجدد بإذن الله[/url][/quote] بارك الله فيك :) بلفعل قمت بلتعديل علي كل الملفات المذكوره قبل ان اكتب الملاحظه وايضا لم يتغير شئ يبدو ان المشكله تكمن في تعديلي علي بعض ملفات الروم كي تعمل علي الويندوز فون 7 شكرا اخي العزيز علي ردك واذا وفقت لحل المشكله سنوافيكم كي تعم الفائده:) |
[quote=marracash2009;2784276]بارك الله فيك :)
بلفعل قمت بلتعديل علي كل الملفات المذكوره قبل ان اكتب الملاحظه وايضا لم يتغير شئ يبدو ان المشكله تكمن في تعديلي علي بعض ملفات الروم كي تعمل علي الويندوز فون 7 شكرا اخي العزيز علي ردك واذا وفقت لحل المشكله سنوافيكم كي تعم الفائده:)[/quote] هل استطعت تشغيل هذه الروم مع التحديث الاخير المانجو 7720 ؟ شكرا لك اخي الكريم[COLOR="Silver"] [SIZE=2]الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 03:41 AM ----------- المشاركة السابقة اضيفت في 01:56 AM --------- [/SIZE] [/COLOR]اذا ممكن لازاله شاشه البدايه ذات العلم الاميريكي القذر واستبدالها بشاشه سيانوجين الافقيه الزجاجيه حمل الملف التالي Boot Animation.rar فك الضغط انقل المجلد root الى داخل مجلد الروم ثم اعمل ريتسارت كامل للروم او انقل الملف يدويا باستخدام رووت اكسبلورير الى موقعه root system media الرابط لايعمل شكرا لكم |
[quote=ريح الشرق;2786719]هل استطعت تشغيل هذه الروم مع التحديث الاخير المانجو 7720 ؟
شكرا لك اخي الكريم[COLOR="Silver"] [SIZE=2]الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 03:41 AM ----------- المشاركة السابقة اضيفت في 01:56 AM --------- [/SIZE] [/COLOR]اذا ممكن لازاله شاشه البدايه ذات العلم الاميريكي القذر واستبدالها بشاشه سيانوجين الافقيه الزجاجيه حمل الملف التالي Boot Animation.rar فك الضغط انقل المجلد root الى داخل مجلد الروم ثم اعمل ريتسارت كامل للروم او انقل الملف يدويا باستخدام رووت اكسبلورير الى موقعه root system media الرابط لايعمل شكرا لكم[/quote] لا لم اجرب اخر تحديث لاني بصراحه ما عندي استعداد لتهيئه الذاكره واعاده جميع الخطوات مره اخري في انتظار نسخه نهائيه اول هذا الشهر حتي استطيع الاستقرار عليها بعض الوقت واعتقد انه لا توجد مشاكل بلنسبه لرومات هذا المطور مع كل تحديثات الويندوز فون |
[quote=marracash2009;2786941]لا لم اجرب اخر تحديث لاني بصراحه ما عندي استعداد لتهيئه الذاكره واعاده جميع الخطوات مره اخري
في انتظار نسخه نهائيه اول هذا الشهر حتي استطيع الاستقرار عليها بعض الوقت واعتقد انه لا توجد مشاكل بلنسبه لرومات هذا المطور مع كل تحديثات الويندوز فون[/quote] المشكلة في المانجو 7720 هي انه يتم قفل بطاقة الذاكرة لذلك لم اتمكن من انزال الاندرويد معها هل اجد لديك هذا الملف لازاله شاشه البدايه ذات العلم الاميريكي القذر واستبدالها بشاشه سيانوجين الافقيه الزجاجيه حمل الملف التالي Boot Animation.rar لم استطع تحميله من مشاركة ابوفهد شكرا لك |
تهلاك البطارية عالي في الاصدار الاخير هل من حل له ؟
جميع الأوقات بتوقيت GMT +3. الساعة الآن 08:01 AM. |
